Reload this Page >
New big Ripmax Xcalibur (Xcalibur+)
Old 09-07-2015, 12:07 PM
  #251
Dave Wilshere
M5 screw, but like he said.
the booms are also clamped to the fuse by M5 bolts, we tried to get the number of tools down to a minimum for assembly. M4 screws (3mm AF Allen) on the canopy, nose cone and tail plane. The booms and wing clamp are M5 (4mm AF Allen)
Dave
Old 09-07-2015, 12:27 PM
  #252
Pondus
Dave's right, I was thinking 4mm because it uses a 4mm Allen key but the bolt is M5.
Dave, is there any need for elevator trim when selecting take off or landing flaps? The manual does not mention anything about it, I've got the rest of the plane setup but I was wondering about this.
Old 09-07-2015, 10:22 PM
  #253
Dave Wilshere
I just looked and we did miss that! Yes it needs down with flap. Around 1mm in take off flap and 4mm landing flap.
Enjoy!
Old 09-08-2015, 05:13 AM
  #254
Pondus
Will get that setup as a starting point.
Old 09-08-2015, 05:43 AM
  #255
Dave Wilshere
Yes, obviously it will change a tiny bit with flap angle and balance
Dave
Old 09-09-2015, 05:48 PM
  #256
TurboFan!
What is the capacity of the included stock fuel tank?
Old 09-09-2015, 11:08 PM
  #257
Dave Wilshere
It's around 4.5ltrs!
Old 09-10-2015, 04:58 AM
  #258
TurboFan!
Excellent! Thanks Dave. My T-Bird scheme just arrived! At this point I'm thinking of fitting 8 Futaba S9156 and 2 S3152 for the gear and brake valves.
Old 09-10-2015, 11:16 AM
  #259
Dave Wilshere
Servo power is more than ample, little heavy, 4 sit at the back end and would be 2oz more way back there. Model is very light, so no real biggy, but you'll need big batteries or weight in the nose.
My three 2s Li-po packs are 692g and my servos 55g each.Just a heads up!
Dave
Old 09-11-2015, 11:57 AM
  #260
Dave Wilshere
Ian Bailey brought his 2010 Plus to CJ today. Great scheme.
ID:	2119312   Click image for larger version
ID:	2119313   Click image for larger version
ID:	2119314   Click image for larger version
ID:	2119315   Click image for larger version
ID:	2119316   Click image for larger version
ID:	2119317   Click image for larger version
ID:	2119318   Click image for larger version
ID:	2119320   Click image for larger version
Old 09-12-2015, 03:28 AM
  #261
TurboFan!
Dave
Now looking at The Futaba S3071HV weigh 49g and produce the required 10kg torque …should save me unnecessary nose weight and fly the Xcaliber + well…
Old 09-12-2015, 08:58 AM
  #262
Dave Wilshere
They will work fine!
Old 09-13-2015, 11:09 AM
  #263
blainer48
My Feedback: (30)
I just want to say that the folks at Global Jet Club have been awesome to work with and the support has been top notch. My retracts were missing from the box when shipped and they got a replacement set shipped out very, very quick. Couldn't ask for better support.
Jason
Old 09-13-2015, 07:13 PM
  #264
rcbidder
Just picked up my "Union Jack" from my LHS, starting to lay out components.
Have a few ?
Air Tanks: I got them to fit head behind the nose in the frame holes, is the correct location.
Are the (2) Tanks enough, when combing both to be used as Retract and Brake?
was planning on using the Pilot RC, elec pneu. valve.
Old 09-13-2015, 08:45 PM
  #265
Pondus
I just installed my tanks under the equipment trays with a dab of silicone, but as the plane is likely to need some weight in the nose for balance putting them further up front makes sense. I'm using one tank for the brakes and one for the gear on separate systems and starting with 100 PS I get 6 cycles on the gear before the pressure gets too low.
Old 09-13-2015, 11:12 PM
  #266
Dave Wilshere
Either side if the nose unit is perfect, in the nose it restricts wire access and tanks are light.
two is plenty, I use the Behotec valve and get multiple cycles.
Old 09-14-2015, 07:29 AM
  #267
Pondus
I have to say I'm pleased with the retract units and included air system, besides swapping out the filler valves to Robart valves (to standardize and fit my compressor), and installing SMC pressure gauges I've used all the included stuff and the retract system is 100% leak proof, it's been holding 50psi for something like 3 weeks now. The brakes bleed out pressure ever so slowly over a few days, but that's ok too.
Old 09-14-2015, 08:04 AM
  #268
Dave Wilshere
The guys at Ripmax spent a long time sorting this, tried more than one manufacturer on the prototypes and settled on the one making them. My Xcalibur plus holds air for weeks (I use the Behotec valve so brakes are isolated)
I use a Festo filler and T's just because that's my standard set up.
Old 09-14-2015, 01:16 PM
  #269
rcbidder
Servo Arm Lengths: I'm using HiTec 7940 on all surfaces, and was planning to use these SWB servo arms and clevis.
Would the 3/4" Length be enough?
Old 09-14-2015, 01:20 PM
  #270
Dave Wilshere
Movement wise yes, you might have to trim larger openings in the servo covers with such large clevis. You won't get a lot of arm outside the covers
Old 09-14-2015, 02:32 PM
  #271
rcbidder
Can go with a 1" arm, so the clevis won't interfere with servo cover and allows more movement, I guess the drawback is the arm/clevis is exposed.
Old 09-14-2015, 02:47 PM
  #272
Pondus
You will need a longer arm on the flap servo, I'm using a Hitec 7955TG servo and with the long single arm (HD-LL) that's included I'm using all the servo travel available to just about get the recommended flap throw. This arm is 28.5mm when using the outer hole, so a 1.25" arm would work ok here.
On the other surfaces i use the short Hitec arms and these are 22mm on the outer hole, I could use the next hole in @19mm on elevator and aileron but as Dave says the problem then will be interference with the servo cover and clevis.
Old 09-14-2015, 10:44 PM
  #273
Dave Wilshere
Yes, good point I forgot! Flap does need a longer arm! I used a Secraft 1.25" arm. Everything else with JR super servos arms 20mm (stock clevis)
Dave
Old 09-15-2015, 08:34 PM
  #274
RENO
My Feedback: (17)
Hello Dave,
I opened the big box and was impressed, still am, however after the booms went correctly in place, the anti rotation tubeswould not allow the wings to slide in place. It appears the mounting rotation tube holes either on the wing or the fuselage are not lined up! Any suggestions?
Skeet
Old 09-16-2015, 12:54 AM
  #275
Dave Wilshere
Odd as I have not seen a problem and they are jig assembled.
Are you putting the screws in first? I put the wing tube in and the carbon pegs and then added the screws. Same on the middle size one.
Dave
OK, reading again you are saying the boom/tubes are OK, its the wing that will not match? How far? Did you chamfer the tube or are you trying with the square cut end?
If you back off the screws on the booms there is some movement in the pegs.
