Reload this Page >
Bavarian Demon Cortex PRO is here!!
Old 05-23-2020, 05:48 PM
  #826
Scott Baker
Great, thanks Danny.
So the 2nd Cortex Pro for the 2 x vector outputs right?
Old 05-24-2020, 03:04 AM
  #827
F1 Rocket
Yes, but you also have enough ports to run all (4) taileron servos through independent channels if you want.
Old 05-24-2020, 11:50 PM
  #828
Scott Baker
I have put Y leads on the 4 Taileron servo's to avoid using a powerbox micromatch or similar products.
Do you think this is worth changing to 4 independent channels?
Old 05-25-2020, 05:01 AM
  #829
F1 Rocket
I prefer running independent channels and being able to match the travels . If you have achieved this with a simple Y connector then you shouldn’t have a problem.
Old 05-25-2020, 07:32 AM
  #830
FenderBean
FenderBean's Avatar
Just so Im not missing something, and Im new to Demon but if I assign both my rudders to the same channel (in the servo) im talking center, endpoint, travel and channel(SBUS) I essentially get the benefit of both rudders with one input on the gyro correct?
My F-22 had sooooo many channels I combined a lot of stuff, rudders, ailerons, flaps all had multiple servos but im on using one channel each in the radio.
Old 05-25-2020, 02:02 PM
  #831
Bob_B
Bob_B's Avatar
Kieth are you running Sbus through out?
Old 05-25-2020, 05:54 PM
  #832
FenderBean
FenderBean's Avatar
Yeah, I got the answer earlier. I was just making sure I didnt miss something in my readings no worries now.
Old 06-02-2020, 12:54 PM
  #833
Tip22v
Originally Posted by DEMONjoe View Post
David, that's another option, but you then loose the gyro-controlled 2.4 backup, which means that every time the primary fails, the CORTEXpro will switch to the 90MHz rx and not to the other 2.4GHz rx, which may still be ok and "connected". And this, as far as I heard, will change control feel at least a bit via the 900MHz. So I would prefer the upper setup over this version.
The perfect solution will be the one to hook up the 900 rx to one of the 2.4 rxs, all signals at any time running through the CORTEXpro. Lets hope the rx firmware will be ready to do so soon.
Does anyone know if the solution mentioned above was ever implemented? I've got two R3 rx, one 900 MHz, cortex pro, and CB200. I would like to be able to connect the 900 mhz rx to one of the R3 rx, then connect both R3 rx to the Cortex Pro and on to the CB200. This would provide gyro stabilization regardless of radio path. Thanks, Tom
Old 06-02-2020, 01:39 PM
  #834
F1 Rocket
We do this using a Rex type receiver as the input into the cortex pro. Typically we only use one REX into port B of the Cortex Pro. Then configure one of the REX’s E ports to EX Bus Backup Input And plug the 900 into it. Ports 5 and 6 from the Cortex Pro typically go to the CB with 6 plugged into rx1 and 5 into rx2. You could also plug a second 2.4 receiver into the CB rx2 port if you want to.
Old 06-02-2020, 03:56 PM
  #835
Dansy
My Feedback: (53)
Dansy's Avatar
Danny, you connecting one RX into the CP B port then out 2 output into the CB (1 in RX1 and 1 in RX2) can you expand here.....with 2 out of the CP?
Old 06-03-2020, 12:02 AM
  #836
F1 Rocket
Outputs 5 and 6 are the same data. Connecting both provides a little extra redundancy. Only output 6 is bidirectional so it needs to be connected to rx1.
Old 06-03-2020, 03:32 AM
  #837
Dansy
My Feedback: (53)
Dansy's Avatar
Danny Thank you, geez there’s a lot of ways to do things with the CP.......
Old 06-03-2020, 05:57 AM
  #838
Tip22v
Thanks, that worked. So I’m good to go with my jets configured with CB200 and Cortex Pro, now I have two jets with Mercury SRS that have no 900 MHz backup, has anyone got a solution using PB Mercury? The problem is the the PB requires UDI.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
