Reload this Page >
Jeti-duplex-ds-16-2.4-ghz
Old 01-24-2015, 03:24 PM
  #1501
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by Jeti USA View Post
Actually it will be even better, we will be selling REX receivers in two configurations. But even the basic one will have all the extra hardware installed, that Assist has but disabled. You can buy basic REX 7/10/12 receiver (Much Cheaper) and later if you want to update firmware for nominal fee to support full stabilization and extra sensors (Vario, G-Force...).
Zb/Jeti USA
Well I like this a lot more......I would take everything but the assist
Old 01-25-2015, 03:00 AM
  #1502
Mark Vandervelden
Mark Vandervelden's Avatar
NEW Tx FROM JETI THE DC24
For those whom like tray styleTXs Jeti,s first own Tx was the DC16. It was quickly followed by a hand held version DS16, both I believe share the same software.
Well now it would seem "as seen on FB" there is a proposed new Jeti Tx on it way, the DC24. So I'm guessing its likely there's going to be a new version of our DS16 with a DS24 version ?
Now even if a new DS24 Tx were in the same case as our currant DS16 but with updated software we could be looking at an extra 8chs to play with
Old 01-27-2015, 07:46 AM
  #1503
Puttputt maru
Speaking of new stuff this is not really Jeti but an indication technology having no limits so far.This little gizmo has cruise control for your jets among other things.
Anyone using it?
http://www.ultimate-jets.net/product...en-assi-module
Old 01-27-2015, 10:27 AM
  #1504
Dansy
My Feedback: (53)
Dansy's Avatar
Anyone using it?
From what I'm reading on there's site it isn't compatible with Jeti....?
Old 01-27-2015, 01:23 PM
  #1505
Jeti USA
[h=2]Jeti Duplex DC-24 2.4GHz Radio System with Color Display and Dual Haptic Feedback!!![/h]
Old 01-27-2015, 01:56 PM
  #1506
Dansy
My Feedback: (53)
Dansy's Avatar
Haptic feedback?
Old 01-27-2015, 03:22 PM
  #1507
Puttputt maru
Originally Posted by Dansy View Post
Haptic feedback?
is a tactile feedback technology which recreates the sense of touch by applying forces, vibrations, or motions to the user (Wikipedia)
So I guess it will have vibration alarm
Old 01-27-2015, 03:46 PM
  #1508
Puttputt maru
I am trying to stream line my flight modes for my jets.
I am always hesitant to include flaps and retracts in flight modes so I have them all on separate switches.
Can you guys give me an idea of what you usually use and what you include in your flight modes with the Jeti Tx?
Old 01-27-2015, 03:48 PM
  #1509
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
I would assume that it will provide feed back through the joy sticks, i.e. give you real time feedback of the feel of the model
Old 01-27-2015, 04:38 PM
  #1510
ZB
Each stick has its own vibration, try imagine the posibilities. You can have stall speed alarms or fuel alarms.
Here is another one, with upcoming G-Force sensor you can have haptic feedback, if you are approaching top speed.
Zb/Jeti USA
Old 01-28-2015, 02:05 AM
  #1511
JohnMac
JohnMac's Avatar
On most of my jets I se 3 flight modes,take off, cruise and landing. I slave the gear, flaps, steering and brakes to these modes.However for he first few flights I do the gear and flaps (slats too were applicable) manually until I am happy with the setup.
John
Old 01-28-2015, 04:54 AM
  #1512
Puttputt maru
John
Thanks John
Old 01-28-2015, 06:08 AM
  #1513
wfield0455
My Feedback: (7)
wfield0455's Avatar
I've been going through this exercise myself. In the past I've had a single switch for Dual Rates/Expo, 1 for landing gear and one for flaps. After thinking about how I could reduce switch flipping I've come up with the following that seems Ok to me. I use a 3 position switch and configure flight modes for cruise, half flaps and full flaps. I also use tflight modes to set dual rates and expos that I feel are suitable for each mode. I basically have the the first switch position as cruise with no flaps, the next as half flaps and the 3rd as full flaps. Since I tend to set half flaps on the down wind leg of a landing approach and select full after turning onto final, assuming I want to land with full flaps, I wanted to avoid having to jump across switch positions to get to a different flaps position. I've seen guys put cruise in the center and half one way and full the other but I didn't like that as I wanted to avoid flipping through cruise mode to get from half to full flaps. I also don't want the gear on the flight mode as I will often land with no flaps in high wind / cross wind situations so I have a separate gear switch.. Still not 100% sure if I want to continue with with flaps controlled by flight modes as for some planes I would like to have an additional mode with higher rates and different expo for aerobatics. In that case, it seems best to have separate flaps, gear and rate switches. I still haven't come up with something that I think will be ideal for all my jets yet but I would like to settle on a single scheme so my controls are always the same for every model. This is a subject that I think could be worth having a thread of it's own..
Old 01-28-2015, 07:34 AM
  #1514
afterburner
My Feedback: (18)
afterburner's Avatar
This radio could get me to jump ship if my current radio manufacturer doesn't come out with some useful updates.
Old 01-28-2015, 08:07 AM
  #1515
Dansy
My Feedback: (53)
Dansy's Avatar
If i didn't already have 2 DC-16 Carbon....ya for sure but....I do!
Old 01-28-2015, 08:14 AM
  #1516
Puttputt maru
Do I hear: Man overboard LOL
Old 01-28-2015, 08:19 AM
  #1517
Puttputt maru
This is pretty much my conendrum especially flying both 3D aerobatic and jets. I am looking at a way to actually have just 3 flight modes for Jets: take off, cruise and landing that will be on a 3 position switch but setting up more modes on an other switch that will give me the possibility to override them for specific situations: in case of high wind to have less flaps for example.
With the flexibility of the system it would be possible. My idea is to have one switch for 95% of the situations and an other for the other 5%.
Old 01-29-2015, 05:52 AM
  #1518
afterburner
My Feedback: (18)
Yeah, the water is still with inactivity and customer requested updates seem to fall on deaf ears.
Old 01-29-2015, 06:19 AM
  #1519
George
My Feedback: (57)
There is thread like this already floating around, but I do not remember the title and it's been a few months. I'll see if I can did it up.
EDIT:
It may or may not be what you're looking for, but this is the thread I was thinking about.
http://www.rcuniverse.com/forum/rc-j...signments.html
Old 01-29-2015, 07:10 AM
  #1520
Puttputt maru
EDIT:
Thanks for the link it was an interesting read, helpful in other ways. Always great to have other RC flyer perspective and reasoning behind it.
By the way this is not Jeti but I think this is a product that I just discovered in the Jet International magazine and ordered immediately. I have been using Jersey modellers tanks and electric pump for years now and enjoy them and this look like a winner too.
http://www.jerseymodeler.com/id29.html
It is not very well explained on the web site but it is a filler valve system with a quarter turn to engage and disengage very leak proof (according to RC Jet Int.) and what I really like, with an overflow, quarter turn too, plug for transport with a neat ''remove before flight' flag. Have a look
Old 01-29-2015, 12:34 PM
  #1521
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Go ahead Marty... jump in ...the water is fine... LOL
I now have a DS-16
Old 01-29-2015, 12:40 PM
  #1522
Jedei120
Jump on in the water is certainly fine.....
Old 01-29-2015, 06:21 PM
  #1523
Helijet
Need some help..
I have the Mbar hooked up to my retract air input line. I am using a separate 3 channel receiver with the jetibox profi that my spotter will be able to use inflight.
I have the kPa coming up but I am unable to get an alarm assigned to the sensor.
Any suggestions on a) switching to psi and b) getting a min/max alarm set up on the box??
thanks
Dean
Old 01-29-2015, 07:37 PM
  #1524
afterburner
My Feedback: (18)
I now have a DS-16
I'll have to fondle the DS-24 before jumping in. Maybe I'll get to see the DC at First in Flight or more likely at Kentucky.
Old 01-30-2015, 11:27 AM
  #1525
Jeti USA
We just tested DPSI 2018 with Jeti, this thing works like a Swiss clock.
You can see up to 15 different sets of telemetry data on Jeti Tx Screen.
Get up to 36 servos from distribution box with dual receivers and dual input batteries.
Use S.Bus or Standard PWM outputs anywhere on the power line.
Zb/Jeti USA
Emcotec DPSI 2018 Power & Signal Distribution Unit
Dual power supply which converts the M signals of five popular receiver systems to S. Bus and PWM signals. The system offers the possibility to connect up to 36 servo motors.
With the S. Bus system, several servo motors can be connected to the DPSI 2018 with just one single S. Bus cable. Consequently, there is only one cable that needs to be run through the fuselage to the tail and two additional cables to connect the wings.
The servo motors can be connected to the S. Bus cable at the very spot where they are needed using special S. Bus terminal blocks. Each servo motor can be addressed via its own unique identifier.
Programming:
The connected S. Bus servo motors can be programmed - e.g. using a laptop - directly via the receiver input of the DPSI 2018.
Channel set-up, pulse width, rotation direction and delay between pulses etc. can be conveniently adjusted using the computer software.
With S. Bus terminal blocks that have a special PWM adapter, even conventional servo motors can be connected to an S. Bus cable. In this case the terminal blocks are addressed and programmed via an own unique identifier not the S. Bus servos.
Compatible Transmitter Systems:
At the moment, the new dual power supply DPSI 2018 can be used with five popular receiver systems:
- Futaba S. Bus / S. Bus 2
- Spektrum DSM2 / DSMX
- Multiplex M-Link
- Graupner/SJ HOTT
- Jeti duplex PPM / EX Bus
- JR sum signal
Name:	DPSI 2018  Spodek.JPG
ID:	2069155   Click image for larger version
Name:	DPSI 2018 #2 det na spodek 2018.JPG
