Rennovation project, Yellow FA18 Twin. Answers and parts appreciated ;)
#76
Take one of the scissor screw out. Be careful as you can strip the head easy if you don't have the correct screw driver. Don't swap the main springs out though. They should remain soft so the gear almost bottoms when sitting static with fuel. You should only have a half an inch of travel left and it should be stiff. If you use stiff main springs, the plane will wallow side to side really bad. You want them to feel bottomed out so the plane is solid.
Guys on my Twin when I have no fuel in the plane (batteries mines electric) I have a nice AOA for take off... when I install the packs the plane sits level.
I've read a few guys have replaced the soft nose gear spring with something stiffer, but I can't see how it come apart.
Have any of you guys taking apart the nose gear and replaced the front spring?
Thanks much, hope mini flyer doesn't mine me asking a few questions in his thread
#78
I have had a looong love affair with this kit, got a good semi built model, and working on it now...undergoing modification work on the fuselage and formers since it was one of the earlier models... twin merlin 100s
Miniflyer will be following your thread for sure...and keeping tabs on those composite wings!!
#80
My Feedback: (22)
#81
OK, airshow season is coming back and i'm hoping pulling this thread will have the same effect as starting a new one.
I still have not managed to get any gear placard details on the hornet and was wondering if anyone will be at an airshow where you can get up close to a hornet and snap some shots for me....
Thanks guys
Hank
Thanks guys
Hank
#82
Hi guys,
i just got in contact with charles, and he can supply me with everything EXCEPT a rear canopy frame. Does anyone still have one lying around he is willing to get rid of, or knows someone who might still have spare parts?
Very many thanks
Hank
Very many thanks
Hank
#84
SC
Interested in your thread. Hoping to take possession of an older YA FA18 twin that will be converted to single turbine. I've done some searching but can't find a manual for it. Really interested in CG and throws. If anybody has a link that would be great.
