Reload this Page >
Kingtech presents the all new T1 sports jet
Old 02-22-2020, 01:19 PM
  #2176
clavin
clavin's Avatar
Originally Posted by winter1 View Post
Then it's ok. The value is set to 0600. ***winter***
Are you taking about the Pump Limit???
Old 02-22-2020, 01:31 PM
  #2177
winter1
winter1's Avatar
No. This value is factory set in telemetry. As I wrote telemetry was purchased to the turbine as an optional accessory. The manufacturer did not know to which turbine the telemetry would be sold. Therefore, I think the set value is not correct. But I can be wrong ***winter***
Old 02-22-2020, 02:53 PM
  #2178
clavin
clavin's Avatar
It should be fine.. Play with it .. The easiest way is to run 1 liter of fuel and the check to see if the Telemetry unit is saying you burned 1 liter of fuel... Above you said int he "ECU" .. The ECU = Engine Control Unit
Old 02-22-2020, 03:34 PM
  #2179
causeitflies
causeitflies's Avatar
Did you see pg.4 of the telemetry manual? It may be a little confusing.
Old 02-22-2020, 11:32 PM
  #2180
winter1
winter1's Avatar
The 0600 is set directly in KingTech telemetry / appears on first start /. At the same time, this value is also mentioned in the manual, as you say. ***winter***
Old 02-22-2020, 11:43 PM
  #2181
winter1
winter1's Avatar
Yes, that would be a way to set fuel consumption.
I thought, that is for each turbine / 45, 85, 120,140 .... / some approximate value is given in advance. At this value, the setting could be started. Then just fine-tune. ***winter***
Old 02-23-2020, 01:38 AM
  #2182
winter1
winter1's Avatar
So I have an answer. The default value for the "Pump Factor" setting for the turbine K 140G is 0420. After 3-4 flights will need be adjusted.
The information was sent by JMB-Jets - KingTech Turbines representation for Europe. Thanks. ***winter***
Old 02-25-2020, 02:52 PM
  #2183
Tip22v
If you are looking for some kind of low fuel alarm, Jeti has an actual fuel flow meter that works really well (I have one). If you want something less expensive ($39) you can use a Jeti MUI current sensor, I use one of these on another jet and find it to be fairly accurate for measuring fuel burned. In both of these jets I have an alarm configured on my DS-24 to alert me when my fuel is low and it's time to land. - Tom
Old 02-25-2020, 03:26 PM
  #2184
Johnny9390
My Feedback: (34)
I thought telemetry just reads ecu info and allows the info to be sent to the rx and thus radio.
Old 02-25-2020, 09:29 PM
  #2185
Desert Fox 1
Cheers!
Desert Fox 1
smcharg (02-26-2020)
Old 02-25-2020, 10:32 PM
  #2186
winter1
winter1's Avatar
Nice flying.... ***winter***
Old 02-25-2020, 10:34 PM
  #2187
winter1
winter1's Avatar
Originally Posted by Tip22v View Post
....., Jeti has an actual fuel flow meter that works really well (I have one). ....... - Tom
Yes I know, also one of the options. Thanks ***winter***
Old 02-26-2020, 02:27 AM
  #2188
Dansy
My Feedback: (53)
Dansy's Avatar
The best engine Telemetry by far for Jeti is the Digitech CTU.....with the LUA app if your on the DC/DS 24....
In the past I have used Xicoy and Kingtech engine telemetry devices .....and they both lack one thing....LUA app that emulate the GSU.
Old 02-26-2020, 03:45 AM
  #2189
ledd4u
My Feedback: (23)
Jetti? I still have my old JR 12X ainít buying any of that stuff. Best radio ever made period!
Old 02-26-2020, 04:18 AM
  #2190
Dansy
My Feedback: (53)
Dansy's Avatar
I had a Jr12X and while it was ok.....itís like living in the deep in the wood with no electricity, no internet....and just a AM radio to listen to CBC......LOL
Old 02-26-2020, 06:06 AM
  #2191
winter1
winter1's Avatar
I also switched from JR to JETI. RC world of limitless possibilities. I'm not saying it's simple. Some things need to be understood. Then it is a joy. ***winter***
Old 02-26-2020, 02:59 PM
  #2192
ledd4u
My Feedback: (23)
Címon man. Itís an awesome setup! Vintage.
Old 02-26-2020, 03:38 PM
  #2193
Dansy
My Feedback: (53)
Dansy's Avatar
Talking
Nope....it Was awesome in the 19 century.....in the 21th itís just old LOL
Old 02-26-2020, 05:46 PM
  #2194
camss69
My Feedback: (46)
camss69's Avatar
I had a 12x too and loved it! Had*, 10 years ago...
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
