Reload this Page >
Ripmax Xcalibur Sports jet
Old 10-15-2013, 10:42 AM
  #101
Dave Wilshere
Not normally a fan of manual valves as supplied with the package, but the demo model I have holds air for weeks and allows several cycles on a fill. When I build my model I'll use the supplied valves.
Dw
Old 10-15-2013, 12:05 PM
  #102
76Mustang76
76Mustang76's Avatar
My Jet arrived today. Really happy with it and great service from Motors and Rotors. Thanks Dave.
Old 10-15-2013, 01:16 PM
  #103
Dave Wilshere
Jeremy
Glad you are happy, so far we have shipped 10 kits and everyone has been very happy. The last few went out today and our last kit ships tomorrow, so then its just a waiting game for more. I'll be impatient as I've stuck my name down for the next batch :-)
Good news is I did have spare retracts sets in from Ripmax today, already people are asking about fitting them into other models!
Old 10-15-2013, 02:58 PM
  #104
Paul0088
I will use this combined retract brake valve,
The one from the kit I will use on my Carf Spitfire.
Old 10-15-2013, 10:21 PM
  #105
duthie
Dave,
How does the Xcalibur compare flight wise with a Boomerang Nano or Sprint?
Looks like Ripmax have taken a Boomerang and engineered out all the known faults and put the refinements it into a fairly priced package.
Old 10-15-2013, 10:49 PM
  #106
Dave Wilshere
Because of the cleaner aerodynamics it holds momentum better, its between the Nano and Sprint on size, but flies with a P-60, which the Sprint would struggle with. It flies more like a Sprint than a Nano, Ali who did most of the Boomerang testing says its a step up on all of them. Its also a much better package than the Boomers, undercarriage designed to fit and proper instructions. There are three Xcalibur's in the Aberdeen club, you should be able to see one soon.
Dave
Old 10-16-2013, 10:52 AM
  #107
Danneman
Started the build today. Retracts are fitted.
Mounting the P70 turbine was not the easiest, its pretty tight but after som cutting it went in. Will post some pictures tomorrow.
Battery, fuelpump and UAT will be mounted in the nose cone.
Old 10-16-2013, 11:08 AM
  #108
Dave Wilshere
For sure, P-70 is about the largest turbine you can fit! You will need everything in the nose to minimise nose weight!
Dave
Old 10-16-2013, 11:34 AM
  #109
Jamie C
Jamie C's Avatar
Dad's has arrived, do not know what turbine we are going to use. Don't think mum knows yet . . . . . rather him than me!
Old 10-16-2013, 11:59 AM
  #110
FightingIrons
Originally Posted by Jamie C
Dad's has arrived, Don't think mum knows yet . . . . . rather him than me!
Brilliant
I'm going with the P100, should be interesting
Old 10-16-2013, 12:11 PM
  #111
Danneman
By the way. I measured the volume of the tank, about 3.15 liters.
Old 10-16-2013, 01:14 PM
  #112
Dave Wilshere
Jamie sure you have something lying around!
P-100 is a good choice for future projects too.
Tank should be 2.9 ltrs!
Old 10-16-2013, 01:21 PM
  #113
jetster81
Ok, let's compromise by saying its a 3 ltr tank. How are al the installs going?
Old 10-16-2013, 01:26 PM
  #114
Dave Wilshere
It grew, originally it was about 2.5 ltrs. Either way as seen the P-60 version carries it fine.
Old 10-16-2013, 01:27 PM
  #115
Jamie C
Jamie C's Avatar
Yep, will find something . . . . OS 91/Ramtec, BVM91/Viojett or BVM 96? or if i cannot fit those in, i may have to resort to a Jetjoe
I have not seen it yet, do not know if he ordered the retracts for it, Will take a look tomorrow. Will have to go in the queue after the Viggen.
Old 10-16-2013, 02:17 PM
  #116
r 3
r 3's Avatar
3 in Aberdeen mine must be still in the delivery van
Old 10-16-2013, 02:21 PM
  #117
r 3
r 3's Avatar
OK Dave
been on the AAM looking foward to it
Old 10-16-2013, 04:11 PM
  #118
Paul0088
More progress tonight after work, servo leads run, engine installed, fuel tank in to check clearance for leads, ecu in place, rx under same tray, need to mount switch and fuel pump, valves on other tray.
need two more leads to finish servos, next is nose steering closed loop.
Old 10-16-2013, 09:31 PM
  #119
p1andy
Patience William...Haha
maiden at weekend?
Old 10-16-2013, 09:43 PM
  #120
jetster81
Thanks for posting the photos Paul, and it's nice to hear of a build thread that appears to be straightforward and not fraught with problems, keep up the good work.
Old 10-16-2013, 11:07 PM
  #121
Jetflyer3000
Banned
Looks like you are using the same air system for retracts and brakes. One fill valve for both retracts and brakes. It is generally wise to separate these 2 systems so that a leak in the brake system does not drain the more vital air for the retracts. Just an observation from many years doing jets
Old 10-17-2013, 03:11 AM
  #122
Paul0088
quick trip to Motors & Rotors this morning for a couple of servos for rudders and some extension leads.
Almost done, got the nose wheel closed loop done, run some leads, I like the tubes in the booms and wings, helps a lot getting the leads in good design feature.
Old 10-17-2013, 07:24 AM
  #123
Danneman
Some pictures as promised. I have cut off aprox. 20 mm of the duct.
Most of my flying are at paved runways so I skip the FOD for now..
Old 10-17-2013, 02:38 PM
  #124
76Mustang76
Looking for some help with retracts as im stuck with the plumbing. Nothing in manual to help me. Could someone maybe post a sketch so I can use it as a reference.
Thanks Jeremy
Old 10-17-2013, 03:22 PM
  #125
Paul0088
Thanks Jeremy
hope this helps just a quick sketch, add the brake line from each wheel,
then a T piece to join two lines, then only one has to go to front, you will end up with 4 lines, one gear up, one gear down, one brake and the last one to the fill valve and air tanks into the + piece.
