Jeti-duplex-ds-16-2.4-ghz
#3351
Number27,
Just saying to use a sequencer hides the tricks that are needed. Basically, the sequencer takes over the assigned channel, and it can't be used simultaneously with a normal control.
The required steps (that I ended up using) are;
1) Build a sequencer (Advanced Properties/ Sequencer) controlled by the gear retract switch - (Q1 - I called it Autobrake)
2) Assign a function (Model/ Function Assignment) - (I called it Autobrake), controlled by Autobrake sequencer (Q1)
3) Assign Autobrake function to an un-used channel (Model/ Servo Assignment)
4) Mix Autobrake Function to Brake channel (Fine Tuning/ Free Mixes)
Screen-shots attached.
Hope that helps.
Paul
Hope that helps.
Paul
#3352
TKs for all the replies have gone with the sequencer as this was the way I was going but got lost on the programming bit. Will try it out later today. Appreciate the time everyone has taken to reply and upload screenshots.
#3353
The beauty of the Jeti system is that there is more than one way to achieve the same task... I had never thought of a sequencer programming... I have made "two free" mixes activated by the retract switch. The purpose of this break pulse was to prevent "mud" in the wheel wells, as well as preventing a running tires to rub on any wires going through the wells..
Please note that "Sb" switch is the retract switch, also note the "Curve" its a 3 point curve (try to achieve that shape).... finally in picture 1 under "switch +" 1.5 sec is the duration of the pulse break...
David
David
#3354
My Feedback: (35)
Flap Confusion: I have 4 separate servos that are used for four separate flaps. I set the servos up and assigned as normal. I did not adjust any throws. Then I assigned a 3 position switch. The second I did this the servos operated as 0% on position 1, 50% on position 2 and 100% on position 3. I did nothing to cause this.
I set up flight modes for each position of the switch and then set up the flight mode trim to the %'s I want, but they will not override the above described settings.
I have no idea how just setting a 3 position switch to 4 servos is causing them to act they way they are.
Help!
Scott
Help!
Scott
#3355
Help!
Scott
Help!
Scott
I set up a test model with 4 flaps and 2 ailerons to give you a full and complete answer. The flaps were automatically assigned to P5. Go into Functions Assignment and change the Control to your 3-position switch (in my case Sa). The switch will drive -100, 0, +100 by default. Set up the 4 servos mechanically to be in the take off position when the switch is in the middle 0% position though you can use Subtrim (for each servo in Servo Setup) as necessary to adjust the servo control arm position so they are mirrored (left wing servos mirror right wing servos). Go to Servo Setup and to set the flaps up and flaps down travel for each servo by adjusting the Max Positive and Max Negative values.
Note: there are many ways to do things with a Jeti radio. This is how I like to set up the flaps. Personally I find it really easy to do (few steps) and since the flaps are mechanically setup as mirror images, the left wing and right wing flaps move exactly the same throughout the travel. However, if this somehow causes you grief, there are other methods including the use of Functions.
You can add flight modes to the same switch. If you want to slow down the travel, do it in Servo Setup.
Flight Mode Trim is not for throw setup but is for making small adjustments to basic settings in each of the modes. Zero these all out from your current settings. If you've changed the setting to S for flaps in Flight Mode Trim, make sure you zero the values for each flight mode.
Regards,
Jim
#3357
I just set up another A10 with 2 ailerons and 4 flaps, and crow..
We used to set it up the way above. but now we do the following.
Do not assign a switch to the function of Flaps.. Let the butterfly system do it. Clear the switch assignment..
Set the throws to the mechanical limits of the flap
Align the flaps in the takeoff position using sub trim.
Zero out any values in the butterfly
Assign flight modes and butterfly to the same switch
Make sure you have only Check marks next to the switch assignment in butterfly..this is important.. You only want 1 flap setting per flight mode
Set 1.5 sec between flight modes.. zero out all the others.
Now, set the flaps in the butterfly menu.. they will ALL move symmetrically. Then turn off the symmetric function on the bottom of the page and make any fine adjustments needed.
Do this for flaps up and down
You can also add Crow if needed.
I have done a bunch of these.. this is the best way.. the function stays linear, and the flaps move together perfectly... In the case of the A-10, I added .5 sec to the inner flaps, so that the outer flaps move quicker, then the inner flaps, like the real plane.
The key in using flight mode/butterfly combo is clearing out the proportional and playing with reverse in order to get only check marks next to the switch assignment.. In my case I use Sd for it.
There is issues using flight mode trim, function curves, and mechanical stops. they are hard to get them to move at the same rate. Using the Butterfly, EVERYTHING moves at the same rate. Butterfly is really mis labeled.. It should be "flap/aileron system"
Once you do it this way one time, you will like it so much more that you will do it this way going forward.. We have been round and round with Jeti over this, and here we are.
Its a Jeti, so you can do it however you want, but I have found this way to be the best.. If you have 4 ailerons selected, all four will show up in butterfly.. S1-4. The butterfly allows very fine adjustments in the ailerons, flaps, and elevators, and using independent Separate trim mode, it takes almost no time to trim the maiden.
The problem is: its not easy to understand, When I REProgram a guys radio, I often have to undo a bunch of attempts at getting things to line up first.. sometimes I have to start over because it won't do the one thing they need.
Caveat: you need to get the flaps mechanically close to the takeoff position to begin. If they are pretty close at the servo mid position, you are good, even if they are closer to being up for example on some plug and play model.
I don't mean in any way to tell everyone how to do things, but when you learn to use the butterfly and flight modes together, it will make you programming immensely simpler.
When you have the flap function programmed on a switch, and the butter fly on the switch too, they fight each other.. When you use the mechanical stops to set the actual flaps down position they WILL move at different rates. When you use function curve, if you make any changes to the takeoff and landing positions, they might be off a little. If you use flight mode trim mode, you are limited to 50% throw.
#3358
David
David
#3360
Thanks goose
Richard Muller
#3364
My Feedback: (35)
Goose,
I am getting closer. I cleared everything back to as if it were a new plane. I set the take off flap positions using the offset for each servo. I then added the 3 flight modes normal flight (flaps will be up), Take off (flaps will be in take off position) and landing (flaps will be in landing position). I assigned SH a 3 position switch to each mode in a different position. Then I went to butterfly and set it to switch SH. I also set the global setting to S as each mode will have a different % in the butterfly setting. I then placed the switch in the normal flight flaps up position and modified the % in the butterfly setting to make the flaps go up. I also moved the switch to the landing position and modified the % in the butterfly setting to make the flaps go down to the landing position.
I should be finished now, but the switch only moves the flaps to normal and take off. When I put the switch in landing position nothing happens.
What am I missing?
Scott
What am I missing?
Scott
#3365
Hey Scott,
I had the same issue. you may try going into the main butterfly page. flip your switch to the landing position. then select the "control" to enter into the switch position and just hit reverse and accept it. It worked for mine.
rob
rob
#3366
My Feedback: (7)
Goose,
What am I missing?
Scott
What am I missing?
Scott
#3368
My Feedback: (7)
LOG_MAX is a preassigned value that Jeti provides that always valuates to +100% or full ON. The reason it works in this case or the check marks that Goose suggested also work is that they evaluate to 100%. The switch field in the Butterfly mix can be assigned to proportional controls as well and it SCALES the values assigned in the butterfly menu. For example, if you set a value of 40 for the flaps and the switch field evaluates to 100% you get an output value of 40 to the flaps. On the other hand if the switch field evaluates to 50% then that same assigned value of 40 will only output 50% of the value or 20. If the switch field evaluates to 0 there the output will be 0. There are many different combinations of switch assignments that can be assigned to a 3 position switch by playing with the PROP and CENTR function keys but by default PROP give -100,0,+100, Press PROP again and it gives a simply on/off check mark for that one switch position. When Butterfly is flight mode based (Separate instead of Global) with a bit of fiddling you can get a 3 position switch to evaluate to a check mark (ON) for each of the switch positions but I find it rather fiddly to get this assigned to I prefer the LOG_MAX value as it's easy to assign once you understand what it does.
Since I also mentioned that the switch field in Butterfly can be assigned to a proportional control, in that case you would want to assign it to a knob or slider, press the CENTR function key so it shows a range of 0 - 100%. In that case you wouldn't really need flight modes, just set the control to 100% and assign a value that provides the max flaps desired and then as you move the control, as it reduces from 100% (we started with it set to +100% remember) towards 0% the flaps output will reduce accordingly based on the value of the control.
Once you understand what the controls in the Butterfly menu do it becomes pretty simply to use and is very powerful.
I also use LOG_MAX assigned to a sequencer channel to start a 2 second delay every time the transmitter is powered up. I then use that sequencer channel to trigger a Voice announcement to speak the model name so when I power up it will say something like "Skymaster Hawk selected"..
LOG_MAX can be useful any time you need a value that will always evaluate to ON / +100%
Hope this make sense.
#3370
#3371
If you are using flap based flight modes you don't even need to assign an actual switch in Butterfly. The switch SCALES all values in Bufferfly which is why Goose said it needs to be assigned as a check mark, not proportional. A possibly simpler alternative is to assign LOG_MAX to the switch field which always evaluates to 100%. Go to the butterfly menu, select the flight mode and select the switch field and use the logical switch function key to select LOG_MAX.
#3374
In Free mixes you create a mix Rudder to Nose wheel set the percentage of the mix to the amount of travel you like.. you can have different travel for each flight mode.... then in second page of the mix you activate the mix using the retract switch in a way that when the gears are down the mix is activated and you see a check mark.. when the gears are up the mix is deactivated ...
David
