Sebart Mini Avanti w/ K45 build thread
#901
Although I'm using different and more heavy-duty HV servos for all other surfaces, I was thinking about using a lighter and smaller servo (still HV capable) for the Rudder because that may allow for less modification during installation. However, I obviously need the servo to be strong enough to withstand high speed and aerobatics reliability.
What do you all think of the Hitec HS-5070 servo for use on just the Rudder?
https://www.amainhobbies.com/hitec-h...c35070/p361357
#902
https://www.amainhobbies.com/mks-ser...waAsRkEALw_wcB
mks is great for the money in this size. 45-55 bucks depending if its on sale and they center well and tons of power.. cant go wrong.. if you wish to keep the cost down go with kst 215mg but be sure you get the newest version moarked on the the side label.v3 or more
https://www.amainhobbies.com/kst-ds2...QaAsr3EALw_wcB
#903
#906
Thanks Horsefeet. I ordered 7 Pro Modeler DS-100DLHV servos for the remaining servos left that the kit requires (with one to be used for the Rudder), but then figured I would see if I could find a Rudder servo that is slimmer and allowed for an easy drop-in fit. I looked at those MKS servos and almost went with them, but reviews in some instances were a hit or miss from friends, and although I have no experience yet with the Pro Modeler I am curious to see how good they are for their price ($40 each). The servos that came with the kit I have running off a two-port regulator (to 5.2V) with one port being utilized for the retracts and doors, and then the steering servo. I'll definitely check out those KST servos. I've never used those either.
#908
You may consider the BLS3270SVi Futaba servo as well. https://futabausa.com/product/s3270svi/
It's HV and fits very nicely on the provided rails with just a hint of sanding on one block to fit in the existing cutouts. I have it on my rudder and can easily climb in knife-edge and I actually used one on the nose gear steering as it is a literal drop-in fit. This allows you to run a single voltage regulator for the sequencer (gear and gear doors). I like to regulate the rest of the HV servos down to 7.2V for consistency in power delivery and transit time as well from the 2S 8.4V. Futaba does sell (as well as others) an inline 5.0V regulator that you can place after the receiver and before the sequencer to just regulate the sequencer down and not effect everything else.
#909
My Feedback: (44)
The provided sequencer "should" provide current limitation in the case of a stuck gear so it does not drag the rest of the voltage supply down to the receiver.
I was considering running a regulator to the sequencer and powering from the ECU battery, so in the case if something went terribly wrong with the chinese controller, the worst that would happen is a turbine shut down which is better than loss of control if the receiver was disabled...
Thoughts?
#911
I was wondering if everyone was utilizing their receiver battery to run the electric retracts? From what I have read it seems so...
Thoughts?
Thoughts?
Rich Jeti sells a nice Inline regulator. HH used to sell the perfect unit for these model with two input/Outputs VR 5203 but discontinued it!
#912
Thanks Bob. That is great to know. Mine are being delivered tomorrow and am looking forward to trying them.
#913
#915
For the regulator for the gear doors, retracts, and nose steering, I purchase the following Western Robotics Dual Step-down thart I found online when trying to find something simple like the old Spektrum dual Step-down regulator they used to sell.
https://www.western-robotics.com/titan
#917
