Reload this Page >
Taft Hobby EPO Viperjet, 90mm EDF/micro turbine *Video*
Old 05-17-2017, 02:44 PM
  #101
Aussie1
Originally Posted by Henke Torphammar
You got a hint in which region you need to be. Order your pipe longer then you need and use a pair of scissors to adjust the length. It needs to end 1-2" in to the outer shroud (the 90mm EDF duct) to get a nice venturi effect cooling things even on the ground.
Our kits are based on our testing and for just that setup so in other planes with other setups it might differ a bit.
We fount it beeing quite east to drop 1lb of push but still very doable to keep the full power, even with a slight gain if done right.
Same engine, same pipe, just diffrent positioning
http://www.youtube.com/watch?v=adO9NiI7edA Our longest 40mm pipe to date, for the Jepe Hawker Hunters that seems to be the next boom in foamy jets.
I have had this jet for several months now and love flying it with my Jetcat P20 turbine. I decided to mount the engine in the tail, thereby eliminating a thrust tube, also I mounted a 700 Ml tank over the CG and the three on-board batteries spaced so that the CG was perfect, and didn't change in flight. Flying time is about 8-9 mins and I set my timer to 7 mins with leaves around 1/2 inch of fuel in the tank. The performance is fantastic and becomes even better during flight as the fuel burns off. I have now converted four 90mm foam jets to P20 power and feel that they are a perfect combination and highly recommend this setup, if you can afford the turbine. I also added some plywood to the nose-wheel area under the steering arm and found that this stops the arm binding, sometimes during retraction. My next conversions are the Freewing F104 and Venum jets.
Name:	Viper P20 1.jpg
ID:	2215794   Click image for larger version
Name:	Viper P20 2.jpg
ID:	2215795   Click image for larger version
Name:	Viper P20 3.jpg
ID:	2215796   Click image for larger version
Name:	Viper P20 4.jpg
ID:	2215797   Click image for larger version
Name:	Viper P20 5.jpg
Old 04-20-2019, 01:38 AM
  #102
Schiefsko
Schiefsko's Avatar
Some weeks ago I finished the refurbishing of an old TH Viper; put in a Kolibri T25, covered the whole plane with self adhesive film and have a lot of fun with that bird.
Here a short video:
Greetings from Salzburg/Austria/Europe
Peter
