Unilight System
#153
SD
ON, CANADA
I hope someone can help me. I just received my lightning system including a economy 8 controller.
Is it possible to connect to my computer without the USB programmer?
Paul
Paul
#158
Unilight
hi guys I have the 4 ch black controller my problem is all lights function well with the exception of ch 1 strobes , when I retract my landing gear strobes switch off but when I extend the landing gear the lights all function as programmed which is what is supposed to happen, am I doing something wrong
kind regards
jedda
kind regards
jedda
#159
My Feedback: (40)
kind regards
jedda
kind regards
jedda
If that's not it, try adjusting the value of your light channel setting a few percent. I've found that there is a narrow band/range of values for each light sequence option and if you are too close to the edge of the band, the controller might intermittently select the adjacent sequence.
#160
Sounds like you might have a mix that is changing the output value on your lights channel. Watch the servo monitor on your transmitter and see if the value changes on the channel you use to control the lights, when you move the retract switch. If so, figure out why.
