Jeti-duplex-ds-16-2.4-ghz
#101
Hi HarryC
Take a look at this forum, maybe you will find the answer easily
http://www.rcgroups.com/forums/showthread.php?t=1693301
Surely the US distributor on this thread knows the answer?
#102
My Feedback: (39)
Bob,
I am using the same combination and unfortunately there is an issue with this configuration. The Jeti PPM output signal is not the best, a slight servo jitter is the result. The solution is using the new digital EX bus output which is supported by Powerbox products as well, this combination works flawlessly. The only downside is that the EX bus output is only available at the "Ext" labelled port of the receivers which is otherwise the output to connect your telemetry sensors to.The only way around is using a third receiver that serves for telemetry purposes only. This can be a cheap 3 or 5 channel receiver that costs $65
Thomas
Thomas
#103
My Feedback: (39)
I have some models with 20 servos etc, how do I control them using Jeti? The 18Rx with 2 satellites has 16 outputs, so does the Central box (100 or 200) allow for adding servos, for example input 1 can be mapped to outputs 1 and 2, input 2 mapped to output 3 and 4 and so on, with independent control of centres and travels for each output so that 1 incoming channel can be mapped to 2 aileron servos, 2 flap servos and so on? The Central boxes have a battery input so does that mean that batteries have to be carried for both the Rx and for the Central box?
If using more than 16 servos, I think you won't get around using a Powerbox or similar product that offers more outputs. A cheaper way would be using a combination of the central box and matchboxes for channels 17-20.
Thomas
#104
I've read through the first 200 pages of the 400+ pages in that "other forum" and I don't think the answer is there so that will save you a bit of reading, LOL.
I haven't experimented with a high number of servos (it's high on my to-do list) but I believe the following is correct.
1) The Central Box has two battery inputs (with Multiplex connectors). The receivers do not require their own batteries as they are powered by the PPM (3 wire servo lead) line from the Central Box to the receiver.
2) The Central Box has outputs for 15 servos. All have adjustable end points and midpoints. If you want to connect 20 servos, it won't be enough on it's own
As I said, I haven't tried a setup for a large number of servos or mapping. I suspect that it can be done using, for instance, a R14 or R18 receiver with a second smaller receiver such as an R7 to give you the extra servo ports. Hopefully ZB will jump in here and quickly give you an answer.
Regards,
Jim
#105
Bob,
Thomas
Thomas
There is NO good and bad PPM signal, PPM is digital data stream. It works or it does not. You need to change you setting for the servos go to 20ms it should stop the jitters.
Also incorrect, EXT Bus is Telemetry, if you use 2x receivers with Central Box you are getting telemetry as well. Central Box has 3x telemetry inputs.
Zb/Jeti USA
#106
Cleanest way is to use 2x Central Boxes 200 and 4x receivers. This way you can assign pin to any channels you like. Also you can take advantage Antenna Diversity as well as Dual Redundant Power.
Zb/Jeti USA
Zb/Jeti USA
#107
My Feedback: (39)
Although this is feasible, I think this configuration is less than ideal. A model with 20 servos is most likely an expensive jet, so you want redundancy with two independent receivers. I would either use the central box for servos 1-15 and matchboxes for servos 16-20 or two receivers with a SRS powerbox.
ZB's suggestion is of course also possible, but costs a lot more.
Thomas
#108
My Feedback: (39)
This problem seems to occur only with the bigger receivers, because their internal programming is so complex that it takes a while to compute the PPM signal. That's also the reason why the Europeans use the small RSAT2 for this application, because it does not have that overhang of internal programming. This receiver is unfortunately not available here in the US, but maybe the new 3 channel RX is an option worth trying.
Please don't misunderstand me, I love my Jeti radio, but we should still be honest here that even the most advanced products are not perfect in all aspects.
Sorry to say this but you seem not to know your own products. You are also mixing up terms, there is no EXT bus! I explained that the EXT port of the receiver must be used to connect a Powerbox to the receiver, because only this port delivers the EX bus signal. Furthermore your statement that EX bus is only for telemetry is simply not true! The EX bus is the digital protocol version of the analog PPM signal.
Thomas
#109
Hi Thomas, If I wanted to use a PowerBox Royal SRS and have all the telemetry data would I need three receivers then? Two connected to the PowerBox and the third separate from the PowerBox that has the telemetry connected to it? How do you connect multiple telemetry modules to only one EXT port. I've been thinking of trying this radio with a sport jet in conjunction with Powerbox and a Jets Munt Turbine so I have all the telemetry data. I don't fully understand how this is possible yet, thanks for any help.
Cheers, Alex
The Little Jet Company
Cheers, Alex
#110
My Feedback: (10)
NY
Alex, I have hooked a Jet up just as you are attempting. You need 2 receivers connected to the Powerbox and 1 Telemetry expander (E2 EX) connected to one of the receivers. Telemetry expanders can be daisy-chained together for more sensors. Works great.
Chris
Chris
#111
ahh thanks. If I use this expander E2 or E4 EX this then connects to the receivers EXT port, where do you connect the bus leads for the powerbox SRS? Thanks for the help
Cheers, Alex
Cheers, Alex
#112
My Feedback: (39)
Cheers, Alex
Cheers, Alex
as previously explained, you have to set the Jeti receivers to EX bus output and connect them through the EXT labelled port with the Powerbox, because only this port delivers the digital EX bus signal. This port is unfortunately the same port that you would connect your telemetry equipment to, so that's the reason why you need a thrid receiver. It is also not possible to connect the expander to that port AND obtain the digital signal.
Thomas
#114
My Feedback: (39)
it is obvious that you are somehow affiliated with Jeti USA, so I understand your urge to defend the product, but nevertheless you should only recommend configurations that you have actually used or know work fine for a fact. Please believe me that there are problems with the analog PPM output signal of the Jeti receivers, so using them in combination with Powerbox Systems products is not recommended without using the new EX bus. As stated earlier, this system is sold in the EU since 2011 so lots of other users have tested the same config before and can confirm this.
Thomas
#115
So would two Duplex R6 A40 EX receivers work ok with the PowerBox Royal SRS? I then bind a third receiver and use an expander on that with the four telemetry modules plugged in? When and why would you use the analog PPM port? Sorry for all the questions but I don't want to order one only to discover it won't do what I was expecting which in fact is already the case.
Alex
Alex
#116
My Feedback: (39)
Alex
Alex
since you are located in the UK, you can buy the RSAT2 receivers which are not (yet) available here in the US. Because these receivers don't have all the internal programming to handle like the bigger receivers, their PPM signal is fine. So in your case you connect the PPM out port of the receivers to the Powerbox SRS receiver input and you still have one EXT port per receiver to connect your telemetry equipment to. I you want to use more than two sensors you'll need an expander.
Thomas
#117
Thanks Thomas, looking at the website aren't these receivers designed to complement the EX receivers as satellites? is it ok to use them on their own then as there's no mention on Jeti's site regarding other uses?
#120
Hi Alex
I have been flying and testing/checking out my DS16 with a Powerbox Competition SRS in my F15 for some time now, its hooked up to two Jeti RSats and its working well.
The Rsats have to be connected too 2 of the Powerbox"s 4 "Spektrum" type plug sockets, set to EX-bus then use duel path setting on the Tx.
I have not experimented with any additional telemetry yet other than the built in signal and Rx voltage but could have a tinker this week and see how it goes.
Worst case is you/we would have to use a third Rx or sat to give us another/free telemetry port to plug in the telemetry expander.
I have also tried running these sats and Rxs in PPM mode on a I-Gyro and it simply dose not work very well and gives a very "glitchy" servo response so not recomended.
Most of these questions have been asked and answered on Powerboxes own forum, if not just ask and Richard responds very quickly.
#122
(30 Outputs) Use 2x Central Box 200 + 4x R3/R5/R6 (small receivers) connected to CB 200 via EX Bus
You set Tx in Dual Path and Receivers you set and Master and Clone
BUT:
Master Rx #1 is bound to RF module #1, Slave #1 is bound to RF module #2
Master Rx #2 is bound to RF module #2, Slave #2 is bound to RF module #1
(24 Outputs) Use 2x R14 + 2x R3/R5/R6 (small receivers) connected to each other via EX Bus
BUT:
Zb/Jeti USA
#124
Alex
I don't think you will be disappointed, the Tx is a bit "Marmite" you ether like the way it looks or you don't but no one could criticise it quality and capability's.
Its capability's and versatility is second to none and can only get better as Jeti develop and respond to end user's comments, something ive not seen with other brands of RC
It took a few flights to get a feel for the trims but now it second nature and having the audio telemetry and alerts is a joy.
#125
Actually very simple: This way you will get Antenna Diversity as well as Dual Path Redundancy
BUT:
BUT:
Zb/Jeti USA
BUT:
BUT:
Zb/Jeti USA
Why with the 2 x R14 would I also want 2 x R3-6 rx? Won't 2x R14 give me 24 outputs and 4 aerials and a fully working system?
Can the same linking be done with 2x R10 Ex rx to give 20 outputs? Or 2 x R11?
