Reload this Page >
SM 1/3.75 Hawk in T-45C Navy Centennial Scheme
Old 12-27-2015, 05:10 PM
jsnipes
Default SM 1/3.75 Hawk in T-45C Navy Centennial Scheme
I was fortunate enough to receive one of the first SM 1/3.75 Hawk kits to come over from Anton. I chose the TW-2 NAS Kingsville Centennial of Naval Flight T-45C scheme. I'll be assembling it over the next couple of months while monitoring the build thread by Flightwerkz.
Undecided on turbine as of now. JR 8711HV's on main flight controls.
I'll be adding some T-45 scale details, though it will not be 100% perfect, e.g. I do not plan to modify the nose gear to tandem wheel at this time. I do plan to add the H tailplanes and (non-functional) speed brakes on each side of the rear fuse as well as the tail hook.
This will not be a full build thread, but I will post pics along the way so let me know if there is something in particular that you would like to see photos or a video of.
Photos of the subject aircraft are below and initial photos of the model after unboxing will follow.
JS
ID:	2138027   Click image for larger version
ID:	2138028   Click image for larger version
ID:	2138029   Click image for larger version
Old 12-27-2015, 05:22 PM
jsnipes
External fuse pics ...
ID:	2138051   Click image for larger version
ID:	2138052   Click image for larger version
ID:	2138053   Click image for larger version
ID:	2138054   Click image for larger version
ID:	2138055   Click image for larger version
ID:	2138056   Click image for larger version
Old 12-27-2015, 05:26 PM
jsnipes
Wings and main gear...
ID:	2138058   Click image for larger version
ID:	2138059   Click image for larger version
ID:	2138060   Click image for larger version
ID:	2138061   Click image for larger version
ID:	2138062   Click image for larger version
Old 12-27-2015, 05:30 PM
jsnipes
Fuse internal pics ...
ID:	2138064   Click image for larger version
ID:	2138065   Click image for larger version
ID:	2138066   Click image for larger version
ID:	2138067   Click image for larger version
Old 12-27-2015, 05:51 PM
BlueBus320
My Feedback: (57)
Subscribed . What are you using for power distribution?
Old 12-27-2015, 06:22 PM
jsnipes
"Nothing". Two 2S Lipo's direct into AR12120 powersafe Rx direct to HV servos. Each servo plugged into its own channel.
Old 12-27-2015, 06:34 PM
BlueBus320
My Feedback: (57)
Sounds nice & simple. I didn't realize you could do that. This is my 1st plane I thought required a power distribution system, so I purchased a powerbox to stick into my Kingcat & get familiar with it. I'm going to research your setup.
thanks, Jay
Old 12-27-2015, 06:42 PM
jsnipes
I have flown this setup in everything from Kingcats to 1/6 scale F-16's to 40% 3D aerobatic planes with no issues. I'm sure many will disagree (and that's OK ... to each their own) and I am not a technology averse person, but I prefer this simple setup. This jet will be much less abusive on the system than a 3D aerobatic plane, in my opinion.
JS
Old 12-27-2015, 07:30 PM
George
My Feedback: (57)
Agreed Jamie, perfectly good set-up!
Old 12-27-2015, 07:34 PM
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
I have always wondered where there isn't an official t-45 from skymaster, they have the Mk66, hawk 100 but no t-45, Seems like with minimal modifications they could have it. from what I see the only things that are different is the t-45 has tandem front nose gar and they air brakes come out from the side; also the tail hook.
Old 12-27-2015, 07:57 PM
jsnipes
I'm hoping that they will come out with a tandem nose wheel setup so I can convert mine down the road. Since doors are already done, etc I'm just going to leave it like it is for now. Most of the other items I'll add, except airbrakes on side will be non-functional.
JS
Old 12-27-2015, 10:40 PM
ticketec
massive differences....
Old 12-28-2015, 04:36 AM
BlueBus320
My Feedback: (57)
On another one of the large hawk threads Anton said he'd be doing the T-45. He said what other projects were 1st, but I don't remember.
Jay
Old 12-28-2015, 05:39 AM
Bob_B
Bob_B's Avatar
One would think as popular as the T 45 is Skymaster could at least read design the wing and horizontal tale to be correct and add the leading-edge slats the tandem nose gear would be nice too i'm sure if they modeled the scale landing gear it would be spectacular
Old 12-28-2015, 06:03 AM
tp777fo
My Feedback: (28)
tp777fo's Avatar
Before I switched to JR DMSS I used the JR Power Safe Rx's in all my jets along with a JR 12X Tx.all DSMX. The big box is really a 30 AMP power bus using 2 batteries for power. I always used real A123s for easy recharging in the jet. The real receivers are the satellites. I always used 4 with a data logger. I watched the numbers and moved the satellites to get the best reception and oriented the antennas in different directions. (the numbers change every flight based on location, number of airplanes being flown and other factors but if one satellite consistently shows hi numbers it needs to be moved) It is a very simple system and I never had a problem.
Old 12-28-2015, 06:45 AM
jws_aces
My Feedback: (33)
jws_aces's Avatar
Jamie,
Man that is beautiful!!!! I can't wait to see it in person.
Happy new year!
Old 12-28-2015, 01:31 PM
jsnipes
Nose gear details ...
ID:	2138239   Click image for larger version
ID:	2138240   Click image for larger version
Old 12-28-2015, 01:33 PM
jsnipes
Thanks, Jeff. Happy New Years to you too!
This is all your fault, you know ...
JS
Originally Posted by jws_aces
Jamie,
Happy new year!
Old 12-28-2015, 04:02 PM
jws_aces
My Feedback: (33)
jws_aces's Avatar
Wow That is very nice. I love the gear that they came up with. It is a lot easier to build than mine was.
Old 12-29-2015, 09:53 AM
warblood
JS
Can you please take photos of cockpit and also where is the wing to fuselage bolt i cant see it anywhere .
Old 12-29-2015, 09:56 AM
vespino67
I ordered mine with the TW-1 scheme, hopefully arrive in late February.
I can not wait more
Old 12-29-2015, 10:01 AM
jws_aces
My Feedback: (33)
jws_aces's Avatar
Warblood,
Jamie can reply but it appears to be like my Skygate. A single bolt pulls the wing against the fuse. I see a small hole on the wing where mine is. You install the bolt in the wheel well area on the fuse.
Old 12-29-2015, 10:14 AM
warblood
Warblood,
Alright thanks mine will be shipped after 3 days cant wait to start building my setup will be
- intairco air trap and fuel fittings
- Powerbox Royal srs
- Powerbox smoke system
- x2 Powerbox 4000 batteris
- Jr NX 8921 servos
- Turbine jetcat p300 or bf 300 still not sure
what about you guys .
Old 12-29-2015, 10:25 AM
warblood
Im also getting this hot air vent and oil gauge from carf model shame skymaster not making this scale parts
ID:	2138389   Click image for larger version
Old 12-29-2015, 11:25 AM
BlueBus320
My Feedback: (57)
- Jr NX 8921 servos
Think I'm going to wait for the jetcat P220, but may look into 300 size turbine once the flight reports start rolling in. I'll do a Powerbox srs also, & leaning towards futaba servos & jettronic valves. Great idea with the carf gauge, I'll do that too if there's one on the 100.
Jay
