Sebart Avanti S Build Thread w/KT 180
#451
CA
Just ran into electron retracts for the avanti on chief's website. Anyone have any additional info? R they drop in?
considering all of the gear issues, it would be good to have another option.
http://www.chiefaircraft.com/krm-2010600-25.html
#452
My Feedback: (41)
#453
CA
1. work involved if we wanted this option
2. that would also mean that folks that purchased this version with the idea of getting composite wings later, would have an issue also retrofitting their gear.
#454
My Feedback: (41)
Well I don't personally know or have I had any experience with the Krill folks but I know people who have and based on that, I sincerely doubt you'll ever see the composite wings promised by Krill for the original Avanti and I too would have liked that option. Last I heard from Jason at SebArt USA, was that the composite wings for the original Avanti would not be manufactured until demand for the new wings/models was filled.
#455
Electrons fit with some minor work. Anything will fit with modification. Depends on our skills and time. Cassiemitch has done this to his Avanti S but has on sold it to another modeller. He had Xicoy oleo's and pul pull steering. This version looks better. Email Electron and ask them they made the set for Chief. Xoel is more than user friendly @ Electron. He makes drop in fits set for most aircraft these days even Skymaster Big Viper.
#456
NV
As I've noted here before, the wings from the Krill manufactured Avanti S FC (Full Composite) 2.1m/83" model WILL fit the original Avanti S 2.0m/79" model (there's only a slight difference in how the wings are secured to the fuselage). However, Krill is still behind on filling orders for complete Avanti S FC models (the last few ordered took about 6 weeks to produce) so they are not yet able to provide separate wing/stab sets. Also, the colors they're currently using to paint the parts in the mold are slightly different than the colors that were used on the original Avanti S models (as seen in the photos attached below) so we're also waiting to confirm if they'll be able to produce better color-matched wing/stab sets in the future. But from what we understand some colors can't be matched exactly when they're painted in the mold so there may be some slight difference in the yellow and silver in particular (and unfortunately they're unable to paint gold in the mold so that color will not be available for the white/blue/red color version wings/stabs).
And although the composite wings have slightly more span/wing area, they do weigh about a pound more per panel than the original Avanti S built-up wings. So for those interested in 3D flying/hovering, or for electric conversions and sport flying with 100 class turbines, we still recommend going with the built-up wings/stabs to keep the all-up-weight as low as possible. Also, the original Avanti S 'air' gear bolts directly into the Avanti S FC wings/fuse (in fact nearly all of the Avanti S FC models sold so far have included the exact same air gear...less the ones we've sold without gear), so we do expect the new electric gear option to drop right into both models (but we're waiting for final confirmation of that and for the first sets we've ordered to arrive here so we can double check).
On a related note, for those with the 'air' gear we now have two alternative spring setups in stock for those that may need a bit more support than the stock main gear spring setup offers (especially those carrying extra fuel/smoke, 180+ turbines, thrust vectoring, etc.). These alternative spring setups are available at no charge to anyone that purchased an Avanti S model from us or one of our authorized dealers, and at minimal cost (plus shipping) for anyone else that may need them.
BTW, we do have Avanti S models in stock now without landing gear, and we can special order Avanti S FC models without landing gear or with the electric gear option. And for those with a set of Avanti S gear that may be looking for something else to use them in, next week we'll be receiving our first shipment of the all-new 2.1m/83" span Pilatus PC-21 for electric or 50-60cc gas power that uses the same landing gear (and yes, we will have some of these in stock with and without the gear).
Also, for those that haven't seen it yet, the all-new 'Mini' Avanti S for 90mm EDF or P20 turbine power will be available in May/June:
http://www.rcuniverse.com/forum/rc-j...l#post11993825
#457
My Feedback: (41)
#460
CA
So it's been quiet and I'd thought I'd shake things up a bit and let you know that I did end up purchasing the electron retracts, struts and wheels. Very high quality undercarriage. Here is what I like
1. They are not drop in, but changes are minor.
-On the nose, 2 new blind nuts and some dremel work to get the setup to clear properly
-I suspect they mains would require shifting on blind nuts, but I wouldn't know for sure as I'm coming off a wing repair. The electron set is slightly shorter than the original set.
2. Steering linkage is on the top side of the gear bay versus on the bottom... So it is completely free to move versus on the old gear it was inverted and the linkage could get hung up on the bottom of the fuse
3. No spring problems...
4. No having to retighten retracts regularly
5. No Air
These are definitely the way to go.
5. No Air
#461
NV
Hello everyone,
For anyone that may be interested we now have the complete sets of Electron Retracts for the Avanti S 2.0m/79" and the Avanti S FC (Full Composite) 2.1m/83" models in stock. These sets include three ER-40eVo electric powered retract units (plus a custom adapter block/mount that makes it possible to use one of these units for the nose gear) and the RB-45 control unit (which is set up to be powered by a 2S LiPo), custom Electron nose gear and main gear struts (with springs to handle models up to 35 pounds), wheels and electric powered brakes (as seen in the photos below). The regular price for the complete set is $1149.99, but until the end of May they're available from us at a special introductory price of $999.99. BTW, the Avanti S 2.0m/79" is now available without gear (was $2399.99, now $2099.99), with air gear (was $3299.99, now $2799.99) or with the Electron electric gear (for $3099.99).
And as hbutler noted, because the sets we offer include a custom adapter block/mount you'll only need to move/install two blind nuts to mount the ER-40eVo electric powered retract unit in place of the air retract unit for the nose gear (you may also need to remove some wood in a few places so everything clears properly). Then for the main gear you'll only need to move/install two blind nuts and remove a small amount of wood (to clear two of the mounting tabs) in order to mount the ER-40eVo units in place of the air units. Here also are some additional notes regarding the Electron electric gear and the air gear:
- The main wheels/tires included with the electric gear are 3.5" in overall diameter (plus they have electric brakes) versus the 3.75" wheels included with the air gear (not a problem, just something to be aware of when comparing the wheels/tires in the photos below).
- For the main gear, the overall distance to the axle is the same for the electric and the air gear.
- Overall weight is about the same for the electric and the air gear setups.
#462
I've read some of the posts here and I'll be honest, I don't know what you guys expect or what you are doing to the gear but the supplied gear with the Sebart AvantiS 2M is very nice! The gear is more than strong enough, well build, well engineered, well machined and finished and the air cylinders operate smooth and hold air all day long, in either position. The trunions lock solid in either position and they operate a full 4 cycles on 100lbs using 2 medium BVM tanks, what else can you want? The tires are secure on the rims, the brakes work perfectly with a small separate tank on 20lbs, smooth and firm without locking up, I don't think I could break this gear if I wanted to?!
Jack
Jack
#463
CA
Depends on ur agenda. If u r a rcu member that is interested in hearing about others experience in order to guide ur own decisions then u want to have the unfiltered information. If ur agenda is different then u might assume a different position.
Not suggesting the side of the fence u r on but I will say I'm the former. The avanti s is a good jet and versatile. Built up wings r a concern for some. Gear has issues as many reported. There could have been changes.
Haven't flown them yet but the electrons appear to be a much better option. As an rcu member I would recommend that set based on what I know today
#464
With all due respect the Electron gear (struts at least) look cheap and under-built, with external springs and lighter weight stock. I love the actuators but I am disappointed in the fit and finish of the struts for certain.
I'm not sure what you mean by "agenda", what I stated about the gear is my viewpoint but one I think you'd be hard-pressed to deny. Fit and finish, sturdiness, design, functionality? Until now I've been all BVM but this gear (looks to be SkyMaster) is more than what I expected for the price for sure.
As for built-up wings, no one hid that fact they were built up, in fact the price point can only be achieved using built up wings and stabs. My eBandit is all composite but also $1000 more without gear, it's all relative. I am unaware of any delaminating or breaking in-flight, is that something people are seeing?
Jack
Jack
#465
Jack
Jack
#466
I have owned one of these and in my experience there are issues with the landing gear. The real bug bear for me has been the springs. Not strong enough. The other minor issue is the screws that hold the trunions in place keep coming out and yes I have even used red loctite. But it must be my environment.
Other than that it is a very enjoyable model. Pity however here in Australia you cant buy it without the gear. Have asked and blunt answer of NO.
#467
Jack
#468
Again back to supplier and request for stronger spring set. There is nothing wrong with springs. Even emails to Seba given blunt answer about landing gear there are no problems. As we have seen in this thread there are problems for some and not others. I am happy with model and have made adjustments. IMHO you cant beat the Electrons in any model I have them in Euro, Reaction, Diamond and Avanti. No failures and solid as paired with Intairco wheels and brakes. Flawless.
#470
NV
FWIW, many hundreds of Avanti S models have been sold worldwide, a large number of which we've sold in North America since we took over distribution here about 18 months ago. And yes, the air gear has worked perfectly for the vast majority of Avanti S owners, and in North America less than a dozen guys have had issues (some of which have posted here on RCU). Some of those issues were due to incorrect setup, assembly, etc., yet some issues were related to the gear itself and we worked with those guys to get them replacement parts as needed. Also, some guys did have issues related to the main gear strut springs as a result of the weight of their particular model based on their chosen power system, fuel/smoke tank and radio/battery setup. And the stock springs do work for many setups (primarily 100-140 'straight' pipe setups carrying the recommended amount of fuel and using the recommended radio gear/battery setups), but they do not work for all setups (primarily heavier 140-180+ setups carrying more than the recommended amount of fuel/smoke, with thrust vectoring, heavier radio gear/battery setups, etc.). So we (SebArt RC USA) took it upon ourselves to find the two alternative spring setups we can offer customers now, and out of the three spring setups we have available, one of those setups typically works for just about everyone.
And because the SebArt distributor is not the same in every region of the world, some distributors have not taken the time nor had the interest in supporting the Avanti S (or other SebArt models) the way that we do. This is why we now offer the Avanti S with air gear and one of three spring setups to accommodate nearly everyone, with the new Electron electric gear, or even without gear (while other distributors may not). We've also pushed the factories to offer us spare parts for the landing gear that was not previously available separately in order to provide the best possible support. Does that mean we make everyone happy? No, unfortunately it does not, but I can say with a clear conscience that we've provided a level of support that's been unmatched by most other distributors and has resulted in many dozens of very happy Avanti S owners. We're even happy to help Avanti S distributors and owners outside of North America if they contact us directly (but please be sure to contact us by email or by phone since I'm not always alerted when you send a PM here on RCU).
#471
My Feedback: (7)
I purchased an Avanti S last year at Joe Nall and I'm finally getting ready to finally assemble it. I also purchased a Kingtech K140G along with the fixed thrust tube that was appropriate for that size turbine.
My question is, with a K140G in the jet, is it possible to use the thrust vectoring tube or would I also need a larger turbine? I'm not so interested in raw power maneuvers such as hovering but
things like flat spins, and some other maneuvers that would benefit from thrust vectoring may be fun.
Wayne
Wayne
#472
My Feedback: (41)
Wayne
Wayne
That said; it should be fun to play with and with the 140 size engine at your altitude it should be worthwhile to try the vectored thrust realizing there will be no hovering or the like. I have a friend with the exact same setup as yours and while it fly's okay here at 4500' ASL, it's certainly not anything to talk about especially in the Summer. Mine has the 180 Behotec with the VT nozzle and it's got plenty of power for the verticals, some high alpha stuff, flat spins and so on but hovering it is going to be another story. With the fuel almost gone and not too hot a weather it should do a hover but I've not tried it nor actually flown the model a whole lot. Be aware that the model Seba was demonstrating all the time with the hovering has a 250 size engine.....
#474
My Feedback: (7)
that the smaller engine may not perform properly with the vectoring thrust tube. Since it doesn't sounds like that will be a problem, I will have to seriously consider adding thrust vectoring.
Wayne
