Reload this Page >
Ultra Lightning / P-200SX installation
Old 03-29-2016, 05:04 AM
i3dm
My Feedback: (51)
Default Ultra Lightning / P-200SX installation
Hello guys,
for those with the above combo, what distance did you mount the P-200SX tail cone from the straight edge of the tail pipe inner tube?
at 20mm, the P-200 is very close to the front of the bypass... a bit worried it would come short on cool air around the turbine.
thanks.
Old 03-29-2016, 09:53 AM
racer8297
My Feedback: (13)
i3dm,
My UL has a Mammoth mounted in it and the distance to tailpipe is 1 inch or 25.4mm. My pipe is a Tam pipe, BTW. I know it's not a P200 but it's close and nobody chimed in, so I hope this helps.
Old 03-29-2016, 11:13 AM
Dave Wilshere
I was going to say 30mm. You can cut ducts into the by-pass to increase air throughput.
Old 03-29-2016, 11:48 AM
i3dm
My Feedback: (51)
Hi Dave,
with 30mm i think the front face of the turbine will touch the inner front of the bypass.
are you sure about this number?
Old 03-29-2016, 11:52 AM
Dave Wilshere
That's the sort of gap the turbine wants between tailcone and tailpipe, with such a big turbine it might be difficult...you need a P-220 Rxi-B :-)
Biggest gap you can get...
Old 03-29-2016, 12:12 PM
i3dm
My Feedback: (51)
agreed, make me a trade in deal
Old 03-29-2016, 12:15 PM
Dave Wilshere
:-) No, hot property!
Old 03-29-2016, 04:34 PM
BlueBus320
My Feedback: (57)
Default I've done this before to get extra air flowing around
Bypass mod, before and after paint
Name:	Ultra flash bypass.jpg
ID:	2155034   Click image for larger version
Old 03-29-2016, 10:04 PM
izzy
Dave
if using the full bypass,all the air is directed into the closed bypass
where would the other air come from , assuming using all doors
Old 03-30-2016, 02:27 AM
Dave Wilshere
All the little gaps add up to a lot of area!
Dave
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
