Jeti-duplex-ds-16-2.4-ghz
#1451
My Feedback: (162)
I have a mix of rudder to my steering and on the second page of that mix I have used the retract switch to activate that mix... Therefore when the gears are down the mix is active and the rudder (master) moves the steering (slave).. And when I retract my gears up that mix is deactivated so the rudder movement doesn't move the steering
To take it a step further the amount of Rudder to Steering mix is flight mode dependent so during take off flight mode the mix is lower than the regular flight and landing mode (I have to thanks LA jetguy for that)
For your auto trim I would advise that you use a toggle switch for it (safer too). You probably give some correction that throws off your auto trim as you go to switch your switch again to turn the auto switch off.
I actually usually have someone to toggle the switch for me to make sure my stick are absolutely were I want them when the auto trim is deactivated
I'll have to try that. Definately a bit of a learning curve from the 14mz. When using conditions on it I would assign the nose gear to the same control then retract the gear, go into the end points and take them to zero.
Are you saying that each time you select a new flight mode setting that your entire screen changes, not just the display of the selected flight mode at the top of the screen but entirely different screens with different telemetry info displayed, etc???? IF that is the case, I assume you haveaccidentally changed from GLOBAL to SEPARATE in the Timers/Sensors, Displayed Telemetry menu. Go into that and it will most likely show an S in the upper left, click on it and it should change to G.
***THANKS, that was it!
In Functions Assignment I assign to P3 to the Steering servo and P8 it's as trim. I then go to Fine Tuning, Free Mixes and create a mix of Steering to Steering with a value of -100% and assign a switch so that this mix is only active when the gear switch is in the RETRACTED position,
*** That did it!
Don't know how to avoid displaying the trim menu but it's never been a problem for me. I never look awau from my aircraft during flight so I use voice prompts to give me into I need such as flight time remaining, etc..
One other comment, the way your flight modes are configured, you won't be able to select the gear flight mode unless the default flight mode is selected by moving switch D to it's undefined position. I'd personally suggest that you consider removing gear as a flight mode as it's much simpler to simply tie your gear channel to a switch. I normally like to use flight modes for configuring the plane for things like cruise, aerobatics, takeoff, landing, etc but I usually prefer the the gear to be independent from flaps, dual rates, etc..
*** I tried that but I lost the ability to have a separate elevator trim when I raised or lowered the gear?
As for Auto-Trim not finding a nice center, I assume your trim steps were set too coarse if auto trim wasn't working satisfactorily. I find trim steps set to 2 percent is usually Ok but I have a couple of models with really large control surface travel that need it dialed back to 1 percent. To change this go to the Fine Tuning, Digital Trim menu, select the desired control and use the right arow to find "STEP". Auto trim works really nicely with the correct trim steps..
*** That did it!
Thanks for the ideas!
#1452
My Feedback: (7)
"I thought about changing the trim step. I changed it to 4% but didn't notice much difference. Next time I'll go a little higher on it"
Actually, make the trim steps smaller. If you're at 4% change it to 2% per step. I'm assuming that what is happening is you for example. make a minor Aileron correction and it's rolling left, make another correction and now it's rolling right and you can never find the perfect center. If that is the scenario, smaller is better. Auto Trim just takes a bit of getting used to. Just put in whatever stick movements are needed and keep reducing them as the plane gets into better and better trim. Once it's REALLY close, then I'll sometime bump the actual trim buttons but on a Maiden with an airplane that is possibly diving quickly, auto trim is the best!
"*** I tried that but I lost the ability to have a separate elevator trim when I raised or lowered the gear?"
I've never had any elevator trim change when I drop the gear, only when I lower the flaps, still, if you're having that problem then flight modes is a good way to deal it. In that case, you should sort your gear down flight mode to the top of the flight mode list, making it the highest priority. Then, if you flip the gear switch the gear flight mode is selected as expected, regardless of the secondary flight mode switch. As you had it in the screen shots in your previous post, you would only be able to go to the Gear flight mode if the other switch wasn't selecting either of the other, higher priority flight modes. Hope that makes sense..
#1453
Hi All,
Has anyone any experience of setting up the Jetti MFLOw ex with the 16 ds tx,the instructions given give the setting up using the JETIBOX ?
not the 16 Ds Tx.any help would be appreciated.
Regards Ray
Regards Ray
#1454
My Feedback: (162)
Actually, make the trim steps smaller. If you're at 4% change it to 2% per step. I'm assuming that what is happening is you make a minor alieron correction and it's rolling left, make another correction and now it's rolling right and you can never find the perfect center. If that is the scenario, smaller is better. Auto Trim just takes a bit of getting used to. Just put in whatever stick movements are needed and keep reducing them as the plane gets into better and better trim. Once it's REALLY close, then I'll sometime bump the actual trim buttons but on a Maiden with an airplane that is possibly diving quickly, auto trim is the best!
I've never had any elevator trim change when drop the gear, only when I lower the flaps, still, if you're having that problem then flight modes is a good way to deal it. In that case, you should sort your gear down flight mode to the top of the flight mode list, making it the highest priority. Then, if you flip the gear switch the gear does what's expected, regardless of the secondary flight mode switch. As you had it in the screen shots in your previous post, you would only be able to go to the Gear flight mode if the other switch wasn't selecting either of the other, higher priority flight modes. Hope that makes sense..
I had had the gear to the top but it blanked the flap trim so I moved it to the bottom as the flap trim is more important.
i took the JetI to the field yesterday along with my new receivers to range test them and make sure everything works before installing in my jet
#1455
My Feedback: (7)
As for the gear flight mode overriding the flap trim you can still trim the flaps in the gear mode using the flight mode trim but you will need to have separate flight modes for each combination of flaps and gear which is the down side of having the gear as a flight mode. With them at the bottom as they are, you can never get to the gear flight mode with the flaps deployed by the other higher priority flight modes.
#1458
Hi Guys.
I have had my DS 16 for about 6 weeks now and have started transferring my models over from my 12X, I am lucky to have a mate here to help me but I can't get him today and I thought I would put this here as some of you guys might be interested. I have my flight modes on SA and what I want to do is have take off to the back cruise in the centre and landing forward I know how to do it with my 12X but I am stumped with my Jeti. There was a question asked what the transition from the 12X is like, ounce you get your head around the fact that your JR is history and you can't think in those terms any longer it becomes very easy but there are a few things the book doesn't explain very clearly how to load your sound files for one and a couple of other things but no different or harder than any other radio and I love the feel of it.
Cheers
Mav
Cheers
Mav
#1459
The thing to remember is the switch position needs to move TO the target position for twhat you want when you set the switch. So for a three position switch, put the switch in the MIDDLE, then go to assign action for the UP position, go to the switch select dialog and flip the switch UP. Leave it there. Go to assign the action for the MIDDLE position, get to the switch select dialog and flip the three position switch to the MIDDLE. Leave it there and go to set up the action for the DOWN position, get to the switch select dialog and flip the three position switch to the DOWN position. You've now assigned an action for all three positions of the switch. (From PVogel)
#1460
Hi Putt.
What I would like to do is have the switch (sa) to the back with take off flaps pull to the centre for cruise (flaps up) full forward for landing full flaps down, dose that make sense ??. I used to have the switch back for cruise centre for take off and forward for landing, but that way the switch is going backward and forward, not sure if it can be done this way.
Cheers
Mav
Cheers
Mav
#1461
My Feedback: (7)
Hi Putt.
Cheers
Mav
Cheers
Mav
#1462
Mavrick, which ever order, you want your flight mode in, you can assign them to the switch position that you want to have. It is all a matter of personal preference.
Do you have problem assigning the position of the switch? Remember to move the switch from an other position towards the position that you want in order to assign that flight mode to it. Then procede to the next flight mode following the same pattern.
#1463
I asked Jeti a question about the antenna voice announce and their reply is interesting so I think it is worth sharing.
If you have an Rx with rsat, or a CB with two rsats, you have 4 antennae. If you go to the voice announce menu, it only offers you antenna 1 and antenna 2, not antenna 3 and antenna 4. I asked Jeti why 3 and 4 are missing and their reply is -
" the Voice announcement announces the lowest value of the receiver's antenna
Something like this:
if (rx1Antenna1 < rx2Antenna1) announce rx1Antenna1 else announce rx2Antenna1
Similar with antenna 2."
What that means is it announces the lowest antenna 1 value of either Rx and the lowest antenna 2 value of either Rx. That is not the same as the lowest 2 values, since if the Rx 1 values are 2 and 5 and the Rx2 values are 3 and 6, the announcement will be 2 and 5, not 2 and 3.
#1464
Since there was a few questions as to how to achieve a a retract to steering mix with deactivation of the steering upon retraction, I did a little how to here:
http://www.rcgroups.com/forums/showt...7#post30492158
Feel free to add and improve
Sharing is the key to enjoying this system at its best. Kudos to LaJetguy for leading my way on this
#1465
Harry I know what you mean.
I had an instance yesterday installing my Demon with my Jeti absolute dead easy until you put the last input for the N/W steering the LED would go nuts I thought the end points were to short or I was doing something wrong, (won't be needing a hair cut for a while) it turned out it was the end of the programing but nowhere in the instuctions did it say this is what happens. I think this must be how they get there kicks.
Cheers
Mav
Cheers
Mav
#1466
Let me know if you or anyone is interested in a small programming I recently created... Which applies a "pulse" of brakes when the gears are retracted up. This will stop,the gyroscopic effect of large tires, as well as preventing the spinning tires entering wheel wells which could possible rub on air lines or brake lines...
The fun never stops with the best system on the market...
Enjoy...
#1467
"Let me know if you or anyone is interested in a small programming I recently created... Which applies a "pulse" of brakes when the gears are retracted up. This will stop,the gyroscopic effect of large tires, as well as preventing the spinning tires entering wheel wells which could possible rub on air lines or brake lines..."
Yes please - This is the kind of really useful stuff that aught to find its way into the Jeti manual in the 'examples' section.
Thanks to PuttPutt and LA Guy
Bob
Bob
#1468
I've added my steering program to the list http://www.rcgroups.com/forums/showt...7#post30492158
LA Jetguy, yes your brake pulse program will be good to see please
#1469
La Jetguy would love to see your pulse brake programming.
HarryC thanks for your programming, I had seen it before but for some reason I could not get it to work. I will have to have a look again.
Many ways to skin a cat with this system and it is always nice to see simpler ways to do it.
#1470
I have just replied to your query about steering sensitivity on the rcgroups thread.
#1471
Take advantage of weak Euro, we extended our Christmas Promotion and get $200.00 Gift Certificate for Jeti DS-16, DS-16 Carbon and DC-16 Carbon Radios.
Zb/Esprit Model
http://www.espritmodel.com/jeti-dupl...o-systems.aspx
Zb/Esprit Model
#1472
I have created a simple program using two mixes (Free Mixes) to apply a short pulse (1.5s) of brakes to the tires when the gears are retracted. This will prevent spinning tires entering the wheel wells:
Free Mix #1
Brake to Brake.... 100% value
Use switch "Sb" (or your retract switch) to activate the mix.. that is you will get a "check mark" when the gears are retracted
Go to the Mixer Curve and change to "3-point" curve the "+" and "-" is important
Point 1 In -100% and Out 0%
Point 2 In 0% and Out 0%
Point 3 In 100% and Out -100%
Free Mix #2
Under Delay (row) and Switch (column) under (+) change 0.0s to 1.5s.... (this is the length of "pulse" you want to apply)
Point 3 In 100% and Out 100%
I know I can take screen shots using switches, but I used my phone to take screen pictures.... Im sure Puttputt will make a better presentation and post it in the "how to" section
Enjoy your Jeti system....
David
Free Mix #1
Free Mix #2
David
#1473
Very nice and creative LA jetguy. Thanks for sharing this.
Nothing wrong with iPhone pictures, I just go through the trouble of screenshots to make my own little manual for the workbench. The ''how to section'' now is starting to be a favorite of mine on my iPad. It takes less room on my already crowded work space of 4X8 quickly turning into a 1X1, if you know what I mean.
#1475
My Feedback: (7)
David, I like your brake pulse implementation. Thinking about it further, if you are using a ds16 sequencer to control your gear and doors, couldn't you simply add the brakes and give a pulse before raising the gear and have the sequencer only pulse as the gear is being raised?. The gear and door sequences would be symmetrical.. I don't have my ds16 handy so I haven't tried it yet though. Can you think of any reason it wouldn't work?
