Ripmax Xcalibur Sports jet
#1226
Easy to say now but as soon as it kicked the first time it was time to land...things only get worse! Also better to keep the speed up a little when its kicking in boots of rudder... Did the gear survive with it extended?
Sorry for the loss. One dies and another is born.
I test flew another Xcalibur for one of my fellow club mates, another RAFscheme/P-100Rx combo with JR servos and JR DSX-12 radio.
After a near faultless test flight Roland had a couple of flights and declared himself very very happy. Mate Dave Bugz had his there too.
#1228
My Feedback: (28)
#1229
Hitec mg, it was a used servo from another plane! It had tail wagging sec before crashing
will use new servos from now on! Video of the crash.
https://m.youtube.com/watch?v=txKQeh_XG9g
#1232
Dave not sure how many in the club now, how about a "club" formation cup all up at once
Roland had a great time, he didn't stop talking about it. Would have been nice to get up together but boy was it cold today. Even with just two wing bolts, fuel and a puff of air in the retracts my fingers could only last 2 flights. Roll on the spring.
#1233
CO
I just ordered the new XL Excalibur from GJC here in the USA. Can you tell me if their is a build thread on this new XL? Also can you tell me the Servo requirement and extensions required or anything that is different about this build, thanks.......Bob
#1234
CO
#1235
The Xcalibur+ (Big one) is not released yet, so no built thread. It is a bigger version of this, so you can follow a lot of what is done. There is an Xcalibur+ thread that will show more detail.
Servos need to be 8 x 10kg+ on main controls. Leads will depend on your chosen radio set up. The prototype uses S-Bus futaba with mini hubs
email me at [email protected] and I'll try and help
Dave
Dave
#1236
Dave,
Have been following tread since start, really enjoying it. Now also following Xcalibur large size.
What is 'wag' and 'kicking'? I haven't heard those terms yet.
Alen
Alen
#1237
smoke install and other points.
I have heard others talk about installing a smoke system but have not seen any pictures. So I am posting a few pictures of the smoke system that I installed. I am just wrapping up the build and have about another hour or two of work.
1. you can pretty much see the entire smoke system it's a power box pump run off of the receiver. The tank for smoke oil is 16 ounces. I can fit and identical tank beside the current one but the tank walls are very thin and it rubs on the canopy so I would need to do something to prevent the tank contacting the canopy. I have also purchased 32 ounce version of this tank and it fits in the spot as well but again contacts the canopy because it is taller. So I will see how this tank works out and possibly go with a larger tank as needed.
2. you can see in the last picture the weight that I needed to add. This Weight needed to be added to the tail section of the plane to achieve a cg at 165mm. Batteries in the nose are 2 x A 123 2500 mah batteries and a king tech 3800 3c life battery. I added this weight in the rudder servo openings with hysol.
3. If bubble trap is added above the front gear enclosure it fits perfectly in there but if you keep the stock canopy bolt it tightens against the bubble trap. Install a shorter one.
#1238
Hi Canadian Man
Good to see a smoke system fitted, looks great.
Interesting to see that you had to add weight to the rear of the plane with this setup.
Let us know how the first flight goes.
Regards
Greg
Regards
Greg
#1241
Wagging (like a dogs tail!) kick is a momentary wag!
Canadian Man
You not using rudder servos? I can't see anyway it would need tail weight like that!
I have 2 x 2200 2s Li-Pos and a 3400 3s Li-Fe ECU pack in mine with no nose weight and balanced at 170mm
Dave
#1242
There are supposed to be rudders on this plane? ???
Yes rudder servos are JR3421
I could not believe it myself at first and measured 4 times before adding the weight. Looking at the setup though it makes sense to me that the weight was needed in the rear as there are a few extra hefty items in the nose. Mainly Power box smoke pump is a hefty unit and it's ahead of cg. Igyro (not a lot of weight) in nose. King tech fuel pump is under purple fuel filter on underside of tray, but that's not an abnormal location.
#1246
Hi Dave,
Thanks for all your advice to date. I am making some progress with my Xcalibur and will eventually get it done.
Can I please ask you what brand of building stand is the orange one in the photo ? It looks good and I need a new one. Do you sell those ?
Cheers
Dom
Cheers
Dom
Tim
Its a better flying aeroplane, its bigger, flys with the same turbine, better made and not a lot more expensive. We all feel that Boomerang Jets selling the Xcalibur is the ultimate admission of its new position as king of the twin boomers. Actually I have a few friends who think they must be..I think the word used was insane!
Final setting up..
Final setting up..
#1247
AR
Cody
#1248
Triple checked CG tonight and with the weights added and fuel in UAT cg comes in at 165mm. So it's real.
Listed in the powerbox manual it says pump is 110 grams.
I will weigh the plane tonight or tomorrow and let you guys know.
#1249
Helium tailplane :-)
Dom
Its a K&S Aircraft stand, I have four, they are brilliant. Have not been able to get them for sometime, but you should be able to go to Japan, maybe Model Engines deal with them still? http://www.ks-j.net/kands/AutoMakePa...indw-E.cgi?756
Regards
Dave
Dom
Regards
Dave
#1250
Thanks Dave,
I have managed to order one from Japan after a quick google search.
Regards
Dom
Regards
Dom
Dom
Regards
Dave
Dom
Regards
Dave
