Reload this Page >
Pilot-rc PREDATOR 2.2m Sport jet / full composite
Old 03-15-2023, 07:49 PM
  #726
bobzilla
My Feedback: (63)
bobzilla's Avatar
Default latest
The latest I have has hidden bolts to attach wings, no more cinch pins, i also have a one piece fuselage. Tank and uat separate. The rubber tank stopper is crap. 2 of mine had the 3rd hole open and leaked fuel upon filling. Inspect, or replace. Pilotrc may not build 1 piece fuselages anymore due to cost to ship/handle long crate.
Old 03-22-2023, 05:49 AM
  #727
bodywerks
bodywerks's Avatar
Is this even a 2.2M Predator? If that clamp you are showing is for the wing, you have an old version. The stab still uses a clamp on the front of the stab but rear threads in with a bolt at the elevator cutout. Wing attaches with a bolt horizontally through the LE and another in the back through the flap cutout.
Also, the canopy bolt is recessed. Yours doesn't appear to be.
Originally Posted by rmb
Thanks just looking for reassurance. Could anyone give me some idea if this would be a later version of the Predator, wings clamp LE and TE, screw locks canopy on and fuel tank and air trap are separate.
Old 03-22-2023, 09:16 AM
  #728
rmb
Definitely 2.2 meter the main wing has a clamp at the front and another clamp at the rear can't get pictures of rear clamp as it is awkward to get at, the early Predators had a single clamp of flat bar to hold main wing on, yes the latest Predators have screws front and rear. The stab has clamp at front and a screw at rear at elevator. Have recessed canopy screw myself think the older Predator had a spring latch same as turbine hatch.
Old 03-29-2023, 08:19 AM
  #729
bodywerks
bodywerks's Avatar
Yours is definitely not the latest version then. It must be an in-between version. I'm sure those clamps will fair better than the flat plate one, though.
Old 06-04-2023, 09:54 PM
  #730
Preauz
Where did you CG the plane. I have a 2.2m that im building right now but i feel like everyone says the factory CG is too nose heavy.
Old 06-04-2023, 10:09 PM
  #731
rmb
Have not finished my Predator yet but will go with the CG that pilot rc say, most people say it is a good starting point.
Old 06-04-2023, 10:40 PM
  #732
bobzilla
My Feedback: (63)
bobzilla's Avatar
Default cg
Uat full, gear down, 1" fuel in tank. Get a digital kitchen scale, move batteries till you get 26 to 32oz on nose wheel. Flaps 50 degrees down for landing. All 5 of my predators same.
Old 06-28-2023, 03:03 PM
  #733
rmb
How much throw are you using on elevator and ailerone, pilot rc give aileron 17mm elevator 13mm but think i would like more also what do you use for half flap and full flap ?
Thanks .
Old 06-28-2023, 03:14 PM
  #734
bobzilla
My Feedback: (63)
bobzilla's Avatar
Default 2.2m predator
I set ail/elev to triple rates, 35%, 55% and 90% of throw. I like middle rate best. I dont used flaps less then full. Full for landing and full for low speed pass. Expo set 30% low/mid, 40% on high.
Old 06-29-2023, 02:16 PM
  #735
rmb
Thanks for your quick reply . My predator is now ready for its maiden flight but weather not great for next week , looking forword to seeing it in the air.
Old 08-16-2023, 01:52 PM
  #736
Buzzsawheli
Hey guys I just picked up a Predator (2pc fuse) not sure what version it is. Seems the fuel tank is only held in place by the velco straps?? Is this what you guys are doing and are you pushing the tank all the back against the bulkhead or??
Thanks in advance.
Old 08-16-2023, 11:22 PM
  #737
Foresmate
Foresmate's Avatar
lightweight plywood can use it
Buzzsawheli (08-17-2023)
Old 08-17-2023, 06:31 AM
  #738
why_fly_high
My Feedback: (19)
Thanks in advance.
Mine has velcro along the bottom and then a couple straps wrapping it. I have thrown it around with thrust vectoring and the tank never budges.
