Ripmax Xcalibur Sports jet >
Old 11-30-2013, 11:34 AM
  #251
Hi Jim,
Well done on your maiden flight, glad all went well. Can I ask what TX and RX are you using.
Old 11-30-2013, 12:33 PM
  #252
Jim Cattanach's Avatar
Originally Posted by Nev01
Hi Jim,
Hi Nev, Using JR 11X Tx. Rx is Spektrum AR9020 9 channel dsmx.
Old 12-02-2013, 02:52 AM
  #253
I forgot to mention. I changed the elevator horn for a metal one. The reason being, I had a Boomerang with a plastic horn & eventually the heat from the turbine, made the plastic brittle, causing it to break. Luckily it broke while on the ground.
Old 12-02-2013, 02:56 AM
  #254
Banned
Jim What retracts are you using on the Xcalibur
Old 12-02-2013, 04:30 AM
  #255
I looked at the heat/horn situation. The tail is quite a bit higher than the Boomers and the test models all have plenty of flights over a long period of time. No sign of it going brittle. There are many types of plastic/nylon and these horns are fibre filled. Certainly worth monitoring for sure.
Only 2 weeks for more, can't wait :-))
Old 12-02-2013, 06:28 AM
  #256
Hi, I am using the landing gear supplied for the Xcalibur. It appears very good quality & leak free.
Old 12-02-2013, 06:39 AM
  #257
The Xcalibur tends to float along the runway, so get as much flap on for landing as you can & I used 10mm of crow, which made it even easier.
Old 12-02-2013, 07:12 AM
  #258
Banned
I asked the question because I saw Jetronics valves in your pics. Was this because the supplied valves were no good ?
Old 12-02-2013, 08:11 AM
  #259
affas's Avatar
Sorry for stealing this picture but we are two frineds buying military version so I think I will paint/adding orange film to mine to see the difference :-)
  #260
I asked the question because I say Jetronics valves in your pics. Was this because the supplied valves were no good ?
No, I am sure the supplied valves will be fine.
Since I started flying jets, I have never been a fan of that type of valve worked with servos. I always use either electronic valves, or UP valves.
It's just a matter of preference.
Old 12-02-2013, 09:06 AM
  #261
Alf
We talked about orange or Yellow...so red is also a possible colour for this scheme.
2 weeks...I'll email retract info now
Dave
Old 12-02-2013, 01:16 PM
  #262
My Feedback: (28)
tp777fo's Avatar
What servos did you guys use for the rudders?
Old 12-02-2013, 01:49 PM
  #263
JR DS3401 midi
Old 12-02-2013, 01:53 PM
  #264
I've sold JR 3401, Savox 1250MG, JR 9421 all for rudders, know of people fitting std size too as the factory put a full size opening when they were supposed to put midi size holes! Lighter the better is the word.
Old 12-02-2013, 04:39 PM
  #265
My Feedback: (28)
tp777fo's Avatar
Thanks!
Old 12-03-2013, 06:05 AM
  #266
My Feedback: (44)
RCISFUN's Avatar
Here is a question to those who have flown this model, is there any tendency to "Cobra" on landing like the first versions of the FB Velox?
FB has since fixed that tendency by making the booms longer.
Old 12-03-2013, 07:41 AM
  #267
So far, I have not had any bad experiences with the Xcalibur. I had an older model Velox & it was an accident waiting to happen.
The Xcalibur is longer than the Boomerangs dimensions, which is probably why it performs so well.
Old 12-03-2013, 07:58 AM
  #268
No not at all. We lengthend the booms by 2" during the development, but that was just to reduce a fish tail in bumpy conditions, the nose is quite long... I have Paul playing with balance today and he's now removed 80 grams of weight and its still behaving well.
The Velox was an interesting one...the Hotspot would also do it with a rear balance
Dave
Old 12-04-2013, 03:26 PM
  #269
Hoping to have another M&R supplied Xcalibur in the air soon.
Just receiver to install/connect and set up, then complete assembly of airfame to enable final position of batteries and ballast to be done
Pictures will be posted this weekend
Old 12-06-2013, 02:37 PM
  #270
5skyhawk172's Avatar
Global Jet Club just cashed my deposit. Hope to have my jet by the end of the year. Yea!
Keith
Old 12-06-2013, 07:59 PM
  #271
Question
Hi,
Would this be a good first turbine jet since it is similar to a Boomer? Also, what is "cobra"?
Regards.
Old 12-07-2013, 12:20 AM
  #272
Banned
Originally Posted by Phantoman
Hi,
Regards.
Yes it would be about the best first jet money can buy
A cobra is a high alfa pitch up of the plane. Ie nose up tail down like a cobra rearing up. This model does not do this though
Old 12-08-2013, 09:54 AM
  #273
I believe that the Oleos for this aircraft are "socket" type. Can someone tell me what the diameter of the sockets and their depth are please?
Dave
Old 12-08-2013, 10:06 AM
  #274
I can measure in morning if no one gets back 11 or 12.6mm dia from memory.
Old 12-08-2013, 11:14 AM
  #275
Thanks Dave, much appreciated. I would like to use a set of Behotec C36 retracts (air up/spring down), as I've developed an unhealthy dislike to air/air retracts. I'm just looking at options for Oleos, wheels and brakes. Would the 105mm oleos for the Nano on your site fit?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
