Reload this Page >
Battery Recommendation, Skymaster Bae Hawk (1: 3.65 scale)
Old 05-16-2017, 06:44 PM
vespino67
Default Battery Recommendation, Skymaster Bae Hawk (1: 3.65 scale)
I'm setting up a Skymaster Bae Hawk (1: 3.65 scale), all servos (8) are HV
I need to leave the batteries for the receiver permanently on the jet.
I think my choice would be LiIon batteries.
I've been thinking about a couple of Fromeco 5200mAh LiIon or a couple of PowerBox PowerPak 5.0x2 Pro Battery 5000mAh
Will be enough ?
What would you recommend?
Thank you
Old 05-16-2017, 06:54 PM
gooseF22
gooseF22's Avatar
depends on if you are using electric gear/brakes..
I would use 3 5200 for it.. two for the radio pack, and one for the gear/brakes. if I had to bury it.
Another ion option is the Jeti packs. you can parallel charge all three with one charge lead.
Old 05-16-2017, 07:02 PM
vespino67
I'm using air gear/brakes. Thank you
Old 05-16-2017, 07:16 PM
gooseF22
gooseF22's Avatar
If you are going to add a bunch of accessories, then use a separate pack for that.. lights, cockpit..sound...etc In other words I use my receiver packs for driving servos and nothing else for big project like this.
Old 05-16-2017, 07:21 PM
vespino67
The receiver packs are for 8 servos HV and 3 air valves only.
Thank you
Old 05-16-2017, 08:30 PM
digitech
My Feedback: (10)
digitech's Avatar
Thank you
get the Jeti 5800 Lion safety first!
1 . no need for balancing
2 . they have a build in FUSE (125 amps) in the cell itself in case of a shortcut they just disconnect the whole pack.
3 . very Light
4 . they use Sony Cells....
Old 05-17-2017, 05:15 AM
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
2x https://www.powerbox-systems.com/pro...y-4000-jr.html
on a powerbox. I run 15 servos on a 170cc giant aerobatic with no problem
