Fueling Can Suggestions
My Feedback: (59)
I recently started flying turbines. I'm using a older Jersey Modeler 5 gal fueling jug. The Jet A nozzle will not fit into the mouth of the jug and it's a hassle to fill without making a mess. I know Jersey modeler makes another jug with a larger mouth. It doesn't look like it would be large enough either.
What are you guys using??????????????i
This is what I used when getting Jet A. The mouth is wide enough to fit the nozzle and you can mix in this container and transfer to jersey modeler.
http://www.jegs.com/i/JEGS/555/80211..._klxoC80Dw_wcB
Patrick
CA
Part of reason I just use diesel or kero now. JetA nozzle is meant for filling hundreds of gallons on large full size jets. But Jegs or Scribner type cans can accept the nozzle. Due to flow rate, it's unlikely a shallow funnel would work.
My Feedback: (99)
I have the can at the very top with the big mouth on it
http://www.jerseymodeler.com/id28.html
but I have not filled it with Jet A yet. I still think I might stick with Diesel as a fuel even in the Jets Munt.
My Feedback: (40)
Some of the guys like Mr. Funnel because it filters and separates out water. Its kind of a pain though because it leaves several ounces of fuel in the funnel when you are finished.
Personally, I just use a plain large mouth funnel. Controls splash and can also be used when adding oil.
Craig
Craig
Dunno what the dimensions of a JetA nozzle are, but I used to sell it. Best I can recall, there'd be no problem firing that nozzle in the Jersey can I own. I'd measure the nozzle and call Jersey to ask what they have that's compatible.
On a different but related note: Unless something is driving you specifically to JetA, consider Kero. While not as bad as diesel, JetA stinks up the place if you have even a small spill in your shop or vehicle. Kero doesn't smell like roses, but it isn't nearly as bad as the other two.
Craig
Craig
