Reload this Page >
How many JL/GJC BAE/T-45's are flying
Old 04-20-2013, 10:55 AM
Hughes500E
My Feedback: (16)
Hughes500E's Avatar
Default How many JL/GJC BAE/T-45's are flying
Just curious how many are still flying or building the Jet Legend (GJC) T-45's or BAE Hawks. I'm working away on modifying one. The T45 Hawk bible (thread) here on RCU is no longer active.
Old 04-20-2013, 12:25 PM
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
Default RE: How many JL/GJC BAE/T-45's are flying
wasted money
http://www.rcuniverse.com/forum/m_10..._4/key_/tm.htm
http://www.rcuniverse.com/forum/m_95...tm.htm#9546375
Old 04-20-2013, 12:44 PM
ash 26
How can you make such a statement I no of lots of guys that fly them successful UK-and Ireland it is all down to the set-up
anyway for some one that is a so called rep of another Mfg to bash the competition is out of line
Old 04-20-2013, 03:58 PM
Hughes500E
My Feedback: (16)
Hughes500E's Avatar
Mine is coming along good. Mostly interested in hearing from guys flying them, thanks!
Steve
Old 04-20-2013, 09:56 PM
paulsf86
My Feedback: (52)
I had 135 flights on my first one until I made a bad mistake during one manueuver. My mistake. If you set this airplane up correctly you will have many fun hours of flight time. Like any other jet/model aircraft, if you maintain it correclty and treat it with respect, it will last forever. Does not need to be overpowered. I flew mine with a P70 and it was quite scale, in fact won a number of Scalemasters qualifiers and one open class championship.
I am working on a second with some scale modifications. I will not make any changes to the airframe as the design works well. Set the CG at 140-145 mm from leading edge at center section. Don't use too much flap and use the speed brakes. As I said, don't overpower, it does not need it and only adds weight and drinks more fuel.
Good luck and have fun. Ask any questions and I will try to answer them honestly.
Paul S
Old 04-20-2013, 10:04 PM
kev-o
Just starting on one for a customer , will,do the usual things I domon a build and will beef up,te stab pivot are Will be p70 powered and kept light where I can without sacrificing strength.
Kevin
Old 04-21-2013, 09:23 AM
Hughes500E
My Feedback: (16)
Hughes500E's Avatar
Thanks guys! I will be using JR8711 servos on the tail and flaps. Right now I have one servo setup on the tail with the upgraded arms instead of the ujoint. I'm thinking (after watching the F-14 vid) maybe I should be running two, one for each side?
I too have a P70 kero start for mine.
