CARF Mephisto Build thread
AEROSHELDON (06-09-2021)
flyer1966 (06-13-2021)
AEROSHELDON (07-25-2021)
#961
Are the V2 tanks the preferred set these days?
I plan to mostly do precision acrobatics with the occasional hover and flat-spin.
#964
The 5ltr tank was produced to allow countries with a 25kg wet restriction to achieve this weight. In the U.K. the two tanks are still used throughout
Dave
Dave
#965
I fly my mephisto's with the dual stock tanks. I get about 7-8mins with my routine. The K320 lets it hover after about 3mins of flying. The last 2 mins of the flight are usually the best for 3D. Unless the 5L is needed for weight purposes - I'd go with the dual tanks.
The following 3 users liked this post by GULDUKAT:
flyer1966 (08-22-2021)
#971
As I continue pushing my Mephisto to its limits I encountered a failure today while taking it apart after flying. One wing tube seemed slightly loose, just a fraction but it made a cracking sound as I removed the wing. So the CF spar tube receiver had split. I can’t see any damage to the ply ribs and the wing feels solid but there is obviously a split tube and some of the Hysol type glue the factory uses is crumbled.
Back lit crack opening
At the bottom you can see a bit of missing glue
#973
There’s not much I can do besides seal the crack with a fiberglass patch and fly conservatively until I’m sure the wing isn’t spreading. That tube is completely buried in the wing center section. The only part of it I can access is where the crack is.
The only maneuver I do that I suspect could cause this is snap rolls, I say that because snaps with this beast can occasional be very dynamic. I do snap rolls with all my planes and try to be reasonable but the Mephisto can move quicker than just about any plane I’ve ever had so occasionally I’ll do a snap think, ouch!
But of course I don’t really know when that spar tube split… Just during the flying day.
I’m up to around 70 flights now.
#975
Yes, I noticed this movement during the wing removal today and that caught my attention but simply inserting the spar gives the same results. Namely movement in the vertical plane, as you would expect from the split allowing it, but no movement fore and aft. So it is a bit oblong. I cannot see any cracks opening in the structure when I apply leverage to the spar tube though, and clamping the structure doesn't close the gap, it looks is as if the play was there all along, but it wasn't. The other wing tube also has a smaller but still noticeable vertical play although that tube has not split. Obviously something elastic had to give to split the tube and now the tube is no longer perfectly round, but the ply all looks good and the glue looks good too. Not deformed. Maybe the glue used has crushed? I'm starting to think this vertical play has been evolving gradually, but the tube finally split today. Anyway, it is odd that the wood and glue do not appear to have deformed but the structure is allowing movement. I don't see any option but to apply fiberglass, then Hysol, maybe soak some thin CA into the wood?
