Jeti-duplex-ds-16-2.4-ghz
#1201
My Feedback: (15)
I am still wondering why only the one Rx gets switched to show the CB 200? my mind expects to see both displaying the CB 200...
Is there a way to display frames or dB reading as opposed to a "9" for the antennae? I don't know what the scale is for the antennae, is 9 good, 8 bad? I couldn't find a description so far.
Dave
#1202
Dave... The current software shows the CB200 as linked or attached to one of the R3's.., I don't think you can see antenna strength in DB.. Antenna strength 9 is the highest and scales down to 0 lowest and the you have signal quality which is from 100% to 0%. You can always check your antenna strength A1 and A2 and quality Q in the log file after each flight. The log gets recorded once your timer is turned on ...
Enjoy.
Enjoy.
#1203
Hello everyone,
Many thanks to the guys here and in LA (thanks Dave!),
I am getting the hang of this, it seems pretty darn good. I am assuming that every channel has the same resolution/servo (Function 1 versus 9 or Servo 1 versus 15)?
Also, I have the Jeti transmitter tray for transmitter and it won't fit unless I put the transmitter into it and re-assemble it....??? It seems like it should slide in between the top and bottom pieces but it won't fit..anyone else experiencing the same thing? This is the non-tray- transmitter, with the Jeti tray for this specific tx.
What I did was to carefully cut the foam out of the bottom side of the case. Now my transmitter/tray fits in in one piece.
It takes a little imagination but is doable.
Stan
#1204
Sorry Dave and Stan.. I wish I could help you both with the tray issue... I don't use one... But if you do find out please share here..
Thanks. and enjoy your Jeti system....
#1205
It was a great weekend here, glad you got to enjoy some if it. Flew most of today at our local field. Great day. I still have some things to figure out but it is up and running. Thanks again for all of your time and phone calls.
Dave
Dave
Even with a very weak signal, digital can have good integrity..
#1206
I flown really high using the Cortex in hold to go straight up...
I went to 1870ft and dive back, i had a radio signal of 3 at that altitude with full control!
#1207
Hello.
I have some issues with setting up a Cortex with my DC 16. I have put the on/of to the sj switch.
I have gyro off and gyro normal, but I can't get it in the hold mode.
Gyro off is in center and normal is with the switch pushed forward.
But when I want it to go to hold, it is still in red when I have pulled the switch to the bottom.
I have set the normal at -30 and off at 0 and hold at +40.
Anyone knows what I'm doing wrong here?
#1208
Svein,
Your setup sounds fine but you might want to check a couple of things. Go into Servo Settings and confirm that your output is -30/0/40 when you move the switch. You also should check the receiver/central box port that you are using for the gain to the Cortex. Some ports need to be configured as servo output. The easiest way to check is to plug in a servo to the port and confirm the servo moves when you move the switch.
Regards,
Jim
Regards,
Jim
#1209
My Feedback: (15)
Hi Everyone,
I bought the M450 speed sensor, I didnt realize the accuracy on this is half of the 300, but it still should work well for me.
I plan to mount it in the stbd wing on the Hog in the scale position. I am wondering if it is better to have longer electrical leads to the wing tip or to have longer tubing to allow the sensor to be farther inboard? Pactically, the pitot tuube will go in the wing leading edge and the sensor will either go closer to the wingtip to service through the tip of the wing, or it will go farther inboard (preferred) to someplace that I can fit it through the aileron servo cover.
Either way it is going to be 7-8 feet away from the reciever and will require probably 2 - 48" extensions to reach the receiver. There is no mention of limiting the length of tubing or electrical connectors for installation.
Dave
Dave
#1212
Dave,
OK, so you have to take the sensor signal back to the Central Box. The sensors have an analog signal so the concern would be voltage drop on the long cable and potential interference from sources of electrical noise next to the cable routing. I have an MSPEED installed on the fin of the plane and used all of the tubing that came with the sensor (plus some regular airline tubing) to get the static and dynamic pressure lines up into the component area. You should be fine with the sensor mounted near the wing root where it can plug into a servo extension running from the wing root to the Central Box.
I doubt that you need a 450 in a Hawg. Why not save it for a Bandit/Flash and use the regular MSPEED.
Regards.
Jim
Regards.
Jim
#1214
The longer air lines would not affect the accuracy at steady state (constant airspeed) but would have a slight effect on dynamic response. The sensor operates on pressure so a longer column of air (due to the long air lines) has to be pressurized/depressurized during acceleration/deceleration so the response will be damped slightly.
Jim
Jim
#1217
I found the problem. It is really funny, I could not program a switch on any of my planes. They just work from 0 to + 100, not to -100.I had two new recivers on my shelf and put one of them in my plane and guess what? Now my switches work both ways.The reciver is over two years old and I have never updated it. Mabye it should try to update it. It is the 14 channel reciver.
Any thougts anyone?
Any thougts anyone?
#1219
hello,
What configuration for using a powerbox srs with a R9 and Rsat,
I would also like to have the telemetry with Rsat.
I have tried unsuccessfully over configuration.
#1220
I have an F-86 with 15 channels. I could use an R18 Rx with an rsat, or a CB200 with 2 rsats. I don't need any telemetry sensors. What are the pros and cons of each, which would you recommend and why?
#1222
#1223
Enjoy....
David
#1225
My Feedback: (10)
NY
I would appreciate your input on this:
I have been using PowerBox RRS with dual receivers on all my turbine jets. I recently read that PowerBox SRS will allow serial interface from Jeti receivers through RSat.
Does anyone have actual experience with using it in this way, if so, what are the caveats?
Thanks, Chris
Thanks, Chris
