Reload this Page >
skymaster pc-21
skymaster pc-21
Old 11-08-2016, 11:21 AM
  #301
helifox
helifox's Avatar
Originally Posted by helifox
We a bit damage our PC in Flight at RusJet masters meeting, during G-force turn the canopy was blowoff from airplane, landing was safe but now need the new canopy frame with bubble :-(
Hi friends,
Just finished with repare the cockpit, new bubble is install and new cocpit done. Also we install iGyro SRS and moved the C of G more back up to 205mm.
Next Saturday will remaiden.
New view of the cockpit:
http://youtu.be/5Lq_a3K3MTw
ID:	2189442   Click image for larger version
ID:	2189443   Click image for larger version
ID:	2189444   Click image for larger version
ID:	2189445   Click image for larger version
ID:	2189446   Click image for larger version
ID:	2189447   Click image for larger version
Old 11-11-2016, 01:05 AM
  #302
helifox
helifox's Avatar
Some scale works on propeller
Tomorrow going for remaiden with iGyro SRS and C&G 205mm
Old 11-14-2016, 09:46 PM
  #303
DrScoles
My Feedback: (18)
DrScoles's Avatar
For those of you who hinged the canopy on the side, what type of hinge did you use? Love to see a close up of how you attached it.
Thanks, Mike
Old 11-15-2016, 01:07 AM
  #304
argyris
argyris's Avatar
Giant plastic hinges with screws.
ID:	2190044   Click image for larger version
ID:	2190045   Click image for larger version
Old 11-15-2016, 01:08 AM
  #305
argyris
argyris's Avatar
https://www.youtube.com/watch?v=YrlGHVUYcGY
Old 11-16-2016, 08:57 AM
  #306
helifox
helifox's Avatar
Thanks, Mike
Hi Mike,
Sorry for delay,
Here http://www.yug-models.ru/forum/index.php?showtopic=9866 you can find all interesting you unswer and some interesting design from our assembling PC-21. I understand that is Russian language but there are lost of pictures step by step and online translator will help you as well.
For canopy we have used these hinges http://www.dreamworksrc.com/catalog/...eavy-Duty-15Pc, we did assembly by pair with changed axe.
Kind regards,
Sergey
Old 11-16-2016, 10:35 AM
  #307
DrScoles
My Feedback: (18)
DrScoles's Avatar
Sergey, what an awesome build tutorial! Very nice. Now you have given me a ton of ideas for me and my 3D printer..... ;-) Thanks again.
Mike
Old 11-22-2016, 12:40 AM
  #308
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
Another PC-21 cockpit with some extra futures
https://www.youtube.com/watch?v=EIAx_GCcfoc
Old 11-23-2016, 01:03 AM
  #309
pilot tw
under wing tanks with pylons for PC-21 are available now
Old 12-07-2016, 04:54 PM
  #310
scrogerio
Originally Posted by k_sonn
David mentioned after his maiden that the engine cover gets very warm and needed heat shielding. I added three coats of BVM heat shield but it didn't completely prevent the fiberglass from getting hot and the paint from bubbling. This morning I went to Home Depot and purchased a flame protector heat shield blanket plumbers use and lined the inside of cover. The heat shield blanket is effective up to 2500F or 1371C. It took two blankets with some left over to cover the inside of the cover.
Kirk
Kirk, which product you use to install flame protector?
Old 12-07-2016, 06:24 PM
  #311
David Jackson
My Feedback: (15)
I am sure there are other methods for attaching the flame protector material, but I use BVM ceramic heat shield. Simply paint a couple of coats of BVM ceramic heat shield to the PC-21 engine cover. While it is still wet, press the flame protector in place and let the ceramic heat shield dry. So far this method has kept the flame protector attached to the engine cover.
Old 12-07-2016, 09:38 PM
  #312
In the Haze
In the Haze's Avatar
Other than the deflection of some intake air as detailed earlier there must be another way of getting some cooler air into the power compartment. The venting of air out of the fuselage at the back together with a few more NACA inlet ducts in the cowl could help. Or not?
Old 12-09-2016, 11:13 PM
  #313
Fireflynightshift
Fireflynightshift's Avatar
Hi Nev.
Have a look at the picture of the full-size next to the spinner at about 8 oclock. I open my scoop there as well on the side and it makes quite a difference in temp with scoop open and I am also going to put the vents in the rear of the body like Scrogerio di in his. I will post a pictures when home. Hope this helps. Have you received yours yet. If you thought the hawk flies well wait until you put your hands on this baby. Send pic of you build and enjoy.
Have a great day
Regards
John B
Old 12-11-2016, 10:04 PM
  #314
In the Haze
Originally Posted by Fireflynightshift
Hi Nev.
Have a great day
Regards
John B
Yes John, will start on it soon. Will add extra intake and exit air.
Old 01-23-2017, 06:01 PM
  #315
ltc
What is a realistic minimum (say leaving out cockpit and pilots) RTF weight for this plane with a K60TP?
I've seen quite a range of RTF weights for this plane across various websites.
Old 01-23-2017, 11:26 PM
  #316
David Jackson
My Feedback: (15)
With just the standard cockpit and a single SM pilot, my PC-21was approx. 42lbs wets.
Old 01-24-2017, 06:50 AM
  #317
ltc
Thank you very much.
I don't have access to a paved runway, so grass is my only option, so I was thinking that keeping the weight as low as possible was the best path to follow.
I would likely skip the cockpit and pilots.
While searching the web, I did stumble across a PC-21 from Kingtech Luxembourg, JMB Jets, which is slightly larger than the Skymaster but significantly lighter (14kg wet) but it is all built up/balsa construction. It was flown at JetPower from the YouTube videos I came across.
Old 01-24-2017, 08:27 AM
  #318
David Jackson
My Feedback: (15)
I do remember seeing that video. I believe that particular model was flown with the new Kingtech 45 turboprop engine.
IMO, the Kt-60 turbo prop engine provide such good power with the right propeller, you shouldn't have any issues flying the PC-21 from a non paved runway.
Old 01-24-2017, 10:46 AM
  #319
helifox
helifox's Avatar
With PC-21 you wouldn't worry about grass runway and take off weight.... Our PC-21 has weight almost 22kg (with 2kg of fuel) and flying unbelievable with K-60TP
http://youtu.be/H-Sw-kVn8Yo
Old 01-24-2017, 07:01 PM
  #320
ltc
Thank you very much for taking the time to help
I was planning on using the JetCentral Turboprop
It weighs about the same as the K60TP with a bit more power (new SE is 9kw compared to my previous version which was 7kw) and slightly lower fuel consumption. Also has Jeti Telemetry integration available....Kingtech has no scheduled date yet for Telemetry
The Swiss scheme in the video is my favorite and likely what I will be ordering
Probably going to go with Details4Scale lighting kit, no cockpit or pilots.
Old 02-25-2017, 06:06 PM
  #321
ltc
Could someone please tell me the dimensions of the rear (removable) section of the fuselage?
Cant find it online, I am trying to determine transportation and storage requirements for this plane.
Old 02-25-2017, 07:23 PM
  #322
David Jackson
My Feedback: (15)
The rear section of the Skymaster PC-21 is 45 inches long.
Old 02-25-2017, 07:56 PM
  #323
David Jackson
My Feedback: (15)
. double post
Old 02-26-2017, 06:56 AM
  #324
pilot tw
new color scheme for PC-21
ID:	2202918   Click image for larger version
ID:	2202919   Click image for larger version
Old 02-26-2017, 07:04 AM
  #325
ltc
can you show the bottom scheme?
Is it black/white like the full scale?
https://www.flightglobal.com/news/ar...-skies-427684/
