Ripmax Xcalibur Sports jet >
Old 05-02-2015, 09:43 AM
  #1351
Banned
Originally Posted by Dave Wilshere
Denis, quite a few including mine balance without any additional weight
Dave
Thanks that is reassuring
Old 05-02-2015, 02:56 PM
  #1352
Originally Posted by Dansy
Great I wanted this one as soon as I saw Dave put his through it pace.....my type of flying..
I have a PST 800R in mine and it reguired about 250 grams of lead up front. I made up a LED light system and power it with a 3S LiPo and a RC switch. With that battery up in the nose, was able to remove the lead. The lights are super bright and are very helpful on a overcast day, especially the military scheme.
Old 05-07-2015, 04:24 PM
  #1353
Hi,
Just wondering if anyone could give me a quick comparison of the general flying characteristics b/n the Xcalibur and a Falcon 120. I'd also be interested in how the landing rollout is, given the smaller stance between the main gear compared to the 120.
Dave
Old 05-07-2015, 04:31 PM
  #1354
Originally Posted by davow
Hi,
Dave
I have owned both and the Excalibur is by far the better plane, very stable and easy to land.
Old 05-07-2015, 08:12 PM
  #1355
wondering if any one is using the factory nylon control horns any suggetions for up grading i have found the aileron horns fall right between the ailerons hinge powering with a k100 just want make sure they stay on
Old 05-08-2015, 01:15 AM
  #1356
We have all used the nylon control horns, mostly with P-100Rx turbines.
Dave
Old 05-08-2015, 01:35 AM
  #1357
Used the stick horns and links in all surfaces
work great
i have a K100 and it's just awesome
overpower and a blast to fly
tommorow testing smoke Systen mounted
using sulivan 40oz tank and sds smoke pump with brushed esc
Old 05-17-2015, 04:47 AM
  #1358
My Feedback: (51)
Guys,
does a standard P-80 fit well in the Xcalibur?
Old 05-17-2015, 05:46 AM
  #1359
Originally Posted by i3dm
Guys,
Yes, perfectly
Old 05-17-2015, 05:47 AM
  #1360
My Feedback: (51)
Originally Posted by mort78
Yes, perfectly
I read Dave's comments about it being too big... any pics?
Old 05-17-2015, 06:04 AM
  #1361
My Feedback: (51)
BTW, for those interested in economy price electric retracts, i have these in my Ultra Flash and they work very well, looks and feel identical to ER40, even the controller is the same:
http://www.ebay.com/itm/90-120C-Full...item20ef02a147
im guessing they would be perfect for the Xcalibur also, after proper fitting.
Old 05-17-2015, 06:53 AM
  #1362
Its too big!
You can hack anything around to fit...but
Old 05-17-2015, 07:02 AM
  #1363
My Feedback: (51)
Its too big!
well, it is what i have spare... so interested in how deep the hacking goes
Old 05-17-2015, 08:32 AM
  #1364
Too far...
What you want is an Xcalibur+
Old 05-17-2015, 12:28 PM
  #1365
My Feedback: (51)
Too far...
hibrido9 (from post #1006) did it with about 150g of lead in the nose... do you see a problem with this setup (although tight)?
Originally Posted by hibrido9
.....but this I am attaching a turbine derived kj66 and is almost identical in size to pieces and jecat p80, is a turbo-jet, construction Switzerland.
Dave, can you take the same picture but without the wide aluminum mounts on the P80?
Old 05-17-2015, 12:38 PM
  #1366
Dave,
I made up my Tank Fiitings today using the recommended Clunk line length of 170mm (170mm tygon length from earlier in this thread).
Looks too short in the tank, what do you think? is it okay or should it be closer to the rear of the tank?
Thanks!
ID:	2096581   Click image for larger version
Old 05-17-2015, 01:05 PM
  #1367
P-80 makes for a heavy Xcalibur. I wouldn't
That's perfect, exactly were my clunk sits.
Dave
Old 05-17-2015, 02:36 PM
  #1368
cmjets's Avatar
My own version of tank for Excalibur ! 3.5L kero + UAT.
regards from Spain
Carlos Marquez
________________________
www.cmjets.blogspot.com
Old 05-18-2015, 02:02 AM
  #1369
Carlos
How much is it with shipping to zip code 34209 in the US
PAUL
regards from Spain
Carlos Marquez
Old 05-19-2015, 04:23 PM
  #1370
Boomerang1's Avatar
I don't own one of these (but I am buddy-boxing a guy with one) and it's a great flying jet ....
BUT!
Are there any factory mods planned for that crappy method of fitting the canopy?
I haven't read all 55 pages of the thread so if the problem has been solved with a simple mod
could you please direct me to it? Thanks.
John.
Old 05-19-2015, 09:41 PM
  #1371
Ricko1's Avatar
Boomerang 1,
Check out post #1146 on page 46. It's not a factory mod but it works for me.
cheers,
Rick
Old 05-19-2015, 10:45 PM
  #1372
BUT!
John.
What's the problem? One tool, 5 seconds!?
Dave
Old 05-19-2015, 11:34 PM
  #1373
Dave,
I've noticed in some of your customer builds on here you use Festo valves for the air fill valve - I know there are two that are very similar devices for the application. One that seals when the tube is unplugged (Plastic boby) and one that is a true non-return valve (Aluminum body on this one).
I'm guessing the true non-return valve is the way to go?
Which do you use / recommend??
Cheers (yet again!)
Old 05-19-2015, 11:51 PM
  #1374
Boomerang1's Avatar
Thanks Ricko, am I correct in assuming the airflow, along with the slight amount of friction on the front
plate hold the canopy back & secure?
That's it in a nutshell Dave, one tool too many, 4 seconds too long.
If Boomerang Jets got it right 15 years ago what's Ripmax's excuse?
John.
Old 05-20-2015, 01:28 AM
  #1375
John
Oh..they didn't! Seen tops come off Boomers and wipe out tails. (The Elan and Torus have one screw also)
The prototype had a clever hatch catch but we changed it to something secure...
I can spare the time, its the same tool that removes the wings, so its in my pocket. I have a shorter screw than supplied, 15mm is perfect.
Dave
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
