Skymaster 1:7.5 F-4 Phantom
#383
Wow!
Nice weight! Mine came in at 36.8 lb, but I'm looking at yours trying to figure out where you shaved that much off! Do you have the full cockpit? I've got a few doo-dads here and there (like an extra servo for the tail-hook), but nothing that adds up to 4 pounds!
#385
Wow!
I do use Futaba S-bus, and I made my own harnesses, so there was some weight savings from that. It also balanced perfectly at 333mm without any need for lead in the nose.
#389
Hi
So I'm building this bird for a customer and when i pulled the madking tape from the inner gear doors, the red wasn't as clean as I would have liked. I felt like a frustrated failure and was about to sand, re-tape and re-spray.... until I got a close look at ALL the doors on all the Navy birds with white inner doors with red borders. Jeez, looked like my 8-year-old daughter got drunk and did them with bucket and a fistful of straw!
#391
My Feedback: (21)
Hi
YellowAircraft (12-31-2021)
RCFlyerDan (01-03-2022)
#395
Interested in this Jet
Hi all, I have been following this thread for a bit. Currently building my second 1/9.5 extreme F4e. I want to purchase a larger one.
What is your thoughts of twin turbine vs single on this jet?
Do folks notice the scale discrepancies of the intakes vs cockpit location? Was it corrected with vs 2?
I have a FB 1/7 F15e twin to build after my F4e is completed.
Thank you in advance for your feedback.
Jeff
Jeff
#396
Buck,
I've got thick black gaffer's tape (the kind they use in theatre) holding the air lines down, then I've got the bottom half of the bypass clamshell trimmed down to go from the cool part of the engine to the inside front of the bell-mouth. The hot part of the bypass bottom has aluminum tape on it. Sound good or?
#398
Thanks, Buck!
I'll have John (I built it for him) keep an eye on that, but the few times I've run it up the engine, the fuse seemed pretty cool afterward. Ambient, actually, except for right before the front of the tail-cones. Right there, it's just warm, but comfy to the touch. Right aft of the bell mouth, you can hold your hand an inch away from the pipe and not feel a thing. I know heat can 'soak' so I checked it about 30 seconds after shut-down, and it's a hair warm under the back half of the hatch (I guess from the engine exhaust cone), but otherwise still nice and cool. I guess I got lucky with my install!
#399
A big Thank You to Anton and John at Skymaster Jets for answering my questions about this jet. I will be joining this group with a 1/7.75 scale F4e Phantom in the Thunderbird scheme in 14 weeks or so I ordered the Airex version and will setup as a twin. It will be cool to see this one sitting next to my 1/9.5 scale F4e Phantom also done in Thunderbird scheme. Next I will begin selling some of my other stuff that I am not using or flying to make room for this one.
Now back to working on my smaller F4e.
