Aviation Design Diamond Build by Ultimate Jets
#101
Have you found any issues with it, any updates or modifications? Still using the 312mm cg position? Control movements, mixers and measurements still as originally stated in the manual and on here?
JanR
JanR
#102
#103
#105
Good to hear guys - from what I can gather, we've only had three of these come in to Aussie. So there may still be two flying here (somewhere), but definitely none anywhere near me.
Very much a unique flying object, but I guess too expensive for most.
Cheers,
JanR
Cheers,
JanR
#106
There is a Canadian site that covered the build of 4 Diamonds. All are flying great with a very minor modifications to the stock set up.
Aviation Design Diamond / Behotec 220
#107
My Feedback: (176)
Hi do you do the cg with the gears down or up? I made the cg with the recommendation 312mm and for some reason it fell like slightly nose heavy and I don’t remember if when I did the cg I did it with the gears down or up just wanted to make sure that and do the cg one more time with new batteries thanks again.
#113
#114
I've made some progress. I've had to wait on shipments of various items so things should pick up The following has been completed:
1.Removed and changed out some of the rear fuselage decals (removed Jetcat and Hvp modell and replaced with Igryo, Jets Munt, Jeti)
2. Installed front clip with retract and painted the assembly
3. Painted the servo covers
4. Painted the two fuel tanks along with the smoke tank.
#116
https://cmjets.com/adjets/195-diamon...-tank-24l.html
ML
#117
My Feedback: (44)
IL
I recently finished mine with a Star Wars color scheme and I also did couple cool things which I will post pictures later on quick removal of the vertical fin tube and a quick access to the nose piece for charging the batteries.
#123
My Feedback: (176)
Make sure that you soak the wood with thin ca glue so they don’t shrink or expand doing the summer temperature jumps and the wood doesn’t crack in the middle,I’m very happy that someone actually you said something about my ideas ,did you used the wooden sink to glue the elevators carbonfiber rots.
