Ripmax Xcalibur Sports jet
#1260
Cheers Dave, I've just had another look at my tubing diagram and can see how I can use one of my spare T connectors. More than one way to skin a cat eh.
Nev.
Nev.
#1263
This is how I was going to plumb the retracts, but, when I discovered one of the 4 way connectors was damaged I had to have a re-think, now I'm left wondering what is the best way to plumb using just one 4 way connector. Before I start cutting tubing I would be interested to see how you've done yours.
Nev.
Nev.
#1264
P.S. I have found that the hole in the valve spool to be too small to take any clevis I have at hand. what do you guys use/do to connect the servo to the valve?
Nev.
Nev.
#1265
My Feedback: (53)
Nev.
Nev.
#1266
Nev
You are using the stock valves. You can drill the hole to 1.8-2.00mm if needed
Its why I like the Behotec valve as the gear is down and locked before the brakes (most likely to leak!) are activated. Using the stock valves I'd be tempted to run the two tanks separately
Dave
Dave
#1267
My jet comes in at 16.5 lbs with a full UAT up front. I also have four LiPo batteries in the nose, 2 RX, 1 ECU, 1 3S for my light system. Also 150 grams of lead in the nose with a PST800R down the back. Canadian Man, looking at your install, could you mount some of your batteries on a plate behind your smoke tank? This may eliminate your lead in the tail.
#1269
hi all
test flew Xcalibur #2 ( RAF) scheme , and flew completely different than my old one
trim was way off ( used all available elevator down trim) and the plane kept climbing
cg is at 160mm
right aileron trim was also way off - had aprox 3-5mm right aileron trim to try keep the plane flying level
all I can say is that maybe this specific plane flys different
don't get me wrong , the first plane I had flew like a dream , I needed to offset the motor a bit with down thrust to get it flying straight with full pwer , but at least the elevator trim was level and wings were level too
bit disappointed .. any ideas?
cg is at 160mm
#1270
Using my JR XG11 and Dehotec valve what is the best way to setup the gear? For example, should I use a three way switch with position 1 gear up, position 2 gear down and brakes activating at position 3 or is there a better way of doing things? I have never used retracts before so this is all new territory for me and would appreciate any suggestions.
Nev.
Nev.
#1271
Nev
Look back a couple of pages and I show the set up on an XG-14E. No need to complicate it on 3 pos switch, 2 pos and either mix elevator to activate the brake or use a lever.
Dave
Dave
#1272
Nev.
#1273
Call me in the morning with the tx in front of you and servo plugged into ch 5, screw driver for servo arm screw! Arm radius should be no more than 11mm. I'm in the office around 7.30am
Dave
Dave
