Reload this Page >
CARF Mephisto Build thread
Old 08-24-2021, 02:31 AM
  #976
Dave Wilshere
The tube is a guide, the main load is taken at each end by the hole in the plywood ribs. I’m sure it’s fine if you can bond the tube to the vertical web that’s there too, but you want to remove any ‘knock’ movement as any travel increases the load tremendously when it reaches the stop again.
Once the split is sealed I might coat the inside of the sleeve with a coat of finishing resin (ZAP40)
Ive emailed the factory for comments
Dave
Old 08-24-2021, 07:07 AM
  #977
husafreak
husafreak's Avatar
Thanks Dave. Removing any “play” at the wing rib sounds good.
Old 08-24-2021, 08:59 AM
  #978
husafreak
husafreak's Avatar
A few more pics for the factory. I think they are going overboard with the lightening holes, my opinion. On the looser wing, the side that split, I can definitely see missing plywood bits at the really thin points in the spar. But the CF looks intact, so hard to tell if the defect was there from the factory, or if the flapping motion of the wing has over time torn the plywood apart. CF is not elastic as far as I know.
Missing ply at spar tube from CF/ply/CF spar
Missing ply at other side
Other wing is sound, no missing ply
With gear removed it is easy to see that the white Hysol type glue is only applied on the accessible areas. The other side of the spar receiver tube has none of this. Wether that contributes to the tube splitting, or lost ply, at the point the glue stops I don’t know.
Old 08-24-2021, 10:41 AM
  #979
Dave Wilshere
First one we have heard of or seen. I have seen some severe abuse and have several around with over 100 3-D flights. The structure is sound normally.
Talk to your rep too
Dave
Old 08-24-2021, 10:57 AM
  #980
husafreak
husafreak's Avatar
Yup I informed Ray L. Thanks again for your help. I may glue ply plates over those holes since the ply (and CF) on the side we can’t see is gone. The resin in the tubes is drying now.
I like to post this stuff so other Mephisto owners can inspect their aircraft. We’ve seen way too many inflight failures around here lately. Yesterday my flying buddies Havok 210 shed a wing in flight. Thank god no one was hurt and we were able to put the fire out. Wing bolt sheared.
Plus, selfishly, it is pretty cool to post here in the evening and have a response from across the Atlantic the next morning.
AEROSHELDON (08-24-2021)
Old 08-24-2021, 11:24 AM
  #981
Dave Wilshere
We don’t really understand how the tube can crack between the support ribs from flight loads. With the wing on could you feel movement, or was it just removing the wing/spar.?
I started answering 5.45am, it’s now 8.20pm. Hobby business people expect answers 7 days a week, weekends are play days for the majority of people so when many people are resting people in the hobby industry carry on. It’s 18 hours a day 7 days a week for me…RCU people are generally not my customers…so it’s relaxation business/technical time 😄
Old 08-24-2021, 11:29 AM
  #982
husafreak
husafreak's Avatar
Well, now I’m mad. Went back out to check the wing and realized there is a big hole in the spar tube that split. And it was built in because you can clearly see the white Hysol from manufacturing. It may not be structurally significant that the factory installed a broken spar tube but it points to shoddy workmanship.
The structure crumbled away over many cycles, ply, carbon fiber, glue, the defective tube split causing me to hear a funny noise. Loose fit discovered, repair in progress.
Ragged hole in side of tube, white Hysol clearly visible.
Better photo
Old 08-24-2021, 11:44 AM
  #983
Dave Wilshere
The tube is mainly a guide for the spar. If the tube was not there and the two ribs had holes fitted to the carbon spar that’s most of the strength.
husafreak (08-24-2021)
Old 08-25-2021, 09:41 AM
  #984
husafreak
husafreak's Avatar
Repair finished. Due to the missing material in the spar and inability to patch on the spar tube side I installed a plywood patch. It’s really hard multi layer ply 1/8”. Also after sanding the resin in the wing tubes there is zero play. Thanks for the suggestion.
This ply plate covers the large lightening holes in the spar.
Old 09-08-2021, 02:35 PM
  #985
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
It looks like I am at 55mm away from the front of the bell, and this cage is hard to manipulate with one person.... best to just subtract 35mm from the hole it was in and then drill it out? There will be a lot of that tab left over too...
Old 09-08-2021, 03:56 PM
  #986
Dansy
My Feedback: (53)
Dansy's Avatar
I do 25mm (20-30mm) from the straight pipe disregard the bell….or reverse lips…
Old 09-08-2021, 04:01 PM
  #987
AEROSHELDON
My Feedback: (99)
normally I would but the manual for this pipe says 20mm from the front of the bell
Old 09-08-2021, 04:02 PM
  #988
Dansy
My Feedback: (53)
Dansy's Avatar
20 is between the range and probably give you 30mm or from the straight part…
Old 09-08-2021, 04:15 PM
  #989
AEROSHELDON
My Feedback: (99)
True !
Old 09-08-2021, 10:28 PM
  #990
LA jetguy
LA jetguy's Avatar
I always set the turbine the distance equal to half the diameter of the exhaust nozzle from the straight pipe.. ignore bell entrance..
works for all size turbine
David
Old 09-10-2021, 11:47 PM
  #991
winter1
winter1's Avatar
I leave 30 mm. ***winter***
Old 09-11-2021, 05:47 AM
  #992
AEROSHELDON
My Feedback: (99)
Thanks guys. The new pipe manual is specific that you leave 20mm from the actual front of the small bell.
Old 09-15-2021, 09:55 PM
  #993
flyer1966
flyer1966's Avatar
Default Mephisto canopy cap screw
Looks like I have lost my canopy cap screw for attaching my canopy on my Mephisto. Can someone tell me what size the cap screw is so I can buy a few new ones. Thanks
Old 09-16-2021, 03:08 AM
  #994
Dave Wilshere
M4 x 16
flyer1966 (09-16-2021)
Old 09-16-2021, 05:33 AM
  #995
flyer1966
flyer1966's Avatar
Default Mephisto
Originally Posted by Dave Wilshere View Post
M4 x 16
Thank you Dave
Old 09-16-2021, 05:36 AM
  #996
flyer1966
flyer1966's Avatar
Default Mephisto
M4 x 16
Dave do you know the thread pitch? 0.5 mm or 0.7 mm? Thanks
Old 09-16-2021, 12:47 PM
  #997
Dave Wilshere
0.7 Seems to be the std M4 thread.
Old 09-16-2021, 01:12 PM
  #998
flyer1966
flyer1966's Avatar
Default Mephisto
Thanks again Dave.
Old 09-17-2021, 09:58 AM
  #999
stuart_80
This useful information table is listed on the website of a UK based supplier of fixings
https://www.modelfixings.co.uk/threa...t%20Dimensions
For future reference if it’s any help to you
Old 09-17-2021, 05:15 PM
  #1000
AEROSHELDON
My Feedback: (99)
What's the general rule on the area needed for a Cheater Hole in the center wing section?
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
