Servo Equivalents
RE: Servo Equivalents
Pardon my ignorance as I know nothing about S-bus. At present I fly with a fair range of different servo makes which are mainly digital, but some are analog. If I was to go totally Futaba and S-bus, would I have to replace all my existing servos with S-bus compatible servos?
NJ
I hope this helps
JR8711
Digital 2.36 oz 1.58×0.82×1.56 in 4.8V: 4.8V: ? (add) Single Bearing Metal $139.99
(66.9 g) (40.1×20.8×39.6 mm) 347.0 oz-in (25.0 kg-cm) 0.19 sec/60°
6.0V: 6.0V:
403.0 oz-in (29.0 kg-cm) 0.15 sec/60°
Futaba S9075SB Digital S.Bus Prog $149.97
FUTM0455
Volts Torque Speed
6.0V 425 oz-in (30.6 kg-cm) 0.14 sec/60°
spacer
Dimensions Weight
1-5/8 x 13/16 x 1-1/2 in
(41 x 21 x 37 mm) 2.5 oz (71 g)
JR8411
Digital 2.03 oz 1.54×0.75×1.36 in 4.8V: 4.8V: Coreless Dual Bearings Metal $114.99
(57.5 g) (39.1×19.1×34.5 mm) 155.0 oz-in (11.2 kg-cm) 0.18 sec/60°
6.0V: 6.0V:
188.0 oz-in (13.5 kg-cm) 0.15 sec/60°
S9074SB Digital S.Bus Prog $124.98
FUTM0454
Volts Torque Speed
6.0V 278 oz-in (20.0 kg-cm) 0.17 sec/60°
Dimensions Weight
1-9/16 x 13/16 x 1-7/16 in
(40 x 20 x 37 mm) 2.2 oz (63 g)
Alan
JR8711
6.0V: 6.0V:
FUTM0455
Volts Torque Speed
spacer
Dimensions Weight
JR8411
6.0V: 6.0V:
FUTM0454
Volts Torque Speed
Dimensions Weight
Alan
I'm using Align Servos for my planes, I used this for my helicopter and they works hard and so far today I haven't had any problem.
Align DS-610
Torque: 4.8V:133.3 oz-in (9.60 kg-cm)
6.0V:166.6 oz-in (12.00 kg-cm)
Speed: 4.8V:0.10 sec/60°
6.0V:0.08 sec/60°
Nice and cheap.
US$67.99
Align DS-610
6.0V:0.08 sec/60°
Nice and cheap.
US$67.99
My Feedback: (50)
ORIGINAL: Malcolm H
Can someone advise me the Sbus equivalents in terms of performance and physical size of JR 8411 and 8711?
Malcolm
Malcolm
http://www.futaba-rc.com/servos/sbus.html
I did some googling:
http://www.futaba-rc.com/sbus/index.html
Not only can you use existing conventional servos operated via a number of SBD-1 S.Bus Decoders, but you can also convert any make of Rx to S.Bus, not only Futaba, by installing a SBE-1 S.Bus PWM Adapter.
I guess most of you on this thread already knew that, but it gives me, a long term JR and Spekky user, food for thought.
