Reload this Page >
Carbon or Aluminum Wing tubes
Old 03-13-2014, 07:15 AM
Bob_B
Bob_B's Avatar
Default Carbon or Aluminum Wing tubes
I'm looking for a source for a 19mm OD wing tube.
Bob
Old 03-13-2014, 07:43 AM
Harley Condra
19 MM works out to .748, which is almost 3/4". or .750
what wall thickness do you want?
Here's a source for CF tubing in 19mm x .540 wall x 48"
http://dragonplate.com/ecart/product...D=4859&cID=102
Old 03-13-2014, 08:18 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Harley are CF wing spars normally pultruded? The reason I ask is I need some tubes too and I am almost more comfortable using aluminum as I know what I will be getting (performance wise) and I can size for what I need. The weight is less of an issue for me. And they bend, too!
Old 03-13-2014, 08:23 AM
Bob_B
Bob_B's Avatar
the current tube is not very symmetrical it measures .036 on one side .048 on the other.
This is the main wing tube so I am open to suggestions on this.
The length is 20 inches
Old 03-13-2014, 09:12 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Bob,
I purchase a new spar from my Dragon here:
http://www.speedymetals.com/pc-4565-...-aluminum.aspx
Old 03-13-2014, 09:15 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Bob
In aluminum, 19 mm is not a standard,I have found either 18mm or 20 mm O.D.
Old 03-13-2014, 09:25 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
3/4" CF tube
http://store.clearwatercomposites.co...750-tw-36.html
Old 03-13-2014, 10:12 AM
jetflyr
Bob
Try RC Foam at: www.rcfoam.com.
They have a huge selection of C/F tubes that I have used successfully for years.
Greg
Old 03-13-2014, 10:53 AM
Harley Condra
Graves Hobby Shop in Orlando Fl. has two 48" long carbon fiber tubes of 3/4" diameter. Same as 19mm for all practical purposes. I was there about an hour ago. and checked them out.
I have seen the process of winding CF tubes on mandrels, but alI I know about pultruded tubes, is that all of the fibers are aligned lengthwise. It is the "Uniderctional" type of CF tubing.The ones at Graves are very stiff.
Old 03-13-2014, 11:09 AM
Bob_B
Bob_B's Avatar
Thanks Harley!
Old 03-13-2014, 02:31 PM
cmjets
cmjets's Avatar
Hello:
Why that measures ? 20mm is more normal for me, but 19 ?
I use strong aluminum in my models. In carbon 20mm you can find tubes with 1 or 2mm of walls.
http://www.petrausch-modellbau.de
http://www.online-shop.carbon-compos...st=KAT11-10113
http://www.clipcarbono.com/es/100-30...o-1000mm-.html
Regards from Spain.
Carlos Marquez.
______________________
www.cmjets.blogspot.com
Old 03-13-2014, 06:23 PM
Texastbird
Texastbird's Avatar
http://www.sdshobby.com/19171000-mm-...3b93f46b48a533
This company sells carbon fiber tubes in a variety of sizes. I have ordered one of the larger sizes for my 50cc plane and it looks good to my untrained eye.
Old 03-13-2014, 08:40 PM
Larry882
I have been using aluminum wing tubes for years. The worst part is drilling the holes. I get 1" diameter .055 wall thickness from Ace Hardware. I used a 48" long wing tube in my Big Slowpoke scratch built plane. It's about $2.50 per foot. The Slow Poke in the picture weighs 38 pounds and could handle full power loops. It expired May 6 2010 because the Robart control horns on the eleavators failed. The wing tube didn't.
Larry Kopecky
Old 03-13-2014, 10:53 PM
dtyjkdutkying
Old 03-14-2014, 02:48 AM
Bob_B
Bob_B's Avatar
I looked here: http://store.clearwatercomposites.co...750-tw-36.html
Their tubes have a .063 wall thickness. The tube that came with the model had uneven wall thickness which concerns me.
Thanks for the link Rich, and thanks to everyone that responded.
Old 03-14-2014, 06:23 AM
Radical Departure
My Feedback: (13)
Radical Departure's Avatar
TnT has a large variety of tubes and sleeves;
http://www.tntlandinggear.com/welcom...ne_catalog.htm
Old 03-14-2014, 08:00 AM
flycatch
My Feedback: (26)
Aluminum tubes are a pain in the ass.
Old 03-14-2014, 08:05 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
I have ordered tubes from these guys on several occasions. I have been quite happy with the quality and delivery times. I usually have them in less then 2 weeks.
http://www.ebay.com/itm/19MM-OD-X-17...item338b09e3f9
Old 03-14-2014, 09:24 AM
VincentJ
VincentJ's Avatar
I too have used TNT for my source of wing tubes, they sell both carnon and aluminum... http://www.tntlandinggear.com/welcom...ne_catalog.htm
They are a very good company with good customer service. Why use aluminum when CF is stronger and lighter... just my opinion.
Old 03-14-2014, 09:28 AM
airraptor
My Feedback: (66)
What plane is this for? i was looking for a carbon tube for my GP Revolver. I think it was 19mm also. i eneded up getting one from Troybuilt models I think. Look at replacement tubes for stabs.
Carbon is much stronger than aluminum. IF I need more strength id will add a balsa core to it.
Old 03-14-2014, 11:38 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Only if it is laid up properly. Most of these sources are very reputable. Of course aluminium sort of has the same issue, you need to buy from a reputable vendor that uses the proper material.
A core material is a great idea too.
Old 03-14-2014, 02:57 PM
airraptor
My Feedback: (66)
The core adds to it as it is like sheer webs and performs as a anti-crush material so that it wont crack or crease like aluminum does.
Old 03-14-2014, 04:19 PM
ChuckC
My Feedback: (24)
Whatever you do, don't get the Ace hardware tubing. May be ok for light g loading, but it's usually "Plano" aluminum, whatever that is. T-6 tempered 7075 or 6061 tubing in thick wall should be available. I get it locally by the joint at commodity pricing-last time was Great Western Metals and before that was Farmers Copper. I think it's used for full scale or something like that.
Old 03-15-2014, 08:32 AM
Harley Condra
My understanding of "Plano" aluminum, is that it is 1100....pure aluminum with no other alloying elements. It is usually called "Architectural Grade".
