ESM Pilatus PC 21
CT
Has anyone had the opportunity to inspect the subject PC21? Wren has a nice turbo prop engine that fits the PC 21 like a glove. I trust the Wren engine but I don't know much about the ESM ARF. The package looks like a good candidate for our 400 foot grass club field.
Guy in my club had one, beautiful finish & a great flyer with the Wren 44 turboprop.
My field is short grass.
It met it's demise when it stalled on the landing approach & dropped a wing sharply
with no height to recover. The approach was VERY slow, you could predict the result.
Don't know if CG or setup was a factor, just keep in mind they will bite if flown too slow.
John.
John.
You could contact Skymaster and ask when their PC 21 is going to be ready. In the videos they have, it looks like a very nice model and flyer ( for still being a prototype.....)
http://v.youku.com/v_show/id_XNTY3NDA3NTIw.html?x
rob.
CT
The Skymaster candidate looks good from what I can get from the video. Typically Skymaster planes are rather large. Any info out there on length and wingspan? I couldn't find any dimensions but some times I can't find my truck keys either so read what you may into that. a Wren 44 turbo prop is what I want for power. The ESM model is going to be a tight fit in the back of my truck.
I had one too. A great performer, very F3A-looking hence great flying. As mentioned the elevator setup needs to be changed to dual servos and the retracts sold by ESM are junk, so go for something else. I setup mine with a fairly low power motor and it did well, a friend shuffed in a motor that puts out about the same power as the Wren. Still did well.
http://www.youtube.com/watch?v=cjRPe_8NNjA
CT
There was mention in another thread that the ESM version wing needed strengthening if I'm going to put the Wren 44 Turbo prop in it. What's the consensus on that and what sort of strengthening is needed? A carbon fiber center section tube and mating sleeve I can do but I don't want to have to rebuild the wing. Also, it's clear to me via photos, that the wing is fabric covered open bay on the bottom. The top surface looks to be sheeted. Correct?
HI all, I'm new to RCU and my actual first post... But not new to RC. I've been researching the threads here on the ESM Pilatus PC-21 and just ordered one from TBM. I'm going run mine electric.. It's my first venture into larger scale electric. My question is: TBM said that the ESM v3 retracts are no longer being offered due to continued issues. They are coming out with a newer air version, but looks like they won't see them here in the US for 6-8 weeks. Does anyone have suggestions on retracts and wheels I could substitute for the ESM's that would fit and still give the "semi-scale" look their electrics had?
CT
My Pilatus PC21 is also on it's way to my shop. I spoke at length with TBM regarding the gear and got the same story that the ESM retracts are no longer available. Century Jets has been contracted to make the gear for the PC21. I spoke to Century Jets and was told that they should have retracts as early as 3/24/14. From the conversation it sounds like we will have an option to have them electric or air operated. The price was not available at the time but if you compare prices for other tri gear retract sets for planes of similar size, I would estimate $500 ish for the air operated system. About $100 more for the electrics??? That includes the control module that you plug into the Rx. Consider the air system that you'll need for the air retracts and it's probably a wash. Power for my PC21 will be a Wren 44 Turbo prop. Also on order. There is something about the whine of electric power that turns me off and a recip is totally wrong.
CT
I could watch that video all day with the sound turned up so I can hear that beautiful turboprop sing. Mine is now in my shop and I'm just starting the mods to install the Wren. The engine is still a few weeks away but I got a mount template from Ron Ballard at Wren USA and set up to cut the firewall. It requires an 85mm hole to accept the turboprop engine. In looking for a way to cut the hole neatly I found that Dremel has a nice hole cutter. Well worth the $13 that I payed for it. The hole is picture perfect. However I ran into a problem when I began installing the mount template onto the firewall. The factory marked horizontal thrust line on the firewall was mislocated. It was 3/4" to high making the cutout for the engine near the top of the firewall. I have been using Paul Hardmans build thread ( YT INTERNATIONAL / ESM PC21 ) on RCU as a guide and his photo of the firewall cutout showed it well below where the factory guidelines were. So what to do!! I knew that the prop shaft hole and the spinner flange on the cowl had to be centered on the engine axis. I located and marked the center lines at the front flange and seated the cowl on the fuselage making sure it was properly seated, rotated and faired into the top line of the fuselage. Then I used my laser to project the horizontal and vertical thrust lines from the cowl to the firewall. Worked like a charm. Now it looked like Paul Hardmans photo. The Dremel Circle Cutter worked beautifully.
Here is my PC-21 with turbo prop style exhaust.
very noisy
https://www.youtube.com/watch?v=8qQQ2XbIEak https://www.youtube.com/watch?v=-D2tQ3zrKsQ
CT
Argyris, you are a true craftsman. The original muffler is a real impressive piece of work. A neat installation is always important to me and yours is very well done. Now you must save your money and put a Wren turboprop in the plane.
John
John
My Feedback: (8)
TX
Ron101
To answer your question, I used Dreamworks Taurus Series retracts, Robart 1/2" main struts, and yoke nose strut with modifications. I used Dreamworks 3 1/2" main wheels and brakes, and 3" nose wheel.
[QUOTE=argyris;11770698]Here is my PC-21 with turbo prop style exhaust.
very noisy
Thank you very much!Pilatus pc-21 is one of the most beautifull aircraft ever made!It flies so nice and yes turbo prop is must!!
My Feedback: (22)
Ron101
This electric version got me pretty pumped up for something to fly at warbird meets... love the four blade prop
https://www.youtube.com/watch?v=wvcCBrZbjFk
Hello everyone,
I have acquired one of these PC-21s by ESM and am searching for a replacement canopy. Bigplanes.nl here in Europe seems to be out of that model.
Does anyone have one, new or used? Preferably in Europe. Am located in France.
Kind regards,
Zipperneck
Kind regards,
Zipperneck
