Reload this Page >
Kingtech presents the all new T1 sports jet
Old 01-23-2020, 10:23 AM
  #2101
camss69
My Feedback: (46)
camss69's Avatar
I bought the servo arm package deal Dirk has on his site. I usually use SWB but these seem nice as well.
I went with brushless Savox for the control surfaces and 1270ís for flaps.
Still waiting on the airframe, all I can do is look at the rest of the parts lol.
Old 01-23-2020, 10:28 AM
  #2102
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Those do look nice
Old 01-23-2020, 10:38 AM
  #2103
winter1
winter1's Avatar
They look nice. Also waiting .... ***winter***
Old 01-23-2020, 01:11 PM
  #2104
ledd4u
My Feedback: (23)
Just started mine today. Took care of the fuselage half by using the blue locktite.
How did you guys secure that front nose piece to the fuse? I donít see 6 Allen type bolts. I see 5 but not 6.
Old 01-23-2020, 01:22 PM
  #2105
winter1
winter1's Avatar
I like this color scheme. It is easy to see. I have it in production. I can see that the wings are ready for the lights. Is there any other lighting accessories. ***winter***
Old 01-23-2020, 02:39 PM
  #2106
Dansy
My Feedback: (53)
Dansy's Avatar
All I used was Servo screws the black plate is glued to the nose part....I have since then stop using the additional battery, made a small Harness to used #2 Battery..build 2017/18
I never used loctite with blind nuts....I used a bonded washer, start using long ago on gas plane...they are called crush washer I think..
Old 01-23-2020, 04:16 PM
  #2107
ledd4u
My Feedback: (23)
Excellent thanks! Going to remove the kingtech insignias from the jet. Getting the paint matched tomorrow.
Old 01-24-2020, 04:16 PM
  #2108
ledd4u
My Feedback: (23)
All the kingtech and T-1 Model paint, GONE!
Old 01-24-2020, 04:28 PM
  #2109
cbk07
My Feedback: (64)
  • Looks great! Did you use single stage or base clear? Love that scheme too
Old 01-24-2020, 04:47 PM
  #2110
ledd4u
My Feedback: (23)
PPG Base clear with PPG 2021. Thanks
Old 01-25-2020, 07:57 AM
  #2111
Tip22v
I have the same color scheme, can you post the color info that was matched?
Old 01-25-2020, 08:41 AM
  #2112
ledd4u
My Feedback: (23)
Let me check if itís on the paint cans.
Old 01-25-2020, 08:43 AM
  #2113
ledd4u
My Feedback: (23)
bought the same stuff.
Old 01-25-2020, 10:59 AM
  #2114
ledd4u
My Feedback: (23)
No codes on my cans. I took my hatch to the paint store and had them match it.$47 for all three colors.
Old 01-25-2020, 02:55 PM
  #2115
Tip22v
what kind of paint store? Specialty auto paint? Is the paint lacquer based? Sorry for all the dumb questions, I donít know much about paint but would like to be able to match paint my replacement nose gear door. Thx.
Old 01-26-2020, 03:48 AM
  #2116
ledd4u
My Feedback: (23)
PPG DBC base coat with PPG 2021 clear coat. But you can use any type of 2k clear. No lacquer paint used. I donít believe Pacific jets uses lacquer. The clear they use is hard 2k type. Dirk might know more. Itís definitely great paint they are using. I was able to apply the PPG clear and melt into the original paint using my final coat of clear reduced considerably. 4 to 1 reduced to clear final melt. My paint supplier has PPG, RM(BASF) and a lower cost base coat. I am just used to using PPG stuff. Take the hatch to the automotive paint store and they will match it using an electronic type device. The silver, red and white were extremely close. Good luck.
they might have the ability to fill cans for you. My paint store does. Honestly, I went in to get the spray type custom mix base coats and 2k clear. They were out of the cans. I used my paint gun.
1. Get the paint matched.
2. Ask them to fill into aerosol cans
3. Get the 2k clear gloss. 2k is urethane clear, with activator built in.
Old 01-26-2020, 05:14 AM
  #2117
bodywerks
bodywerks's Avatar
Originally Posted by Agrav8ed View Post
Still waiting for my thrust vectoring to arrive. In the meantime I got my plumbing completed, smoke installed, gps, 160n turbine, receiver and smoothflite installed. Can't go much further until I balance it and figure out were to put the batteries. I primarily went with the Smoothflite because it has a thrust vectoring feature that works with the gyro. Trying to wait for the new thrust vectoring set up so I wont have to balance twice but I may just go ahead and finish everything up
Tone.
I see you put a Swiwin in her
Have you flown it yet or have an all up weight? I'm looking for a summer project and am deciding between this and a Rebel Classic.
The PnP features of the T1 are attractive, and it's slightly larger than the classic, but size for size I think the Rebel will be significantly lighter, being painted in the mold, and purchasing is less painful, in that you only need a 50% deposit, and typical time between order and to your door is around 10-14 weeks if you go the container route, and only around $100 for shipping. 4 weeks less if you do EMS shipping. Whereas having to pay in full for the T1 and also having to wait significantly longer to get it is a little harder to swallow.
Decisions, decisions. I can't really hold the order prices against the jet, though, as I don't need it now. I think how it's finishing out, weight wise, will be my deciding factor.
Old 01-26-2020, 05:52 AM
  #2118
Dansy
My Feedback: (53)
Dansy's Avatar
They can build light or heavy.....it’s all in the selection of parts and what you want to stuff inside any jet......the quality of T-One model is superior to CARF any day of the week. Better paint, better wood, better hardware......all usable.
Old 01-26-2020, 06:18 AM
  #2119
bodywerks
bodywerks's Avatar
Originally Posted by Dansy View Post
They can build light or heavy.....itís all in the selection of parts and what you want to stuff inside any jet......the quality of T-One model is superior to CARF any day of the week. Better paint, better wood, better hardware......all usable.
I have a Rebel HOT, and personally, prefer the painted in mold look, as it is completely smooth(no high spots at paint trim lines). It is also lighter. I am very happy with the overall quality, but I've seen the T1 close up and it's nice, too.
Been scrolling through the thread and only found one eight report of 30lbs.
I have a predator 2.2m at 29lbs less main tank fuel and a 170 turbine. I consider the power to be sufficient, but not exhilarating.
I don't do smoke and I typically only use three batteries total. If I could get this at 26-27lbs I would be happy.
Old 01-26-2020, 08:04 AM
  #2120
Tip22v
Thanks for the help! Iíve got a spray gun if needed, but hopefully I can get them to fill the aerosol can. -Tom
Old 01-26-2020, 08:34 AM
  #2121
cbk07
My Feedback: (64)
This clear works amazingly well alsoif you want to avoid buying a larger quantity of clear/hardener
https://www.amazon.com/dp/B00W2D806Y/?coliid=I2ZG0JXWRCJ9UL&colid=SVCIWI0GOCQL&psc=1&ref_=lv_ov_lig_dp_it https://www.amazon.com/dp/B00W2D806Y/?coliid=I2ZG0JXWRCJ9UL&colid=SVCIWI0GOCQL&psc=1&ref_=lv_ov_lig_dp_it
Old 01-26-2020, 09:17 AM
  #2122
ledd4u
My Feedback: (23)
Originally Posted by cbk07 View Post
This clear works amazingly well alsoif you want to avoid buying a larger quantity of clear/hardener https://www.amazon.com/dp/B00W2D806Y...v_ov_lig_dp_it
Yes thatís the one! I have used it before it works fantastic. Itís a great product for those whom donít have the spray gear. One tip is after you use it, place it in the freezer. It will last 4 additional days.
Old 01-26-2020, 10:20 AM
  #2123
Tip22v
Excellent! I did some searching and found an Automotive Paint store only 2 miles from my house, they even have a PPG color workstation so hopefully they will be able to match the colors. I donít know yet whether or not the can make up aerosol cans yet, Iíll find out tomorrow when they open. Thanks again for all the help, much appreciated -Tom
Old 01-26-2020, 01:35 PM
  #2124
Agrav8ed
I live in the northeast so there have not been very many good flying days in the last few months. I have it set up and ready to go, but I have not done a final balance or a weight yet. Have been waiting for the thrust vectoring issue to be resolved first. I was hoping it would come in soon but at this point it will probably be a minute. I will most likely balance a test fly it this spring.
Tone
Old 02-02-2020, 03:45 AM
  #2125
ledd4u
My Feedback: (23)
I have the air system for retracts. Just saw a JP electric set for under $400! JP system but I donít see to much information on the use of these. Are they not as good as the electrons?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
