Reload this Page >
Source for BVM 91 Rotor bolt ??
Old 02-08-2013, 04:54 PM
turbine guy
My Feedback: (266)
Default Source for BVM 91 Rotor bolt ??
Yikes,
BVM doesn't carry this anymore and I can't find a source
Anybody got one to sell?
Looks like 1/4 " hex socket bolt - 28 thread pitch - the tough part though is its 2.25 or 2.5" long!
I haven't found a bolt with the correct dimensions anywhere online without buying at least 50!
Also in need of a starter wand as well
Jake
Old 02-08-2013, 05:05 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Default RE: Source for BVM 91 Rotor bolt ??
I will look at home tonight if you can't find one. Someone will have one no worries there.
Old 02-08-2013, 05:06 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Don't feel bad as I remember they were custom made to spec.
Old 02-08-2013, 05:38 PM
turbine guy
My Feedback: (266)
I should have also mentioned - also need an aftbody fairing for the fan unit and the fairing that goes behind the cyl head if somebody's got one lying from years ago!
Jake
Old 02-08-2013, 06:03 PM
john491
My Feedback: (13)
Are you talking about the ducting after head shroud? I've got bolts and after engine shrouds, just not sure what you mean on the other.
John
Old 02-08-2013, 06:32 PM
turbine guy
My Feedback: (266)
Yes, the Fiberglass fairing that's attached to the top duct cover- it directs the airflow just behind the top cylinder head
I need that and the aftbody fairing - it is about 6" FG long cone, attaches to the back of carb with an "s" shaped rod- it directs air smoothly past the back of the fan unit.
Should also add -I just realized I'm missing the 4 rubber rectangle pads that soft mount the fan unit to the mounting plates
About 1/8" thick , 1/4X1" black rubber with 2 holes in them
Let me know what you've got and how much for them
I'm in California and can Paypal
Thanks!
Jake
Old 02-08-2013, 06:39 PM
john491
My Feedback: (13)
I have all the above, but in three dirrerent boxes. I'll locate them tomorrow.
John
edwarda10pilot
Jake:
The rubber "soft mount" pads are still available from BVM as I believe they are used on the current EDF units.
Sorry
Ed
Old 02-08-2013, 07:31 PM
Ron Stahl
My Feedback: (12)
ORIGINAL: edwarda10pilot
Jake:
The rubber ''soft mount'' pads are still available from BVM as I believe they are used on the current EDF units.
Sorry
Ed
True, BVM has them if you can't find them elsewhere.
Old 02-09-2013, 04:58 AM
Dr Honda
Dr Honda's Avatar
Are you just looking for a 1/4-28 bolt... 2.5" long??
Here ya go. $0.78 each.
http://www.boltdepot.com/Socket_cap_...sh_1_4-28.aspx
Old 02-09-2013, 07:33 AM
turbine guy
My Feedback: (266)
The bolts are also 1/4" socket drive to stand up to the torque of starting
All the ones I've found online are3/16" drive
Jake
