Reload this Page >
Sebart Mini Avanti w/ K45 build thread
Old 06-28-2023, 02:59 PM
  #1126
jvaliensi
I get mine form Amir at HAB Electronics.
Email him.
https://www.hab.se/bygghobby/hab-cnc...t-komplett-x45
Old 06-28-2023, 09:22 PM
  #1127
Aussie1
Originally Posted by essyou35
That K55G4 is at a good price, cheaper than both a K45g4 and a k65g4. Do you think it is a good match for the avanti? I do not need more heavy junk that barely stand the landing speed it needs.
In the end a few hundreds bucks is worth it to have a great flying airplane. Ive read, The k45 is a bit unreliable?
My Avanti has had 4 different engines in it, P20, K45G2, K30G2 and finally the X45, which has been in there for nearly 4 years! The K45G2 was a very heavy engine and it would be very heavy with a K65!
Old 06-29-2023, 07:41 AM
  #1128
Bob_B
Bob_B's Avatar
The K65 is similar in size to the X60
Old 06-29-2023, 08:10 AM
  #1129
jvaliensi
The X60 is the same length as the X45 but a little bigger in diameter. It would be too much for the small Avanti.
Old 06-29-2023, 09:01 AM
  #1130
Bob_B
Bob_B's Avatar
Well, Paul A is flying one of the Eflite Viper on an X60.
Old 06-29-2023, 09:40 AM
  #1131
BarracudaHockey
BarracudaHockey's Avatar
Yea, I wouldn't want the residual thrust. This thread is old enough that anyone contemplating over a P20 was nuts, then 45 became the norm. I personally wouldn't fly it on anything bigger than a 45 but I'd never get it down and stopped at my field if it was faster and heavier or had more residual thrust.
Old 06-29-2023, 09:44 AM
  #1132
jvaliensi
The little Avanti is a bit more fragile than full glass or even foam airplanes. I like to keep it light and watch the speed.
Old 06-29-2023, 08:06 PM
  #1133
essyou35
Im going x45 not sure if I want light or compact version.
Are the JP 50mm brakes the best option? I have the 75mm and man they suck. Buts thats on a flash that needs to land fast this thing should fly similar to my foam version.
Old 06-29-2023, 08:08 PM
  #1134
essyou35
BTW I ordered the grumania pipe as I want dual walled.
RCISFUN (06-30-2023)
Old 06-30-2023, 04:23 AM
  #1135
jvaliensi
I am building another one. I will use X45 Light, HAB single wall pipe and mounting kit. (I have a Gumania pipe and its 2-1/2 times heavier than HAB.)
I found a new source of wheels from RC Castle. LD Technology. They look like JP wheels but the brake wires plug in the same as Electron does. And they costs 40% less than JPs.
https://www.rc-castle.com/index.php?...oduct_id=10071
essyou35 (07-03-2023)
Old 07-02-2023, 10:29 PM
  #1136
extra 300
you will most probably need to add weight aft, going for the heavier pipe is not at all a bad idea. i have the K-30 and grumania pipe in mine and need to remove 230 gr. from the front (according to Xicoy CG device) or add some weight far aft to achieve the required CG at 145mm....
Old 07-02-2023, 11:03 PM
  #1137
Aussie1
I have a single wall Grumania pipe in mine and this picture shows where my two batteries now. I have now moved the red 2s 2200ma LiPo to over the tank and it takes off in 20 metres and lands super slow. Black line is the CG
Old 07-03-2023, 05:00 AM
  #1138
jvaliensi
I do believe you are correct. I had to add 50g of lead to the tail. However, it was still lighter than using the double walled pipe.
I like the HAB pipe + their G10 mounts, because the installation is so easy.
I use Grumania pipes too, they are great.
Old 07-03-2023, 07:47 AM
  #1139
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Yes, battery location is above the tank on mine, your G.G. line looks correct.
Old 07-05-2023, 08:41 PM
  #1140
essyou35
Can this jet use 55mm rear wheels? If so will a bigger nose wheel fit in the front strut or can I move the strut down off the pin a bit to get the AOA correct? Id like to use the electron brakes but the only make 55mm as the smallest.
Old 07-10-2023, 11:39 PM
  #1141
extra 300
Pleased to say that i have maiden my Mini Avanti last Saturday. i had added 50 Gr lead aft and programmed all throws as per manual. What i can say is woooow. What a nice docile jet CG was spot on and jet tracks perfectly.... i programmed crow and used it for landing. simply perfect.
i had a stuck nose gear for the first landing and still i was able to land on the mains and keep the nose straight until speed was bled and i came to a stop with not even a scratch on the doors that remained open.
after fixing the nose gear problem, second flight was even better with some maneuvers loops rolls, slow roll, four point roll, split S....this jet handles like a big pattern ship...
flew 5 minutes (timer) and landed with half tank full. i can easily go for 7 minute flights and have plenty fuel left...
dr.tom (07-11-2023)
Old 08-04-2023, 06:49 PM
  #1142
caliber90
I use 45mm JP wheels at the rear, 40mm at the front. I want the nose pointing a bit lower on the ground. Beware, my M Avanti take off and land on asphalt.
If larger wheel size is used, it certainly help in grass field but, if the pin in the strut bend a little, the landing gear might stuck in the fuselage.
Old 08-04-2023, 07:02 PM
  #1143
essyou35
I got a set of 56mm xicoy wheels and brakes, stock wheels are 50mm so they will be a little bigger and may need to adjust nose strut a little.
I ended up get the xicoy 45 finally I have high expectations.
Old 09-11-2023, 07:34 AM
  #1144
ddfwaj
ddfwaj's Avatar
Default Sebart Avanti Mini Largest Nose Wheel
Hey Guys, I am having issues rotating off grass with my Mini Avanti, powered via KT K45. I believe it to be the small wheels. I have 50mm for rears with brakes and 46mm on the front. What is the largest nose wheel that can be put on the stock nose strut? It appears to be no more than 50mm but maybe 55mm will fit with alteration? I read somewhere on this thread where someone mentioned altering the front strut but no details of what they did. I appreciate any help.
Old 09-11-2023, 02:09 PM
  #1145
Aussie1
I have been flying my Mini Avanti for many years now with a X45 in it, and am still using the original retracts and wheels. I did put some 3mm ply under the front retract to raise the nose slightly and always use 10 degrees of flap for take-off, which makes a huge difference in take-off distance off grass. My jet had a K45 G2 engine in it at one stage, which made it quite a heavy jet. I estimate that I lost 800gms of weight by installing the X45! Also, the fuel tank sits slightly ahead of the CG, so this will create a forward CG when full, so maybe balance with zero fuel towards the rear most CG position. I do not use a header tank, just a felt clunk, so it's possible that a header tank may be forward of the main tank compounding the nose heaviness
The black line is my CG position.
. Here is a old video of my jet showing grass ops.
Old 09-11-2023, 05:32 PM
  #1146
ddfwaj
ddfwaj's Avatar
. Here is a old video of my jet showing grass ops. https://www.youtube.com/watch?v=-gwl0nuxLnY
Hey Aussie, really appreciate the reply! Yeah I had a feeling it might be the weight. I am currently at 5.58kg AUW. I also do have a header tank that holds about 3.5oz of fuel. My CG was done with an empty tank, gear down and it balances right at the book CG of 145mm. I also had to add 6.5oz of weight inside the fuse towards the rear in order to get it to balance at that CG. What do you recommend I shoot for in regards to farthest CG as I didn't see a +/- from 145mm? I am also looking into extending the nose gear height as I also think when it starts to accelerate I am getting a bit of nose gear collapse even though these are JP struts and seem to be pretty tight in regards to up/down.
Old 09-11-2023, 06:36 PM
  #1147
Aussie1
Can you please post some pictures of your installation? For starters,,you can mount the batteries over the tank and remove the lead. It's up to you whether you remove the header tank or try and mount it over the main tank as well. Also, I don't use the cockpit tub, just have a pilot sitting on a support. This allows room into the canopy for other staff. I think mine weights 4.2kg and my cg is 150mm back.
Old 09-11-2023, 07:08 PM
  #1148
frankie
Good Stuff Aussie1, that's certainly a great combination you have there. I can recall when we use to run PST-600's, similar power levels to an X45 but so much more weight, and long spool times...I guess that's progress.
BRG, Frank
Old 09-11-2023, 07:30 PM
  #1149
Aussie1
BRG, Frank
Yeah, I had a couple of those PST engines, great little turbines! The X45 is also great because it will still power most 60 size jets, but at a reduced take-off weight.
