Reload this Page >
CARF L-39 Transport
CARF L-39 Transport
Old 09-01-2015, 02:10 PM
Colin Allen
Colin Allen's Avatar
Default CARF L-39 Transport
Hi,
I'm almost ready to push the button on ordering a CARF L-39, but my biggest issue is transport due to the length fitting it in my trailer. Worked out I should be able to get it to just fit provided the fin and stabs are easily removed for transport. I've read the manual, but am none the wiser on this point. Can any CARF L-39 owners let me know?
Thanks!!
Colin
Old 09-01-2015, 10:52 PM
Dave Wilshere
Colin
The fin comes off easily, the stab is not so easy as stock. ball link needs removing from each elevator, and rear fairing un-screwed. Would be easier to make the nose come off, air and battery leads could be made to join up as the nose goes on.
Dave
Old 09-01-2015, 10:56 PM
Colin Allen
Thanks Dave... I suspected that might be the case. How much length could be saved on the nose, if it was cut off just in front of the front former?
Old 09-02-2015, 02:14 AM
Dave Wilshere
It unbolts easily on pins as designed. You save around 500mm!
Old 09-02-2015, 02:33 AM
Dave Wilshere
Name:	DSC_0448 (Small).JPG
ID:	2117803   Click image for larger version
Name:	DSC_0449 (Small).JPG
ID:	2117804   Click image for larger version
Name:	DSC_0450 (Small).JPG
Old 09-02-2015, 05:21 AM
Colin Allen
Brilliant... problem solved. Appreciate the time you've taken Dave.
Will confirm my order!
Old 09-02-2015, 08:11 AM
Geoff White
Geoff White's Avatar
Dave, to get the CG in the correct place, how much of the equipment did you have to stuff in the nose on Simon's L39?
Thanks.
Old 09-02-2015, 12:50 PM
Dave Wilshere
Not so much. It has the PB batteries in the nose and some weight. We thought with cockpit and pilot it was going to balance without weight, but it didn't (simon does like a forward balance). Most of the equipment and ECU battery (for easy charging and short cable) is towards the rear of the cockpit opening. Would be easy to balance with no weight.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
