Reload this Page >
Census of Hotspots !!!
Old 12-22-2012, 02:33 AM
  #101
BaldEagel
BaldEagel's Avatar
Default RE: Census of Hotspots !!!
ORIGINAL: hooker53
ORIGINAL: BaldEagel
The Rookie does not suffer from this, Possibly this is down to the canards coupled to the elevator, it may be possible to retro fit them onto the hotspot.
Mike
Mike. I know you been flying your Rookie for a time now and was just wondering. What do you set your canard deflection up to in relation to the elev. deflection? also. Do you program to have your pitch vectoring to cut off at a high throttle setting? Thanks and happy holidays to ya.
Roy.
Canard deflection is 15mm both ways except on landing when I use it as an additional air brake and deflect it 80degs nose up.
Pitch vectoring is switched so I can cut it off when I want too, sometimes you want pitch vectoring with high throttle settings especially in those high alpha slow passes to show off. LOL did think of mixing it to the rates so it came on with high rate (playing and 3D) and off with low rate (high speed) but have not got done this yet, but then I want pitch vectoring (not yaw) on take off which is mid rate, decisions decisions.
Compliments of the season to you and yours.
Mike
Mike
Old 12-22-2012, 04:25 AM
  #102
hooker53
My Feedback: (106)
Thanks Mike. Think I will just set it up on a switch so I can cut it off at will and the. Find a way to prorgram it so when I deploy the speed brake it will throw them to the 80 degr you spoke of.
Old 12-22-2012, 05:11 AM
  #103
BaldEagel
BaldEagel's Avatar
Hooker53
Is this on a Hotspot or a Rookie?
Mike
Old 12-22-2012, 05:20 AM
  #104
hooker53
My Feedback: (106)
This is on a Rookie. Somehow the Rookie got into the mix here so took the time to clear this up. Ha. Ha. Wink.
Old 12-22-2012, 05:38 AM
  #105
cmjets
cmjets's Avatar
Hi:
I have the mold for the canopy.
I no get perfect clear still, but if you want one, no problem, I can send you.
Send me a PM.
Regards from Spain.
  #106
BaldEagel
BaldEagel's Avatar
May be an idea to revive a Rookie thread to stimulate some interest in this very capable airframe.
Mike
Old 12-22-2012, 06:37 AM
  #107
BaldEagel
BaldEagel's Avatar
Hooker
I have found a post of yours on a Rookie thread dated April 2012, what's the hold up.
Mike
Old 12-22-2012, 06:44 AM
  #108
hooker53
My Feedback: (106)
Life. Ha. Ha. Just to much to do but, it is next. :-).
Old 12-22-2012, 11:00 AM
  #109
Dr Honda
Dr Honda's Avatar
ORIGINAL: cmjets
Hi:
Send me a PM.
Regards from Spain.
Regardless... a few little dimples beats the heck out of a busted, or missing canopy. The one you sent me looks great !!
Old 12-22-2012, 11:31 AM
  #110
cmjets
cmjets's Avatar
Hello:
Dr. Honda !!! do you received it ? do you like ?
Perfect.
Old 12-22-2012, 01:48 PM
  #111
Dr Honda
Dr Honda's Avatar
ORIGINAL: cmjets
Hello:
Perfect.
Yes, it arrived a few days ago. Thanks !!
Old 12-23-2012, 03:39 AM
  #112
John Tancock
Mine took a year to come from Air Tech!!!!!!!!!!!!
As Carlos knows and PM me, was funny though! LOL
Wish I'd got mine from you Carlos!
John
Old 12-23-2012, 03:27 PM
  #113
cmjets
cmjets's Avatar
Hello:
He is my father with a Hotspot canopy.
Carlos.
ID:	1833185   Click image for larger version
Old 12-24-2012, 12:27 AM
  #114
POWER JET
This is my Hotspot canopy from my mold.
It's fiberglassed with gelcoat.
ID:	1833293   Click image for larger version
ID:	1833294   Click image for larger version
Old 12-25-2012, 04:32 PM
  #115
cuevasan
cuevasan's Avatar
Hey guys i am looking for a canopy for a hotspot pls send me some info to my email [email protected] i just got my hotspot painted and i need a canopy thx
Old 01-01-2013, 04:59 AM
  #116
RUFTER
RUFTER's Avatar
Progress on my build so far:
I have a build thread running on my club's forum, it's in Dutch but there's lots of pictures.
[link=http://www.diestmodelclub.be/forum/viewtopic.php?f=19&t=626]http://www.diestmodelclub.be/forum/viewtopic.php?f=19&t=626[/link]
Regards, Bart.
Old 01-01-2013, 06:06 AM
  #117
SJN
Here`s mine.......my Rookie will be on its wings first though
Old 01-01-2013, 08:13 AM
  #118
hooker53
My Feedback: (106)
ORIGINAL: SJN
Hey SJN. Is there any advantage to runni g Elevons on the Rookie? Mine is set up for them but wonder if I would be better off cutting them loose and running four servos.
Old 01-01-2013, 09:28 AM
  #119
SJN
Im not quite sure what you mean.
The 2 servos in each wing on mine follow each other, and I use them as elevons.......... I might as well have just installed one servo in each wing, and glue the split surface together.
4 servos give a little redudancy, so you can potentialy save the plane if one of the 4 servos die....you might get lucky, and nurse it home
I bought the rookie second hand, and the previos owners had installed 4 servos.
I would myself if I bought it from new just use 1 servo per wing, and glue the elevons together to save a little weight.
I dont think it would be a good idea to use the inboard surfaces as elevator, and the outboard as ailerons if that was what you where thinking about ?
ID:	1835806   Click image for larger version
Old 01-01-2013, 11:04 AM
  #120
Kelly W
Nice clean looking jets Bart / Sonnich. I'm kinda jealous...
Curious, I posted how I fastened my wings and fins on a page or two ago. Would you mind showing some details on how you're going to do it? I might be building another and would prefer to find a good alternate that matches the stiffness but with less build effort.
Thx,
Kelly
Old 01-01-2013, 11:33 AM
  #121
RUFTER
RUFTER's Avatar
I'm just following the build instructions from Thorsten Klaus:
The plywood piece bolts to the fuse, the visible part is glued in the wing at a later stage.
I have added a few holes to the fins to bolt them to the fuse if they turn out to be too loose. But the wings and fins are sheeted with 1mm thick Obechi, and appear to be very stiff, I don't see how they can flutter IF they are wedged properly between the wings and fuse.
I am not going to add rudders, no glassing, just some Oracover and that's it. The idea was to keep this bird light.
Regards, Bart.
Old 01-01-2013, 06:12 PM
  #122
hooker53
My Feedback: (106)
ORIGINAL: SJN
Yes. Inboard Elev and outboard Ail was what I was referring to and you answered my question. Thanks for doing so. I saw your two servoes in each wing and thought you had cut your surface to run them as separate surfaces. I am gonna put Jr 8711 on each wing so think I will be ok there. Thanks again.
Old 01-08-2013, 04:33 PM
  #123
always dangerous
Hi Folk's , may i ask if anyone know's the wing area of the Hotspot ? , also i notice there are New Hotspot's available , are there any differences between the new moulding's and the origional Graupner moulding's , regard's , Dave
Old 01-08-2013, 04:56 PM
  #124
Randy M.
My Feedback: (38)
Hey Guys,
I've found an old canopy that I was thinking about making a plug of. A friend is making a vacuum form machine. I thought I punch out a few if there is interest.
I ordered a canopy years ago from Graupner. I finally got it about 6 months later.
Old 01-08-2013, 07:26 PM
  #125
S HARRIS
Here are a couple vintage HotSpots from days way back! This topic have given me the itch to pull mine out and finish repaint and fly it. Really a fun jet to have. Scott
ID:	1838403   Click image for larger version
