Avonds F-15 Pipe
NC
Avonds F-15 Pipe
Hi Guys,
I am installing a K-140 in my Avonds F-15 and was wondering what the RCU experts thought about the Avonds pipe. I have emailed Philip and although I have never questioned anything he has ever told me, after looking at the engine and the pipe, I'm nervous that the pipe may not be large enough. Philip has told me that the pipe will handle it, but it just appears really small for the size of the outlet of the engine. I have been flying it with a Ram 750 for years and have decided its now time for more power. It seems as though a lot of guys were/are flying them with P-120's and I was just wondering what everyone was doing in regards to the pipe. For the record, Philip has told me to tune it down to about 24-25 lbs. of thrust so that may be why he said it would handle it.
Any help and guidance would be very much appreciated!
My Feedback: (7)
I never even tried mine. We ran a P-120 in a light setup through a Tam's pipe. A friend of mine used the Avond's one and his paint bubbled on the upper surface so he switched to a Tam's pipe also. It may be fine but I agree with you. A lot of work into building one of these and you sure don't want to risk losing the plane to a single wall pipe and heat tape
NC
Hi Sean,
Yes, the Avonds pipe is single walled. I have never had any heat problems with it. The design has an abundance of cooling air around and over the pipe. What did the Yellow have? They are practically the same size.
NC
Thanks Vinny and Jason, it sounds as if the pipe should be okay if you both had larger engines with no problems. I have the usual BVM heat shield and the ceramic blankets as per Avonds.
Thanks again for all the replies.
NC
Jason,
Can you give me some feedback on how it performed with the K-140 and now the K-100? I'm wondering if I would be better to go with the K-100 myself. What was your reason for changing?
Hi,
Regular ol' aluminum foil beats the pants off ceramic blanket for heat protection. I experimented with both and the fuse skin is always ambient temp with the foil, but warm (or even hot) with the ceramic.
Hi,
Yep. I use two layers of heavy-duty Reynold's brand. I crumple them up first so that there's plenty of air pockets between the two and tack them together with a few spots of red RTV. I then use good-quality aluminum tape (after I've cleaned the area to be taped to with acetone) to tape my foil blanket to the inside of the fuse. No kidding, the fuse skin over the foil is ambient regardless of throttle setting. Even a half-inch away from the pipe.
Oh, and make sure the shiny side is facing the heat.
My Feedback: (24)
Nope, but coming from the petrochemical sector earlier in my career, (where ceramic insulation is ubiquitous), I was always told it's not as much about the material, but the air gap or vacuum the material creates. Happens that ceramic survives some pretty intense heat, but the fiber make up air pockets, which themselves have a very high insulation value.
Shaun's experience with aluminum foil bears that out. The aluminum foil also reflects the radiant heat as well as the air gaps insulating the conductive heat.
Funny, a long time ago I was researching aluminum tapes for faux aluminum skin and there's a ton of products out there with a fairly high (relatively) heat resistant adhesive. For $80, I got maybe 10 inch by 100 feet of real aluminum with high performance adhesive; it's aggressive and works out like Flitemetal (soft). Anyway, I wonder if this stuff has an application here? Supposed to be aerospace grade, whatever that amounts to. I've ironically brought home a FLIR camera for other reasons, might be time to rig up some tests...
NC
Thanks George! That helps ease my mind too! Did you keep the pipe as is with the smaller inner pipe? Also what's the distance from the pipe to the exhaust nozzle?
Thanks again guys for all the help!
