Is there a Texan 2 / Harvard 2 in 1/6th?
AB, CANADA
Looking so see if there's one out there. I can't find one but that doesn't mean it doesn't exist. Kit or ARF is fine. I'd like to venture into turboprops and this would be my ultimate bird of choice.
My Feedback: (7)
a friend of mine bought one of these and put a Wren 44 TP. I'm sure the new KingTech 45 TP would fit well too.
https://vqwarbirds.com/product/esm-t...an-ii-usaf-80/
AB, CANADA
patrnflyr, yes I did see that one. Its a nice bird but I'm one of those OCD cases that wants everything to be the same scale. I would however be very interested in seeing some photo's of the modifications required to make it work. Do you have any photo's?
David, thanks for the reply but I am looking specifically for the Texan / Harvard 2
Dale
Dale
AB, CANADA
My Feedback: (102)
I have one partially built in my attic. The only thing holding it up is the canopy. The guy built a rough plug for it, but it needs to be finisihed. I have the center section of the winf, and the outer panels will be foam, which are already cut. Would love to see this thing finished out.
My Feedback: (102)
It was not setup for anything yet. Basically a blank canvas. The plans are for it to be turboprop. I fitted a K60TP in it with no problems and the prop would be scale for it. The guy did a fantastic job on the mockup. I just need to find time to finish it up. I have the drawings for it, and the drawings for the gear. He used Robart off the shelf gear for it. It is large bird for sure, but the construction is very light. It ought to fly like a homesick angel.
AB, CANADA
AB, CANADA
