Guidance for installing turbine components
My Feedback: (45)
I'm looking for tips and best practices on installing components for a turbine. The last one I installed was a JM VT-80, so only a fuel pump and ECU battery needed placing. My next install is JC Rabbit with solenoid valves, ECU, pump, battery, etc., going into an F-16.
There must be an existing article or thread out there. I haven't found it yet.
I found the links below from an older post but they don't seem to be working...
[h=2]RE: Anyone have install pics of a Skymaster..[/h]
Thanks for help.
Thanks for help.
My Feedback: (45)
The Jet Central instructions are great with plumbing and electrical schematics. I found other info on high flow fuel systems at bvmjets.com and testing fuel systems at dreamworksrc.com. My main concern is avoiding RF interference. I’m using Futaba 2.4 and I know turbine manufacturers are making components better than past years with respect to RF.
I plan to keep the receiver toward the front. Any other good rules of thumb?
It can depend how the centre of gravity works out.
Nobody likes shovelling lead into a model & these components (particularly the header tank full of fuel,
ECU battery & pump) are quite heavy. Not sure how the Skymaster F-16 balances.
I try to keep all turbine wiring on one side of the model & radio wiring the other, receivers away from any carbon.
John.
John.
FL
For guidance, why not contact some experienced waiver holders in your area?
The AMA website has a list of turbine waiver holders for the entire USA, sorted by state. There are quite a few waiver holders in the Minneapolis area, and there are no less than 18 model clubs in that general area. That way you can see how others do it, and combine that with knowledge gained from other sources.
http://www.modelaircraft.org/MembersOnly/pdf/510-M.pdf
I try to place all my plumbing in the same area thats accessible.. I also have a 5 min rule.. I need to get to any component in 5 min, so I don't bury things under other things when able.
As far as antenna placement, one satellite of any radio brand should be in the nose.. the placement of the others is subjective and takes experimentation.
Engines need cool air and need to have outlet for it around the tail pipe, so let it breath.
stick your smoke stick out the back where if it drips, it won't wet the model inside.
If your ECU cuts off at an intermediate voltage, don't put a smoke pump or something like it on your turbine batt.. If your ECU doesn't cutoff once it runs, then a smoke pump on the batt is ok.(xicoy) for example..
Best advice: find some experienced jet guys and learn from them.. a lot of lessons are hard knocks.. a 30 cent part can cost you a 5000$ plane..
My Feedback: (45)
I know what you mean Goose, every detail matters. My first turbine flight included a flameout ten seconds after takeoff. The cause was a fuel fitting that let loose. Inspection by a seasoned jet flyer might have caught that, but then again this jet was built by a seasoned jet flyer. I bought it unflown and ready to go. It landed just fine, and since then I have learned that I am completely responsible for whatever I put in the air regardless of who has worked on it.
So I appreciate the instruction and advice. I’d rather learn from the experience of others than go through it myself!
