Reload this Page >
Skymaster 1:7.5 F-4 Phantom
Old 07-10-2022, 01:38 PM
  #426
F16Jeff
Desert Fox,
Congrats on the successful maiden. Looks fairly stable once the trims were adjusted. What broke on landing?
My F4e should be shipping soon. Factory is finishing final touches on the drop tanks.
Jeff
Old 07-10-2022, 01:56 PM
  #427
Desert Fox 1
Hello Jeff,
Garey used a plastic arm on the steering servo. It broke, he should be replacing it with a metal arm.
Cheers!
Desert Fox 1
Old 07-10-2022, 06:44 PM
  #428
kevinthoele
Were there gear issues? Looked like they did not retract but I was watching on my Iphone. The F4 is such a great flying machine. I have 2 of the same size as yours. Enjoy!!!!
Old 07-10-2022, 06:51 PM
  #429
Desert Fox 1
Hello Kevin,
The left gear strut door was keeping the left gear from retracting. I spoke of it in the description for the video.
Cheers!
Desert Fox 1
Old 07-11-2022, 06:42 AM
  #430
kevinthoele
Originally Posted by Desert Fox 1
Hello Kevin,
Cheers!
Desert Fox 1
OK Hopefully you get that part figured. They fly awesome with gear retracted
Old 07-20-2022, 12:59 AM
  #431
LA jetguy
LA jetguy's Avatar
Hi Guys… My F4 should be arriving soon.. Plan to install a drag chute .. I was told this size (1:7.5) doesn’t have a factory (SM) chute mechanisms. Any suggestion on chute mechanisms ?
Thank you
Old 07-30-2022, 06:16 AM
  #432
F16Jeff
Thank you
Glad to see another F4 will be out here. Which scheme did you order? Mine is coming soon as well. It just cleared customs yesterday in Los Angeles. Should have it Monday or Tuesday.
I am designing a chute mechanism for my 1/9.5 scale F4e and will probably scale up for the 1/7.5 scale. Both of my F4s are in the Thunderbird scheme.
Jeff
Old 07-30-2022, 06:29 AM
  #433
LA jetguy
LA jetguy's Avatar
Jeff
Hi Jeff .., I got mine in the “Diamond Back” scheme to match my F18 and F14. I would really be interested to see how you do the chute mechanisms.. Hope you can make one for me to purchase ..
David
The following 2 users liked this post by LA jetguy:
Canadian Man (08-02-2022), f106jax (07-31-2022)
Old 07-30-2022, 07:00 AM
  #434
F16Jeff
Paint shop messed up the white step by the stab and had to repaint it. See next pic
Corrected the paint on fuse where the white meets the metal paint by the stab.
That is a nice looking scheme. Did you do single or twin? I ordered mine as a twin. I will make you one to purchase once I get it sorted out. RC Jet Chutes is making my chute. He did a great job on my smaller F4 chute. When did you order yours?
Old 07-30-2022, 07:05 AM
  #435
LA jetguy
LA jetguy's Avatar
I ordered mine as a twin.. Have two special X120 for it coming …. Ordered Mid April 2022. I will have Jeti equipment. Wha5 radio system will you use?
Old 07-30-2022, 07:12 AM
  #436
F16Jeff
I ordered mine in January, glad to see yours is being done quicker. I did order some changes to mine. Mainly had to do with the paint shop getting the scheme closer to the real Thunderbirds.
i am not sure which turbines I will use. I exclusively use Kingtech, but now some want me to try Ace. I plan to go with twin 120s as well.
I am using Jeti as well. CB220, rex 12, r3, r900, cortex pro, and Savox servos.
Old 07-30-2022, 07:25 AM
  #437
LA jetguy
LA jetguy's Avatar
Perfect on the Jeti.. But I plan on CB210, REX12, REX 3(clone), R3 (remote switch), Cortex Pro and MKS servos…. I have already ordered the air actuated Nose struts from Matrixx…
Canadian Man (08-02-2022), F16Jeff (07-30-2022)
Old 07-30-2022, 07:28 AM
  #438
LA jetguy
LA jetguy's Avatar
My F18 and F14.. same scheme
Old 07-30-2022, 07:38 AM
  #439
F16Jeff
I am curious about the air actuated nose strut. That will be nice for increasing angle of attack for take off. I want to figure out how to do operational canopies for mine.
Old 07-30-2022, 07:41 AM
  #440
LA jetguy
LA jetguy's Avatar
All will be on air. Using Xicoy air valves and Jeti sequencer for canopy.. nose strut air at “Take Off” flight mode.. with Jeti all is so simple… And of course will have an onboard air pump Jeti controlled 😀
Old 07-30-2022, 07:42 AM
  #441
F16Jeff
Do you have a link to the Matrixx air actuated nose strut?
Old 07-30-2022, 07:47 AM
  #442
LA jetguy
LA jetguy's Avatar
I have his email at “[email protected]”…. He is doing two of them for me and Jonathan (The lighter Side of RC)..
Old 07-30-2022, 07:50 AM
  #443
F16Jeff
Thank you, I will reach out to him.
Old 07-31-2022, 05:04 AM
  #444
SkyKnight
My Feedback: (67)
SkyKnight's Avatar
I'm glad to learn there are other twin projects coming. Mine is a twin also. I was strongly warned against doing a twin because it is supposed to be too heavy but I couldn't resist. I just wanted a twin Phantom! This is actually my 2nd twin Phantom project. I have the 1:6th also in the sale colors.
This is scheduled to have twin JetCat P130RX engines for the heartbeat and JR Elite for guidance.
The following 2 users liked this post by SkyKnight:
Old 07-31-2022, 06:23 AM
  #445
F16Jeff
Some of the guys on here were trying to talk me out of doing a twin as well. I have a 1/9.5 scale Extreme F4e that I am building as a single with a K142g4 in it. The turbines have gotten lighter, smaller, and more responsive, so running twins is not going to be much different in weight compared to a large single. Plus if you get the new airex composite, the jet is lighter than previous versions.
What size turbines did you use in your 1/7.5 jet?
I would like the 1/6, but limited for space and figuring out how to get these larger jets to the field is going to be challenging for me. I do not have a van or trailer. Currently my F250 is working well fir my 6 foot jets, but not sure with my new F4e and my Fei Bao 1/7 F15e.
Old 07-31-2022, 06:44 AM
  #446
F16Jeff
A funny thing happened to me on Friday. My jet arrived at LA customs on Wednesday and there had been no movement. After seeing it sit for another couple days, I called and spoke to an agent there. He informed me that my box is in the Customs bomb area. After being a little confused, then realizing that I have the wing tanks in the box that could look like missiles or whatever else they think. I explained it to them and after that it was released and now moving again. Hope to have it tomorrow.
Old 07-31-2022, 11:33 AM
  #447
SkyKnight
My Feedback: (67)
SkyKnight's Avatar
My 1:6th was earmarked for P220 RXIs but I'm reconsidering downgrading to P180RXI. I heard rumored that JetCat is planning a P180 RXI Pro version. If so, I will likely go with that option.
Old 08-01-2022, 07:18 AM
  #448
kevinthoele
Alan
The 180 engines are plenty big for this twin
Old 08-02-2022, 06:04 PM
  #449
F16Jeff
Default Thunderbird F4e
Excited my F4e arrived and so far most seems to have survived the trip. Still going through and checking the hardware. One thing I noticed is it seems the ailerons and flaps have external control linkages. I thought they are internal on this one. Not a big deal, but was looking forward to not seeing them under the wing.
I appreciate John, Anton, and their team for doing a great job.
The following 2 users liked this post by F16Jeff:
Canadian Man (08-03-2022), Halcyon66 (08-03-2022)
Old 08-02-2022, 09:46 PM
  #450
LA jetguy
LA jetguy's Avatar
Congrats Jeff .. Looks real nice 👍
David
