Skymaster 1:7.5 F-4 Phantom
#303
Shaun
I ordered new wings for my F4 that were damaged in flame out. The pieces pictured I ordered from Skymaster. They installed pretty straight forward and new wings are good to go after paint and weathering to match my older F4. Ended up ordering another one and I finished both at same time. Just went to Doc for my new glasses which I'm waiting for to do maidens on both
Kevin
Kevin
YellowAircraft (12-06-2021)
#305
Shaun
Kevin
Kevin
Mike
#308
Hi,
About to start building one of these and I have a few questions for you guys: What unholy, demonic fluid (lube of some sort) is this they use inside these gear? I can't clean this crap off of anything. I've wiped it with acetone, IPA, bug-juice cleaner... no bueno. It looks like it's gone, but then you can see it the next day. And it transfers easier than my money to my wife's credit card accounts. Any tips would be great because I don't see how in the world I'm going to be able to paint these struts with this stuff everywhere.
Did any of you use button valves on the pneumatic doors? Servos? I'm planning to use BVM air quick-connects, but I don't want to have 5 of them hooked up.
#309
My Feedback: (15)
Replacement formers
Hopefully I’ll have better results asking here
I have a second hand phantom that someone did an electric conversion and cut away the engine bay formers.
ive contacted sky master with no help
does anyone have a tracing of the formers or a wrecked one that I can pattern
#312
"Did any of you use button valves on the pneumatic doors? Servos? I'm planning to use BVM air quick-connects, but I don't want to have 5 of them hooked up"
Hello Shawn,
With regards to your question about Retract setup.
I am building the 1/6 scale F4 at the moment and did not want all the connections either.
I will be using 2 x Ultra Precision UP3 Air Valves.
One for the Nose Retract & Door that will be mounted in the front.
One for the Main Retracts & Doors which I will mount inside the wing.
This way I only have one air line to connect between the Wing & Fuse for the retracts.
Running 4mm OD tubing for the air feed and will just use a festo fitting for the connection.
PS. Also changing the skymaster Gear Door cylinders to Ultra Precision brand cylinders.
Regards
Bruce
Hello Shawn,
Regards
Bruce
#317
Hello shaun,
Yes the cockpit does not fit with retracted nosegear.
Also ailerons are jammed when flaps are down (one is top hinged,other bottom). The formers are glued in without the tanks being installed, making it impossible to install them. I am very very unhappy and it needs lots of work to get to a satisfactory level.....
I lost interest because i wanted a quick flying arf,and its been sittin on the shel untouched ever since delivered and inspected.....
Cheers hank
Cheers hank
#319
Hello shaun,
Cheers hank
Cheers hank
#320
Hello kevin,
All is glued with those whiteish resinish goo poodles, nothing with bolts, and no way to insert the tanks. I will throw them out anyway and go for bag tanks, so i dont care anymore, but for me the "ARF" in this F4 kit stands for "AlReady F§%$ed-Up". I will throw out all pneumatics and connectors, overdo the wing hinging, get the gear electric with hydraulic brakes, replace the banana thrust tube with one that ends straight and see if it can be finished in a somewhat good manor, but i will need time for that, which i currently just dont have.
Cheers
Cheers
#321
Hello kevin,
Cheers
Cheers
#322
Yeah very sad. The stuff is simply too expensive what you are getting. Gladly willing to pay more to get something that someone invested some time in to make it work, but it seems the only time that was invested was the one to throw some resin in a plug and earn a fast buck.....
Oh well, started building some small add-ons.....here are temperature and AOA sensor in 1/7,75
#323
#324
My Feedback: (48)
"Did any of you use button valves on the pneumatic doors? Servos? I'm planning to use BVM air quick-connects, but I don't want to have 5 of them hooked up."
I used button valves on my 1/9.5 F4. Also I glued a small magnet to the door to keep them closed during flight. The magnet contacts the steel axle bolt. See pictures.
Joe
Joe
