Sebart Mini Avanti w/ K45 build thread
#976
I can't help you with a sticker set, but was wondering if someone could post a full size plan of the wing fences, as I would like to try them out. I have a colour laser printer and make my own stickers using stick on decal gloss printing paper.
#977
felt clunk
I wonder what is your opinion on using felt clunks. Some people say they loose little pieces of felt which can build up in the pump and engine. But when using an Intairco Mini Airtrap and an inline fuel filter, they will stop the little pieces of felt, no?
And what size hoppertank do most people use with a 45 N engine? Is the Intairco Mini big enough (around 50 ml) or better use a bigger one from 100 ml?
What is your experience with a normal metal clunk => does it pick up much air? How much air is there in the Intairco mini after a flight?
Skyrider71 (05-24-2020)
#979
For the exposed portion of the elevator servo leads in the fuselage (before they go into the fiberglass tube to that runs at the top of the fuselage), is there a need to protect them from heat near the pipe? If so, what is the preferred method?
#980
Manual suggests glueing your exstention End to the slot In the fuse. Pull the lead snug towards the radio compartment so wires cannot touch the outer wall of the pipe.
I did mine this way and same on the Rebel ( single wall) with zero issues
#984
My Feedback: (30)
I test flew my Mini Avanti with X45. I have been out twice now total of 4 flights so far. The CG was bang on, I used the ply template that Richard aka RCISFUN made... thanks Rich! The aircraft flies and lands beautifully. All measurements as per manual.
I am using low rates on aileron and that too is very quick but I like it as I have 30% expo. Aileron high rate is too high for my style of flying.
I am using low rates on elevator and the aircraft flies perfect but to make the aircraft flare, I switch to use high rates on elevator. The reason is my tank is CMJETS 1.3 litres and after 6 min of flight, I land with 2/3 fuel left, since the tank sits ahead of CG, it needs more elevator to do two point landing with the mains first.
Flaps are as per manual, I have no change in my elevator trim when I select takeoff or landing flaps, the aircraft does not pitch up or down.
This is my second Mini Avanti, I like it with X45 and way better oleos then the previous version. It's a great flying aircraft!!
Regards
Asif
Regards
Asif
#986
Regards
Asif
Regards
Asif
#989
That makes sense. If I'm not mistaken, I believe I've seen some people hang the end of their tank off the aft of the end of the plywood tray, almost butt up against the turbine. I'm not sure if that's advised, but many would know much better than I. Hopefully someone can chime in about that. I have the exact same fuel tank, in the process of building the jet, and was planning to do what I stated if it is safe to do so, and if it allows me to place the tank in a more advantageous position.
#991
Thank you! I hope so. I purchased two Mini Avanti's because I love the way Avanti's fly, one to build as an EDF and the second with a Xicoy X45 turbine.
#992
What is going on that you don't need trim with flaps? Is the gyro on hold? Any sizeable change to the configuration requires a trim change. I have 5 clicks on Flaps1 and 20clicks on Flaps2 (add 5 more if using 5mm crow).
#993
My Feedback: (30)
Hi
My Mini Avanti with X45, GPS, Igyro, voltage regulator, jeti switch with no fuel in the tank weighs 3.64kg (8.02 lbs) whereas my last Mini Avanti, with K45G2 weighed 4.36kg ( 9.61 lbs) with 1" of fuel (See post thread # 497 page 20) and 4.27 kg (9.41 lbs) no fuel in tank with full UAT. So mini current mini avanti is lighter compared to my previous one although I have more stuff in this aircraft, don't know how or why....maybe this version is lighter compared to the previous version. The K-45G3 ECU, pump and 3SLiFe battery might be more weight compared to X-45 ECU, Brushless pump and 2S LiPO. The few differences in this version compared to my previous one is that I am using customs size Powerbox Maxi servo leads that I make myself which are 30% lighter than a heavy duty ready made extension of similar length. I have very small Intairco itrap vs previous version had bigger UAT. Powerbox battery weighs 125grams and Jeti battery 138grams.
The aircraft is well balanced, Ive pull the aircraft 45 degree up and rolled 180 degree and aircraft maintains the flight heading without nose dropping, gyro is no active as yet. Ive done the test upwind and down wind. Ive also done a 45 degree left and right turn bank and the nose does not drop, which means CG is bang on!! I have 40% expo on elevator and that may be the reason I feel I am pulling elevator bit more elevator, although my elevator travel is also as per manual. I like the way it flies.
I don't have brakes as it is not mandatory in Canada to have brakes on turbine jets but I plan to install JP wheels and brakes soon.
#994
WOW. ok I am going to weigh mine again later. I bet that X45 is a lighter overall package. mine was 8lb also and look how different our setups are, lol. The brakes are just handy. I read that JP is doing the retracts/brakes for the new flexjet pro, and that those will be 2S ready. Wish ours were, could get rid of the regulators. Great choice on the JM dry break filler probe.
Hey, let's compare the distance/setup numbers with the Xicoy cg meter.
#995
My Feedback: (30)
I believe JP has V2 brake unit uses anything between 2S-6S as per their manual. I am using the Xicoy measurements from few year back. I see the difference in the measurement of nose. I measure all my jets to the tip of the nose. I place weights (if needed) as far forward as I can. I am also checked my CG with a ply fixture that was cut for me by RCISFUN (picture copied for his post #884).
#996
The measurements between the landing gears relative to the CG is what is relevant- except for the location of weight placement for CG correction. Measuring to the nose does nothing unless your weight is going there.
Regarding the brakes, it's the gear controller that I wish were 2S
I still LOVE the laser cut jig the guy in this thread made, a killer idea.
I would NEVER have believed that your plane was that light with all that stuff in it. Here are my weights from this morning.
Takeoff weight
Landing weight (remaining fuel from last flight, after 7 minutes)
Min fuel weight.
Takeoff weight
Min fuel weight.
#998
My Feedback: (44)
"6. For RC fixed wing aircraft: With the exception of hand-launched aircraft which have no undercarriage and with a flight weight under 7.5 pounds wet, the model shall be able to come to a controlled stop on command with the engine at idle on a level hard surface."
How you accomplish this is up to you.... you can drop an anchor and it will fulfill the requirements...LOL
#1000
K45g3 pipe
Hi group,
I am just sorting out all the kit for my mini avanti build with k45g3.
Just a couple of queries, what is the minimum thrust tube ID and length needed for k45 please?
Also what is the correct spacing from the exit lip of the turbine nozzle to the start of the thrust tube (not including the bell mouth on the tube).
Andy
Andy
