Reload this Page >
Kingtech presents the all new T1 sports jet
Old 08-19-2021, 10:43 PM
  #2826
Histrion
Hi Guys
Excellent repair work
Old 08-21-2021, 07:21 AM
  #2827
winter1
winter1's Avatar
Originally Posted by camss69 View Post
I switched to Jeti 3 years ago after running JR for over 20. Love Jeti and can’t really see myself ever going back. I was one of the first in my area to make the switch and now there’s quite a few Jeti flyers.
When you buy a Jeti, you won't need to think of another Tx. You will have the best. I also had JR for many years, in fact I still have it here. I use it on the simulator when the winter evenings are long. ***winter***
Old 09-08-2021, 10:12 AM
  #2828
Fins
Default Weak main strut springs
My main strut springs seemed to have weakened over the past two years to where the left strut is almost fully compressed when the plane is sitting on the ground. (Plane weight is 30 lb with UAT full and main tank 10-20% full.) I usually like for the struts to be compressed about 20% when sitting on the ground (fueled) , but mine are compressed about 50% and 90%! I removed the weakest spring and stretched it out from about 70 mm to 80 mm. There was little if any improvement. The stock springs seem to have too low an elastic limit and perhaps too low a spring constant. I do not see replacement springs on the PRCJ website but have emailed Dirk inquiring. Has anyone found a source for better springs (higher spring constant and higher elastic limit)? Or an alternate solution?
Old 09-08-2021, 05:31 PM
  #2829
Desertlakesflying
My Feedback: (28)
Riiiiiiiight..... Jeti isn't used as often as others, but I have seen many crashes with them when I do see them. Saw one wipe out 5 grand worth of planes in one day. Keep being a fanboy.
Old 09-08-2021, 08:06 PM
  #2830
jvaliensi
What were the causes?
I've been a Jeti user for five years. Any failures I experience were traced back to user error (that's me).
I am always interested in learning about failures.
Old 09-09-2021, 05:10 AM
  #2831
Dansy
My Feedback: (53)
Dansy's Avatar
‘Our jet field is almost 100% Jeti’s a not a single crash so far…..been in Jeti since 2012/13…..and all the plane I lost, I can honestly say…that was my fault one way or the other…
Im not a fan boy, but I wouldn’t fly anything else either, been Futaba and JR before…..flying since the early 80’s
Old 09-10-2021, 03:40 AM
  #2832
winter1
winter1's Avatar
99% of it is a user error. Either the wrong setting, the wrong installation, the wrong combination of electronics of different brands or has both hands left, which few will admit. ***winter***
Old 09-11-2021, 12:01 PM
  #2833
camss69
My Feedback: (46)
camss69's Avatar
Pretty sure we are at the same jet event this weekend which is being completely dominated by Jeti pilots. I was going to take a count and there’s too many to count.
Dansy (09-11-2021)
Old 09-12-2021, 01:45 AM
  #2834
ledd4u
My Feedback: (23)
Man, I just spent thousands of dollars on DS-24 with all the bells and whistles! All new RX’s for all my models, thousands of dollars! Now it’s all for sale at a reduction. Back to my Futaba 8U FM PCM 75 mhz stuff. I am done with Jeti!
Old 09-12-2021, 04:01 AM
  #2835
Dansy
My Feedback: (53)
Dansy's Avatar
‘I’m guessing your lacking support in your group? I have help many transition to Jeti, most are extremely happy…I also help many far away from home…it’s not a difficult system, and it’s very robust, but there’s a learning curve associated to it like anything else…..
Sorry to hear this….
Old 09-12-2021, 04:06 AM
  #2836
ledd4u
My Feedback: (23)
It was meant to be a sarcastic reply to the reply about crashing
Old 09-12-2021, 04:23 AM
  #2837
Dansy
My Feedback: (53)
Dansy's Avatar
ah I see it wasn’t sarcastic enough….LOL
Old 09-13-2021, 02:41 AM
  #2838
ledd4u
My Feedback: (23)
Ordered a set of electrons for the T-1. No issues with my air originals, just wanted the electrons. Took one week because they needed to fabricate them per Adrian at Electron. Took 2 days to arrive via DHL.
Old 09-13-2021, 05:29 AM
  #2839
smcharg
smcharg's Avatar
All,
I have placed my T1 for sale fully loaded and RTF if you know anyone that may be interested. I love this jet but I'm moving on to a bigger jet that's easier for me to see and fly F3S with. https://www.rcuniverse.com/forum/market/11693338
This is an amazing jet and I'm sad to let it go already.
Scott
AEROSHELDON just so you know, I never forgot about your request concerning Mercury iGyro settings but I never got to it. Life kept me from getting the flights on this thing to finally turn on the gyro and it certainly doesn't "need" the gyro. If no one bites and I wind up keeping it, when I finally do get to the gyro, I'll still remember to let you know.
Old 09-20-2021, 07:41 AM
  #2840
Histrion
Hi guys
Very good retractable electron
Old 09-26-2021, 04:15 PM
  #2841
MarkF
This is my first turbine build and I'm about done. Just need to connect my radio to my turbine and add fuel so I can check CG. I'm happy with how everything came out and should be ready to fly in a week or two.
Old 09-26-2021, 09:07 PM
  #2842
Zeeb
My Feedback: (41)
Zeeb's Avatar
T-One Sport Jet combination bag for sale.
My T-One met an unfortunate demise on it's Maiden flight so I have a basically unused T-One sport jet transport bag. These are about $195.00 at Pacific Jets IF he has them in stock which he does not currently have nor has he had for quite sometime.
$200 plus shipping and PP fees.
Old 09-27-2021, 12:50 PM
  #2843
Tip22v
sorry to hear about your loss, what happened?
Old 09-27-2021, 04:20 PM
  #2844
Zeeb
My Feedback: (41)
Zeeb's Avatar
My builder guy who does all the Maiden flights, got the ailerons reversed. Went into the dirt just off the departure end of the runway, inverted.
Old 09-27-2021, 04:33 PM
  #2845
Tip22v
So sorry to hear that. I did that on a gas powered plane a few years back, tough way to lose a plane. In my case I had flown the plane many times then decided to upgrade the aileron servos, I had no idea at the time that different manufacturers swing the servos differently depending on the signal. Went from Futaba to Hitech and got some expensive wisdom that day.
Old 09-27-2021, 08:13 PM
  #2846
winter1
winter1's Avatar
Sometimes it happens. I know how you feel.
Hi Tom /Tip22v/, I haven't "seen" you here in a long time. ***winter***
Old 09-28-2021, 06:27 AM
  #2847
Tip22v
Winter, I’m still flying my T1 jets as often as possible, but I’ve also been converting and flying small micro jets Hope you are doing well. -Tom
Old 09-29-2021, 12:30 AM
  #2848
winter1
winter1's Avatar
I'm doing well. As soon as the weather is nice and I have time off, I go flying. It is necessary to use every moment, bad autumn weather is just around the corner. ***winter***
Old 10-04-2021, 06:48 AM
  #2849
camss69
My Feedback: (46)
camss69's Avatar
Here are a few pics from yesterday, great day at the field! Weather is finally getting good again.
The following 2 users liked this post by camss69:
smcharg (10-04-2021), winter1 (10-05-2021)
Old 10-04-2021, 03:36 PM
  #2850
MarkF
I did the maiden of mine yesterday and got 3 great flights. I have a CRX Swiwin 190 in mine and couldn't be happier with my motor choice. This is my first turbine jet and was my first time flying one.
The following 2 users liked this post by MarkF:
camss69 (10-05-2021), winter1 (10-05-2021)
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
