Ripmax Xcalibur Sports jet >
Old 06-15-2015, 01:27 AM
  #1401
Originally Posted by Fly Mower
That's what I have! - although all the tubes are new so a little tight. I suspect they will easy off after a while.
Dave, I have been looking at my fuel filter mounting (or lack of ) do you think it will be okay just hanging off the short lenght of tube from the Festo ball valve. I was wondering if movement (G force) may strain the fixing into the ball valve. Should I try and mount it a little firmer??
I had not really looked at the pics. You have an awful lot of joints in the fuel system, I see they are wire locked and it all looks well done, but still something to think about. You could have one joiner on some of the lines you have two.
Yes, the filter will move so another MAP tidy clip on the tank corner will tie that down
Best Regards
Dave
Old 06-15-2015, 04:22 PM
  #1402
Is anyone using a Kevlar fuel cell? If so which one?
Also anyone CG with the Xicoy balancer? What measurement did you use?
Thx!
Steve
Old 06-15-2015, 11:40 PM
  #1403
Stock tank in glass is all you need. The only Kevlar one I know of is mentioned earlier and is huge! Stock tank is big enough.
Dave
Old 06-18-2015, 11:58 PM
  #1404
Good advice from Dave reinforced my own concerns about the number of fuel connections and the ‘floating’ Fuel filter. So I decided to ‘try harder’……..
This time with a custom made reducer in the feed line to the fuel pump to allow me to get from XL Tygon (4.7mm ID) to 4mm Poly. All the fuel lines are now anchored to avoid any movement or strain.
And the JetCat Fuel filter has been relocated onto a bracket fabricated along the lines of that posted by Mark Beacham. It’s near vertical now and hard mounted so hopefully that will suffice.
I’m running out of jobs to do on this model now and excuses to make so I guess I’ll have to try and fly it soon
Cheers,
Lee.
Name:	2015-06-18 15.25.32.jpg
ID:	2103946   Click image for larger version
Name:	2015-06-18 15.26.21.jpg
Old 06-19-2015, 03:53 AM
  #1405
Lee
Much better!
Time to fly now then...
Dave
Old 06-24-2015, 02:43 PM
  #1406
Si_B's Avatar
Just about done. Need to mount turbine and a few little things.
Old 06-24-2015, 11:48 PM
  #1407
Wow Si - That didn't take you very long! Must be the nice comfy indoor building room you have there. I have to work in the garage!
What Turbine you putting in this one?
Lee.
Old 06-25-2015, 12:48 AM
  #1408
Si_B's Avatar
Lee,
Got a Jetmunts 100 going in. Shouldn't take too long to get the blocks glued in and drilled. Need to make a little mount for the jetcat filter. I see how you mounted yours, I assume the fuel pipe is clear of where the carbon tube comes through the fuselage? It's hard to see from the photo, but I think I will look at mounting mine there as well. Shouldn't take long to knock one up.
I took this just before I connected everything up. Hopefully get everything tested before the weekend. Might even get to maiden her.
Most of it will need to come back out as I've forgot to program the brake valve, but it all disconnects in sections so not too much hassle.
Simon
Old 06-25-2015, 03:05 AM
  #1409
Simon,
Same Turbine here.....
Yes the fuel line is completely clear of the carbon tube - In fact the carbon tube is in front of the rear bulkhead. My filter is mounted on the rear of the rear bulkhead. The fuel line drops down from the top and there is loads of space for a good loop without a tight bend radius. I got the idea from Mark Beacham (go back to pages 30-33) and you can clearly see what he has done and how it fits...
Cheers,
Lee.
Old 06-25-2015, 08:39 AM
  #1410
Final CG checks just completed:
8.5Kg (18.7lb) overall weight with with header full and approx 10mm of fuel in the main tank (Jets Munt 100XBLTurbine)
CG at 165mm (just in front of the mounting bolts on the nose side of the rear retracts).
No added weight needed but I have 2*2200 Lipos for the RX and 1*3600 for the ECU.
That will do me for starters....Time to fly....
Old 06-25-2015, 09:22 AM
  #1411
Si_B's Avatar
Looks like I'm going to need a bigger ecu pack in the nose then!!
Old 06-28-2015, 04:32 AM
  #1412
if i remember correctly mine is at 170 mm and flys great
Old 06-28-2015, 04:41 AM
  #1413
Si_B's Avatar
Just ran up turbine in garden. Perfect first run even with the air bubbles making their way through.
Was hoping to fly this weekend but ran out of time for bolting it all together to check cg and set up radio.
What is the general feeling on using crow? Seen a few people using it on this model, just wondered if it actually needs it (never tried it before on my other jets).
Simon
ID:	2106119   Click image for larger version
Old 06-28-2015, 10:51 PM
  #1414
Does not need CROW, but it does have its uses if you fly in some tight spots. I have CROW set on a separate switch so I can use it to add drag/dump lift. I don't use it very often, but I have flown the Xcalibur in some tight places (50m grass strips) and I used it there to nail the strip.
I also have split rudders on another switch (both rudders opening 20mm) This is like an airbrake. Adds to the fun when flying as you can play with the options.
Dave
Old 06-28-2015, 11:05 PM
  #1415
Si_B's Avatar
Might set it up on a different switch and have a play once the maiden is out of the way.
Simon
Old 07-02-2015, 12:38 PM
  #1416
Si_B's Avatar
Balances at roughly 170mm with no extra weight in the nose (give or take a mm). Hopefully weather will play ball on Sunday.
Simon
Old 07-02-2015, 02:24 PM
  #1417
Hi Simon, hope all goes well with the maiden. Perhaps see you at Greenacres or Nye Jets next weekend?
Nev.
Old 07-02-2015, 02:28 PM
  #1418
Si_B's Avatar
Nev,
Will be at the NYE jets on the Sunday, can't do both days unfortunately. Should have the Xcalibur with me hopefully !!
Simon
Old 07-02-2015, 10:42 PM
  #1419
Simon
What did you do with batteries Simon? Stick with the Jets Munt Lipo or add a bigger one to get the 170mm CG?
Cheers,
Lee
Old 07-02-2015, 11:05 PM
  #1420
Si_B's Avatar
Just stuck with the standard lipo which came with the turbine. I have got two jetronic valves tucked under one of the front trays, so I guess that has made a difference. Checked my figures twice and the cg was 170-172 but I have pushed the packs forward a little. I think it will be fine, I've seen a few flying with more rearward cg.
Old 07-02-2015, 11:39 PM
  #1421
So just as a quick double check for me; Did that come out on the front mounting bolt heads of the rear retract? I've measured a million times but you get paranoid about these things!
Old 07-03-2015, 01:14 AM
  #1422
Si_B's Avatar
I'm not sure as I worked it out on the spread sheet using the front edge of the wing by the boom as my reference point from which the 170 measurement is taken. If I get a chance later, I could put her together again and try picking the model up by those rear bolts. Is that where yours is balancing?
Old 07-03-2015, 10:02 AM
  #1423
Si_B's Avatar
Didn't put the wing on so only a rough check but I would say those front mounting bolts are pretty much 170mm back from the outer leading edge of the wing. Might just pick mine up there as a quick double check before I commit to the air.
Simon
Old 07-03-2015, 01:04 PM
  #1424
I'm now a jet flyer The maiden has been completed!
Not the best day weather wise. Although it was hot and sunny the wind was blowing quite hard and at a perfect 90deg to the runway. That’s said, I’d made the trip to field with the intention of the maiden so she was going up whatever!
Take-off (without flaps) was perfect. The model just ran straight as a die down the middle of the runway and with a little elevator she was away. Once in the circuit I was quite a bit out on elevator trim; quite a few ‘up pips’ to get her flying nice and level but thereafter it was great. I don’t think I actually needed any aileron trim at all.
Felt really locked in (despite the wind) and I used the setup outlined in the build manual for throws and Exp and for me it was ideal.
The turbine (Jets Munt 100XBL) ran great. It is clear once I’m ready this will have more than enough power to keep me entertained. In fact I was pretty amazed that most of the flight was at 1/3-1/2 throttle. I had the occasional full throttle moment but only on the up-lines and let’s just say
My first landing approach (full flap) just floated on and on and with a cross-wind I had nothing to hold the model up against; that said she came down okay just not at my feet! And for my first Jet landing I was more than happy!
Just can’t wait to get to the field again…………
And yes Simon; My CG is just in front (3-4mm) of the centre of the rear retract (front) mounting bolt.
Lee.
Old 07-03-2015, 02:18 PM
  #1425
Si_B's Avatar
Congrats chap. My first turbine flight was roughly 2 years ago and I remember how excited (nervous) I was. Will hopefully have some good news on Sunday when mine takes to the air.
Simon
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
