Kingtech presents the all new T1 sports jet
#2652
First off I really like your custom scheme, that looks so good 👍
Great job flying those nice slow rolls and point rolls, lots of finesse there.
I like your lights too 🙂
#2655
Hi guys. How you take care of the fuel system in your jet after the season. Will it be enough to just drain the fuel from the fuel system? Are you using a fuel stabilizer?
I pour a fuel stabilizer in my 3D acrobats before the last flight. I'll do the last flight and then I'll drain all the fuel from the fuel system.
How do you do this in turbines. ***winter***
#2656
My Feedback: (53)
Our winter are pretty long as well......I treat my fuel..summer or winter for algae, for the winter I empty the tank....as much as I can....always have some fuel remaining and keep the UAT full.....just like after any flying day/weekend....
I always do some maintenance during the winter....which at one point I will be emptying the uat so I can disconnect the fuel tank and have a look inside, inspect the line ect.....then reassemble and fill the uat again ready for the next season....
the first run is at home to make sure everything is running well.....then it’s ready..
#2657
-So, exhaust everything.
-Keep the UAT full of fuel even in the winter months when it is not flying.
-Drain the UAT before the season to check the tank and lines.
-Refuel the UAT, refuel the tank, perform an engine test on the ground.
-If everything is ok, it can go into the air.
Did I get that right? ***winter***
#2658
My Feedback: (53)
#2659
OK thanks. Unfortunately, it is not available on the European market. Shipment from the USA goes in Covid at the time of the month. I will try to find a similar product on the European market. ***winter***
#2664
My Feedback: (20)
What are you guys using for clunk line inside the tanks? I've ordered several different sizes of Viton from McMaster-Carr because that's what I'd prefer to use but the metric stuff is only 1mm sidewall thickness and I think it could collapse. What size are you guys using?
#2666
My Feedback: (20)
My rule of thumb is 1/8" ID up to 160N, 3/16" ID up to 220N and 1/4" ID over 220N. Just my preference mostly based on reference to Oli's fuel systems blog. I've done 160N and 180N on 1/8" with no problems years ago but today I wound recommend 3/16" for 160 to 180N. Just my opinion.
Gary
Gary
#2667
Hello guys
Have you seen the assembly of the T-one in a Spanish forum in milliamps
I leave the link
https://www.miliamperios.com/foro/mo...orghini-289247
I leave the link
#2674
#2675
I use KT140G2. I think it's the ideal power / weight ratio.
According to the PowerBox GPS, the speed of the model is 296 km / h. If I focus on reaching the maximum speed, reaching a speed of 300 km / h should not be a problem. ***winter***
