Reload this Page >
Jeti-duplex-ds-16-2.4-ghz
Old 12-03-2013, 07:34 PM
  #151
speed is life
speed is life's Avatar
Good bye Weatronics........Hello Jeti.
I'm now on board as well, have a DS-16 + several receivers on the way from Zb @ Esprit.
Jeti = Extensive telemetry, customer service, availability of English language voice files,.....
(delayed BAT60, again).....sorry Wea, you snooze you lose.
Many thanks to Jeti rep Jim McEwen at the AZ Jet Rally, he sold me!
-Mike
Old 12-03-2013, 07:56 PM
  #152
xxspeed
Question, when I power up my Jeti the LCD display show as the picture in the right (the last plane used), and when I have the charger connected I see the picture in the left for about 5 sec. In one of the on line videos I was watching the transmitter power up like the one pictured on the left. What I would like to do is have the power up as the picture on the left. The software is version 2.01, I know there a new one available. I can fine any setting to change that, any help would be appreciated, Thanks xxspeed.
ID:	1944575   Click image for larger version
Old 12-03-2013, 11:36 PM
  #153
LA jetguy
LA jetguy's Avatar
Go to System-->Configuration->scroll down to "Disable startup question" and change the "yes" to "NO"... Upgrade to firmware 2.22 and enjoy watching the snowflakes before pressing yes... You will notice them!!!!
Don't forget to backup before upgrading....
Old 12-04-2013, 03:28 AM
  #154
HarryC
I really have no need for the gyros etc inside the Tx and don't want to pay the extra for them. Is Jeti planning to sell a DS without them, for the lower price of the DC which doesn't have them? DC is 200 cheaper than DS
Old 12-04-2013, 04:39 AM
  #155
xxspeed
Thanks Ill do it tonight.
Old 12-04-2013, 07:21 AM
  #156
bluelevel
My Feedback: (39)
bluelevel's Avatar
Harry,
what you are looking for has already been announced, there will we a DS-14 coming out in a few months. See http://blog.espritmodel.com/the-stor...ystem-1090-00/
Thomas
Old 12-04-2013, 08:19 AM
  #157
HarryC
Originally Posted by bluelevel View Post
Harry,
Thomas
That's interesting, thanks Thomas. Unfortunately the number of channels and other features is going the wrong way! I want a full DS 16 but without the gyros/accelerometers, as per the DC16.
Old 12-04-2013, 10:05 AM
  #158
gooseF22
gooseF22's Avatar
Don't forget that it will be 14 command functions that can be mapped to many servos/outputs, so it can drive multiple outputs and 2+ receivers that can be set up..
I also want to point out that a DX18 is really a 10-12 chan system with add on functionality via expansion box getting 18, but the expansion box is slower 512.. and you cannot map servo function in the RX... W Jeti, you can do whatever you want within the receiver...
Old 12-04-2013, 10:17 AM
  #159
ash 26
With the new Multiplex Profi TX that is now out we have 16 fully proportional channels and all the Powerbox equipment works with it this is one of the reasons that I will stay with Multiplex
Old 12-04-2013, 10:43 AM
  #160
Jeti USA
With Jeti you have 32 channels, 16 full + 16 additional wireless commands coming very soon.
Wireless Commands can be pretty much 1x signal outputs (Gear down....) or commands like clear Data Logging from your Central Box Unit. (Sorry :-))
Zb/Jeti USA
Old 12-04-2013, 11:33 AM
  #161
Mark Vandervelden
Mark Vandervelden's Avatar
Hi all
Do we get carried away with how many channels we think we need?, surly for most of us even with the most complicated of airframes how often do we actually uses 14 let alone 16 or more channels?
Throt = 1
Eile = 1 prob 2ch
Aile = 1 prob 2ch
Rudd = 1 pos 2ch
Flap = 1
Nose wheel = 1ch
Gear = 1ch
Brake = 1ch
Air Brake =1ch
Lights = 1ch
Smoke =1ch
The list above seems to me like a fairly comprehensive airframe and even using 1 command channel per surface or function it still only adds up to just the 14ch.
Add this to Jetis RXs ability to trim and adjust any number of output/socket independently from the Tx allows functions like duel flaps or twin rudders to be operated from a single command function.
Thoughts any one, I'm sure some of you will have other function's I have not thought of
Old 12-04-2013, 11:34 AM
  #162
bluelevel
My Feedback: (39)
bluelevel's Avatar
This discussion seems to be turning into a pi**ing contest
Old 12-04-2013, 11:38 AM
  #163
Mark Vandervelden
Hi "Jeti USA"
Can you elaborate on "16 additional wireless commands coming very soon" what exactly can we hope to do with extras
Old 12-04-2013, 11:43 AM
  #164
gooseF22
gooseF22's Avatar
I have a couple of technical q's
I know the receivers are interchangeable for redundancy/diversity
1. If you have a CentralBox 200, What, if any, is the technical advantage of using the R3 Sats for primary SAT over the R5L or for that matter any other Rx? the R5L is the same price as the R3... Is there better frame rate consistency? Is there more ExtTelemetry functions?.. Are either able to use external channel while set up for PPM output? I realize the R3 can be used as a switch, but Im more interested in any technical advantage of one Sat setup over the other
2. If you are using a R14 or R18 plus a satellite, is there any advantage to using an R3 over a R5L for Sat redundancy?
thanks..goose
Old 12-04-2013, 11:49 AM
  #165
ash 26
Hi Mark
I totally agree with you 16 ch is more than any of us will ever need the only point I was trying to make is that Multiplex works with all the PowerBox equipment straight off with no issues and it is very straight forward to run a dual receiver diversity system
cheers
Andy
Old 12-04-2013, 11:51 AM
  #166
bluelevel
My Feedback: (39)
bluelevel's Avatar
thanks..goose
Goose,
if using two receivers in combination with the Central box, there will be no difference, because the Central Box communicates with the RX's through the digital EX Bus protocol. If it were the old analog PPM signal, only then it might matter. Your telemetry equipment will be connected to the Central box anyway, so there is no more or less telemetry ports.
Regarding your second question I also think that there is no difference between the R3 or and R5L regarding its reception capabilities. The technical specs are identical. On the paper even the specs of the R14 / R18 are the same as the smaller receivers, but unter difficult conditions you should see a little advantage with the bigger receivers because their antennas are shielded. But I think it would be overkill to use two R14's or two R18's.
Thomas
Old 12-04-2013, 11:58 AM
  #167
Mark Vandervelden
Hi Andy
Yes I seem to remember running all my airframes on as little as 8chs not so very long ago but did have to get inventive at times.
Jeti dose work with all the Powerbox equipment ? and on its all its primary "full" 16chs in its EX-Bus mode.
All TXs have there strengths and weaknesses, so far I'm very pleased with my choice
Old 12-04-2013, 11:59 AM
  #168
speed is life
Hi Mark
cheers
Andy
A non-issue for the USA........Multiplex is "dead as a door nail" here. Not FCC certified, not imported.
Old 12-04-2013, 12:30 PM
  #169
Jeti USA
Originally Posted by Mark Vandervelden View Post
Hi "Jeti USA"
Copy from different forum:
Good news is that DS/DC-16 radio systems very soon will be DS-32, we will have 16x "additional remote commands". System will be able to control additional 16 devices/functions. Those can be simple functions like turning lights ON/OFF, Gear UP/Down or resetting Central Box Data Log.
This addition will not effect the data stream or latency. The remote command is one time command that Tx will send to Rx and wait for Rx confirmation, it's only executed once.
Zb/Jeti USA
Old 12-04-2013, 12:39 PM
  #170
Jeti USA
thanks..goose
1) No advantage, all receivers are Full Range and have all functionality. Only advantage with R3 is Wireless Switch Fumction and Hard Case
2) Same as #1
Zb/Jeti USA
Old 12-04-2013, 08:00 PM
  #171
DrV
DrV's Avatar
Zb/Jeti USA
in other words, are they non proportional off/on channels?
Old 12-05-2013, 02:16 AM
  #172
HarryC
Hi all
Throt = 1
Eile = 1 prob 2ch
Aile = 1 prob 2ch
Rudd = 1 pos 2ch
Flap = 1
Nose wheel = 1ch
Gear = 1ch
Brake = 1ch
Air Brake =1ch
Lights = 1ch
Smoke =1ch
Lots more! My EE Lightning has 20 devices and I could fit more yet. One of my F-86 has 18 devices. They don't all need individual Tx channels but it is best if they each have their own output at the Rx in a programmable Rx so that for instance one Tx flap channel can be mapped to two Rx outputs which is what I do at the moment with Weatronic. It seems that Jeti can do similar. Systems that don't have programmable Rx need Tx channels or y leads. That's why I have been asking questions about how a Jeti system with max 16 outputs on the 18ch rx with rsats, could expand up to dealing with 20 devices. It's not clear from jeti's website how I could link up Rx etc and expand the system.
Old 12-05-2013, 06:56 AM
  #173
Jeti USA
No, fully proportional. They are just not part of the standard data stream, otherwise you latency would be huge, transmit 32 ch. takes time.
Zb/Jeti USA
Old 12-05-2013, 02:26 PM
  #174
gooseF22
gooseF22's Avatar
So if I understand this. We have 2 tx modules. So you can bind one to the #1 tx module in normal mode and the other to #2 tx module in normal mode and link sat receiver to the main by plugging from the sat rx ppm designated servo port into the Sat input on main rx.
In this scenario, what does it take for the sat rx to take over? Complete loss of main sig? Or is it an algorithm based on sig dBM or?
Ie how does degradation work?
Old 12-05-2013, 08:31 PM
  #175
bluelevel
My Feedback: (39)
bluelevel's Avatar
In this scenario, what does it take for the sat rx to take over? Complete loss of main sig? Or is it an algorithm based on sig dBM or? Ie how does degradation work?
Goose,
my information is that both RF links to the master receivers are always active and are used alternately regardless of their signal strength. The satellite receivers only come into play if the corresponding master does not receive a valid signal.
Thomas
