Reload this Page >
Introducing the Top RC Model Odyssey - New sport jet - build thread
Old 12-26-2019, 02:04 PM
  #551
camss69
My Feedback: (46)
camss69's Avatar
Originally Posted by dapreacherman48
mine came with plumbing...
lol
Old 12-26-2019, 09:13 PM
  #552
Dapreacherman48
Well, I label and bag everything coming out of the box so I don’t loose it... it works for me
Old 12-26-2019, 09:29 PM
  #553
camss69
My Feedback: (46)
camss69's Avatar
Oh I thought you were showing it out of the plane because it was junk and you didn’t use it.
Old 12-27-2019, 07:47 AM
  #554
airborn900
My Feedback: (25)
My odyssey and my predator fly very different. The odyssey is more like a pattern style ship and flies perfectly straight lines and does big beautiful aerobatics very well. My predator is better for 3D style maneuvers. It snaps, tumbles, and spins but isn’t as Precise.
i run a Sw140b in the odyssey and find it to be perfect power. I had the 140 in my predator and was underwhelmed. After trying several motors, it took a 210 to make me happy with the predator.
Dry weight with fuel in uat:
Odyssey 29.35lb
Predator 31.45lb
Old 12-27-2019, 01:28 PM
  #555
bodywerks
bodywerks's Avatar
Odyssey 29.35lb
Predator 31.45lb
thanks for the info. I still don't think it flies different enough for my taste and flying style, and I find the predator quite precise, for a jet. 210 in it would be fun! We estimate 175-180 straight and level with my 170, and that's probably all it's comfortable doing. I know it's not a speed jet, but a fast pass is always fun. I'm sure it would be in the Odyssey, too.
I've decided to go a different route and ordered a CARF Ultra Flash Evo, as it's more for speed(as am I) but does point/slow rolls/ loops/knife edge just fine and looks cool doing it, while pushing the 199.9mph stupid USA speed limit.
Old 12-28-2019, 12:30 PM
  #556
i3dm
My Feedback: (51)
Servos: 35kg, 40kg, or 46kg servos?
Im assuming coreless hv ht metal gear servos..,
what are you using (not asking brand but rather specs)
40mmx20mmx27(ish)mm
35Kg/cm is already overkill. have you read my build thread from the start?
Old 05-03-2020, 07:37 PM
  #557
luckymacy
Would someone measure the struts and wheel dimensions? Need it to know if a set I have will fit.
thanks!
Old 05-04-2020, 09:04 AM
  #558
Ceeray
One of my retract goes down only if speed is low. I think the motor is weak and taking too many amps and shutting down. From where I could get a replacement motor ? Factory does not answer mails..
Old 05-04-2020, 11:41 AM
  #559
luckymacy
What specific control surface related hardware such as push rods are folks replacing or is everything more than acceptable in the latest versions of the kit?
Old 05-05-2020, 09:46 AM
  #560
Sky Toys
Sky Toys's Avatar
The equipment that comes with the plane is very well deserved but most of the pilots upgrade the equipment ... and that's fine too
Old 05-10-2020, 05:43 AM
  #561
luckymacy
Originally Posted by i3dm
adding a copy of my post:
Hello Guys,
i would like to share my CG / Throws settings for the Odyssey Sport Jet. these settings would help anyone who is building one have a good starting point.
Note: All measurements are taken at control surface root.
Ailerons: 28mm both ways (will probably add some differential in the future), 45% Expo
Elevator: 28mm both ways, 30% Expo
Rudder: 50mm both ways, 30% Expo
Flaps Takeoff: 25mm with 2mm down elevator compensation
Flaps Landing: 80mm with 4mm down elevator compensation
Cortex Gyro gain: 60%
CG: currently 220mm back from leading edge at wing root, i recommend starting with 215mm.
Total weight with UAT full, full cockpit + pilot figure, 5000 mAh 2S Lipo hardcase Turbine battery and two 2200mAh 2S Lipo Rx batteries - 13.97Kg.
For me these settings make a very easy to fly, very predictable Jet.
I do hope they help others as well.
Thanks for reading,
Lior Zahavi
Edit 16/12/17:
I have tested crow mix with full flaps and it works very well on the Odyssey, and these are the numbers:
with full flaps applied, the ailerons go UP 12.5mm (measured at root) and elevator compensation increases to 7mm down measured at root.
this gives you much more drag, model descends and slows down faster and stall speed is even lower - it works great and is highly recommended.
does everyone else have a landing function to activate the crow function? IF you do a go around with full flaps and crow already going on, how do you gracefully back out crow and full flaps? On another note, how much do you slow your flap movement up and down?
Old 05-10-2020, 05:53 AM
  #562
i3dm
My Feedback: (51)
my flaps and crow take abour 2 seconds for full travel
luckymacy (05-11-2020)
Old 05-10-2020, 10:25 AM
  #563
Jmav7279
If you want a 210 in the Odyssey it would be a blast! The only thing I would caution is the tail pipe. I fly with a SW190 and I'm upgrading to a larger pipe from Gary at Jet Tech. My Odyssey is a bullet already but if I can fit a 1/2 inch bigger pipe...
Old 05-10-2020, 11:11 AM
  #564
Dansy
My Feedback: (53)
Dansy's Avatar
Flight mode...does this for me and flap/elev/crow are set for 1.5sec...
luckymacy (05-10-2020)
Old 05-11-2020, 01:02 AM
  #565
luckymacy
Originally Posted by Jmav7279
Mike at Gator Hobbies is the importer of Top Rc in the US. I fly mine with a SW 190 and love it!
what specific fuel tank fittings are you using and where did you get them and what is that box on top of your tank?
Old 05-11-2020, 02:32 AM
  #566
luckymacy
delete...
Old 05-11-2020, 02:40 AM
  #567
i3dm
My Feedback: (51)
who are you asking?
Old 05-19-2020, 03:30 PM
  #568
Jmav7279
The box is a Spektrum satellite and the fittings are 6mm M5 Festo compression barbs so no more safety wire!!
luckymacy (05-24-2020)
Old 06-08-2020, 02:03 AM
  #569
snir2001
snir2001's Avatar
Looks nice in the pictures, got nice feedback here and remind me the SM Dragon G2 by shape, that i really like, so I purchase one, just because...
Now, after about 60% ready, I just wish it will fly good, because the kit itself is crap.
No QC what so ever.
I got a defective wing (That replaced by SkyToys, great service from his side).
The pain job is amateur at best, ****ty 3D printed case for the retracts controller (I designed new one), low (very low) quality of the plywood parts (cracking and de-laminating sound is part of the build process).
One of the hinges from the rudder was broken, and the paint peeled of off the cockpit.
The inside of the fuselage looks like they had no idea how to put the fiberglass in the mould...
Two of the six nuts that connecting the two fuselage parts are defective.
The accessories are, well, you know... So I replaced them with something descent, from HobbyKing and so on.... many other small crappy things.
This kit is a toy grade crap!
Even the early jets from JL where better quality.
But it came well packed
If someone is in the market for an Odyssey, mine is for sale.
Old 06-08-2020, 02:13 AM
  #570
bodywerks
bodywerks's Avatar
I have seen a couple u close. You 'kinda' get what you pay for. A couple friends picked up a couple Aspires back when they were on like a $1250US "flash" sale. IMO, that's about what they are worth with shipping included. I like the looks of the Odyssey, and it flies OK, but glad I went with a CARF Rebel classic instead.
snir2001 (06-11-2020)
Old 06-08-2020, 03:36 AM
  #571
snir2001
snir2001's Avatar
Yes, but...
The "low cost" should not mean ZERO QC.
Mine was with a defective wing, the skin was NOT attached to the profiles.
Anyway, Toprc is not in the same league as CARF, even FB is light years ahead.
Old 06-08-2020, 04:05 AM
  #572
clavin
clavin's Avatar
I agree 100% this stuff is junk.. Look at the the formers in the wings.. Mine were so bad it took me a week to get in there and epoxy them to the skins.. This is a poor quality product!!
Old 06-08-2020, 04:31 AM
  #573
snir2001
snir2001's Avatar
I will keep building it, and if no one will buy it, I hope it will fly good.
If it will, than I will sand the crappy paint job, and I will give it to my 10 years old son to paint it again, I'm sure it will be much better!
Old 06-09-2020, 12:43 AM
  #574
i3dm
My Feedback: (51)
Some cool action shots taken by the Sky Architect Avgar Idan, last weekend in Mevo Horon with Team Jet Israel.
Old 06-09-2020, 01:54 AM
  #575
snir2001
snir2001's Avatar
The rudder is perfectly centered, but the vertical fin itself is warped.
It's getting worse by the minute...
What a pile of crap.
