Reload this Page >
Bavarian Demon Cortex PRO is here!!
Old 01-31-2019, 09:02 AM
  #701
F1 Rocket
Hi Greg,
Please give me a call and we’ll figure out what’s going on with your system.
Danny
407-687-3126
Old 01-31-2019, 09:26 AM
  #702
PREACHHAMES
My Feedback: (58)
PREACHHAMES's Avatar
Sure thing Danny
It will be later this afternoon 👍
Old 03-16-2019, 09:29 AM
  #703
alfawaz
I finally had a chance to fly my cortex and luckily it was a gust 18mph and I love it!
I still have two questions if someone could chime in.
First
do I need to teach the cortex any knife edge mixes I have in the radio? Or how does that work with mixes that had to do with stabilized surfaces?
second
there is is an option in the software that says “ lock-in characteristics “ what is that and what is it for and what should the values be?
Thank you guys
Old 03-16-2019, 11:00 AM
  #704
F1 Rocket
For small mixes such as those needed for knife edge it’s best to not have these active during the teach in process.
Lock in characteristic adjusts how hard the system stops the movement when the TX stick is returned to center. For example. Do a point roll. If there is a bounce after each point you can lower the aileron lock in to get rid of the bounce.
Danny
Old 03-16-2019, 11:25 AM
  #705
alfawaz
Awesome Danny thank you.
I talked to couple guys at the event I am at and everyone says great things about you and about the gyro. Most appreciated
Old 05-04-2019, 09:10 PM
  #706
alfawaz
Could someone shed some light on an issue I am having with one of my cortex pros. I setup the gains and got it all figured out airplane flies awesome with the gyro on except in knife edge the elevators oscillate like crazy I went into the software and turned down gain on the elevators by 20% but it is still happening. It doesn't happen in hovers, Harriers, slow rolls nothing. Only knife edge flight both fast and slow. I have the cortex pro mounted with the thick supplied double sided sticker.
Thank you
Old 05-05-2019, 02:48 AM
  #707
F1 Rocket
Thank you
What is happening is the Cortex Pro is picking up and responding to a vibration in the airframe. It is not uncommon for this to occur in one mode of flight and not others. Make sure the Cortex Pro is mounted to a rigid part of the airframe. Do not mount it to any part that is flexible and can “drum” with engine induced vibration or deflect under load. In general, unsupported pipe tunnels and rudder servo trays can cause issues. The pipe tunnel is a high source of vibration and rudders trays can twist under load. We have found the best mounting area in a 3D type prop plane to be around the wing tube socket. I also suggest using the thin mounting tape. We have found this works best overall.
Danny
Old 05-05-2019, 06:53 AM
  #708
alfawaz
Danny this helps a lot. I will change the location and use the thinner foam and test it. Thank you so much.
Old 05-12-2019, 10:43 AM
  #709
alfawaz
Danny
like always your knowledge never ceases to amaze me!
I moved my cortex pro from the rudder tray to somewhere more rigid and used the other sticky foam and the issue was gone. In fact I was able to add much more gain than before and this only tells me that the gyro actually was vibrating too much before
thank you
Old 07-14-2019, 12:20 PM
  #710
c_makhija
What’s the frame rate to be selected for Ditex servos?
Chatty.
Old 07-14-2019, 01:14 PM
  #711
Bob_B
Bob_B's Avatar
If you don’t know the servo frame rate set the gyro to 166.
Old 07-15-2019, 04:31 AM
  #712
Dansy
My Feedback: (53)
Dansy's Avatar
Chatty.
333 for those..
Old 07-15-2019, 11:57 AM
  #713
smoknrv4
smoknrv4's Avatar
Can someone point me in the right direction for information on using the software programming for the PC in the Cortex Pro?
Thanks!
Old 07-15-2019, 11:59 AM
  #714
Bob_B
Bob_B's Avatar
Thanks!
What specifically do you need to know?
Old 07-15-2019, 12:41 PM
  #715
c_makhija
Originally Posted by Dansy
333 for those..
Thanks Danny.
Old 07-15-2019, 03:56 PM
  #716
smoknrv4
smoknrv4's Avatar
I would like to know how to navigate through some of the fine tuning in the PC software . I would also like to know how to set up different gain settings in different flight modes.. I don’t find much detail in those instructions, for this.
Old 07-15-2019, 05:12 PM
  #717
Bob_B
Bob_B's Avatar
The PC software is quite intuitive I would say to hook the Gyro up click on the different menus and see what’s there it’s easy to do a reset.
I would suggest actually installing it using the quickset up manual and then with the radio system On you could move the sticks and see the actual radio input.
Old 07-16-2019, 03:33 AM
  #718
smoknrv4
smoknrv4's Avatar
I have it set-up no problem and have been flying the jet, increasing the gains with a slider on the initial flights, flys great! Now I want to get into the software for fine tuning each control surface, flight modes, etc.. and don't want to screw up what I have already. LOL!
I haven't been successful at finding other peoples experiences and procedures.
Old 07-16-2019, 05:00 AM
  #719
Bob_B
Bob_B's Avatar
That's easy. Hookup the PC and Save your current setup. Then you can reload it into the gyro if needed.
Old 07-16-2019, 07:01 AM
  #720
tp777fo
My Feedback: (28)
tp777fo's Avatar
This is what I use on all my jets. FB T33, FB Dolphin, Dolphin S, and SM F4. Made a nice improvement on all. Rolls crisper and locked when you release the sticks.
Old 07-16-2019, 10:16 AM
  #721
smoknrv4
smoknrv4's Avatar
Hey there, thanks for the hint and pic.
What about if you running 3 FM's and you want different gain settings etc.. on each FM? I'm using a DX18.
Old 07-16-2019, 10:34 AM
  #722
Bob_B
Bob_B's Avatar
Different Flight Mode gains settings would be done in the TX.
Old 07-27-2019, 02:42 AM
  #723
c_makhija
Hi Guys,
Have setup the cortex pro with 2 Jeti Rsat2 and a 900mhz Rx and CB200 as per the diagram.
This setup was before V1.31 of the CB200 came out. Now the CB200 can accept the 900 Rx in Ext 1 of the CB.
Do I continue with the old setup or configure it differently? Everything works fine but the jet is still new and not test flown yet.
Regards
Chatty
Old 07-27-2019, 03:02 AM
  #724
Dansy
My Feedback: (53)
Dansy's Avatar
I do the new way now...
RX # 1 & 2 (2.4) into B & A Out 6 & 5
RX # 3 (900) into Ext port.......
Old 07-27-2019, 03:16 AM
  #725
c_makhija
Out 6 and 5 should go where into the CB? And what’s its meant for?
