Turbine Rebuild Hours
As I have gotten these motors used, with unknon number of hours, So I figured this winter I would send one in for Service to be safe, I sent a email to AMT Netherlands and there responce was:
There are a few versions of the Mercury but we do not have any parts any more for the very first version, you can recognize them with at the "open" compressor nut.
<o></o>
I assume that the engines you have are "air start engines", a typical "overhaul" would cost around 750,- Euro (ex shipping back) depending on the state of the engine. Wich is almsot $1k in US dollars.
Is this the typical rebuild cost?
But my main question is, The turbine guys I fly with tell me they have to send in there turbines after 25 hours, one told me he has sent his in 2 times after his 25hour use with no need to have the bearing changed.
So I was looking around on USMicroJets web site, (the compnay is no more and is up for sale) and on there question section it shows this.
Q. | What is the service interval? |
A. | We recommend that an engine be sent in for a checkup after every 100 hours of service. Note: Although 200 hours of service before rebuild is common, service greatly depends on the application and the environment in which the engine is operated. |
So whats the deal educate me guys, is it really 100-200 hours but the turbine companys are trying to make some of there money back selling them so cheap by makeing you send them in every 25hours?
Is it becouse our use in Hobby aircraft vs civilan aplication is more prone to dirt?
I was told as long as I hit the Same RPM at wot not to have any worries, wich makes a lot of since. So except useing good oil, is there steps that can help your berrings last longer?
Ie put some trubine oil in the fuel intake line to get a good spash every so often?
Thanks guys Mike
With the older turbines you are flying you will have to bite the bullet for servicing. Some the newer motors come with lifetime service plans that cover overhauls for just a small flat fee. Jet Central is one and has had theirs in place for a while, and others are coming on board with the same service plans.
Take care.
Mike
Ivan
Jason
I've got a few AMT turbines and can tell you that as long as you run the correct fuel and oil and don't fly in the Sahara, you can expect bearing performance beyond any of the other brands at present. For example, I sent my Pegasus in for a check up after 100+ hours and the response was "the bearings do not require replacement".
Good luck, and I hope you enjoy operating these turbines,
Frank
If you examine the link above you will find the same part numbers for bearings used from one manufacturer to another.. point being they will all go over 25 hours so if you dont have some reason to send it in you dont need to.
